GitLab
Explore
Primary navigation
Search or go to…
E
eScriptorium
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Container registry
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
scripta
eScriptorium
af0172a1
af0172a1
4 years ago
Robin Tissot
Downloads
Merge branch 'develop'
parents
dc64ce9d
4117c8b9
1 merge request
!57
Adding missing libs in requirements
3
3 changed files
app/Dockerfile
+5
-5
5 additions, 5 deletions
app/Dockerfile
app/apps/core/tasks.py
+1
-1
1 addition, 1 deletion
app/requirements.txt
+2
2 additions, 0 deletions
8 additions
6 deletions
app/Dockerfile
5
5
af0172a1
@@ -14,9 +14,6 @@ ENV PYTHONUNBUFFERED 1
ARG
VERSION_DATE="passthistobuildcmd"
ENV
VERSION_DATE=$VERSION_DATE
# set work directory
WORKDIR
/usr/src/app
# update apk
RUN
apt-get update
@@ -26,9 +23,12 @@ RUN adduser --system --no-create-home --ingroup uwsgi uwsgi
RUN
apt-get
install
netcat-traditional jpegoptim pngcrush
RUN
apt-get
--assume-yes
install
libvips
RUN
pip
install
--upgrade
pip
COPY
./requirements.txt /usr/src/app/requirements.txt
WORKDIR
/usr/src/app
RUN
pip
install
--upgrade
pip
RUN
pip
install
-U
-r
requirements.txt
COPY
./entrypoint.sh /usr/src/app/entrypoint.sh
This diff is collapsed.
af0172a1
@@ -509,7 +509,7 @@ def before_publish_state(sender=None, body=None, **kwargs):
if
sender
task_id
sender
request
id
not
check_signal_order
sender
status
signal_name
return
except
KeyError
except
KeyError
AttributeError
pass
sender
2
af0172a1
@@ -24,3 +24,5 @@ django-compressor==2.4
albumentations
django-simple-captcha==0.5.12
pyvips==2.1.12
scikit-image==0.17.2
scipy==1.5.2
Loading
Save comment
