Commit 737a3fb6 authored by AGULLO Emmanuel's avatar AGULLO Emmanuel
how to reconfigure
parent 5dc78447
...@@ -113,7 +113,20 @@ with this repository. ...@@ -113,7 +113,20 @@ with this repository.
(service cups-service-type)) (service cups-service-type))
%my-services)) %my-services))
Once the /etc/config.scm has been set up, the system can be reconfigured:
sudo guix system reconfigure /etc/config.scm
The machine does not need to be globally restarted, it is sufficient to restart the service:
sudo herd restart guix-daemon
The correctness of the set up can then be checked with the ```ps aux | grep
guix-daemon``` command.
2. [Authorize](https://www.gnu.org/software/guix/manual/en/html_node/Substitute-Server-Authorization.html) 2. [Authorize](https://www.gnu.org/software/guix/manual/en/html_node/Substitute-Server-Authorization.html)
the key used to sign substitutes: the key used to sign substitutes:
Supports Markdown
