GitLab
Explore
Primary navigation
Search or go to…
R
RobotLearn Cluster Monitor
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
RobotLearn
e799b319
e799b319
2 years ago
LEPAGE Gaetan
Downloads
Patches
minor things
9d6840fc
Pipeline
#557792
passed
2 years ago
Stage: deploy
backend/main.py
+2
-3
2 additions, 3 deletions
backend/main.py
2 additions
3 deletions
backend/main.py
2
3
e799b319
@@ -49,7 +49,6 @@ def _update_loop(socket_io: socketio.Server) -> None:
# If the update fails, just ignore it and try another time.
try
try
payload_dict
dict
cluster
update
payload_dict
dict
cluster
update
# payload_dict: dict = {}
socket_io
emit
socket_io
emit
event
update
event
update
@@ -61,7 +60,7 @@ def _update_loop(socket_io: socketio.Server) -> None:
# Eventually wait before updating again
if
REFRESH_TIME
if
REFRESH_TIME
LOGGER
info
waiting %is before updating again
REFRESH_TIME
LOGGER
debug
REFRESH_TIME
time
sleep
REFRESH_TIME
time
sleep
REFRESH_TIME
step_counter
step_counter
@@ -91,7 +90,7 @@ def callback_disconnect(*args) -> None:
def
main
None
def
main
None
# Run the update loop that
gets updates from the data fetcher.
queries cluster information
socket_io
start_background_task
socket_io
target
_update_loop
target
_update_loop
socket_io
socket_io
socket_io
socket_io
This diff is collapsed.
Loading
Save comment
