GitLab
Explore
Primary navigation
Search or go to…
F
fbxsdk_python
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Package registry
Model registry
Operate
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
ADILI Robin
fbxsdk_python
0d2f8ae2
0d2f8ae2
4 years ago
w-v
Downloads
Patches
add libraries requirements for windows
4653ab24
windows
2
2 changed files
build.bat
+6
-16
6 additions, 16 deletions
build.bat
pyproject.toml
+6
-4
6 additions, 4 deletions
pyproject.toml
12 additions
20 deletions
build.bat
6
16
0d2f8ae2
@@ -7,7 +7,7 @@ SET "SIPDIR=%BUILDDIR%\sip-4.19.3"
SET
"SIPINSTALLDIR=
%BUILDDIR%
\sipinstall"
SET
"SIPINSTALLDIR=
%BUILDDIR%
\sipinstall"
SET
"vs_buildtoolsexe=
%BUILDDIR%
\vs_buildtools.exe"
SET
"vs_buildtoolsexe=
%BUILDDIR%
\vs_buildtools.exe"
SET
"FBXSDKDIR=
%BUILDDIR%
\fbxsdk"
SET
"FBXSDKDIR=
%BUILDDIR%
\fbxsdk"
SET
"FBXSDKPYTHONDIR=
%BUILDDIR%
\fbx
sdk
py"
SET
"FBXSDKPYTHONDIR=
%BUILDDIR%
\fbxpy"
:: PYTHONVERSION=$(python -c [...]) #lol
for
/f
%%i
in
'python -c "import sys; print(''.join(sys.version.split('
')[0].split('
')[:2]))"'
do
set
PYTHONVERSION
%%i
for
/f
%%i
in
')[0].split('
')[:2]))"'
do
set
PYTHONVERSION
%%i
SET
"FBXDIR=
%CURRENTDIR%
\fbxsdkpy-cp
%PYTHONVERSION%
-win_x64"
SET
"FBXDIR=
%CURRENTDIR%
\fbxsdkpy-cp
%PYTHONVERSION%
-win_x64"
@@ -22,7 +22,7 @@ echo "Download and install Visual Studio Build Tools (nmake, MSVC, link, etc.)"
curl
-L -o
%vs_buildtoolsexe%
https
://aka.ms/vs/16/release/vs_buildtools.exe
curl
-L -o
%vs_buildtoolsexe%
https
%vs_buildtoolsexe%
--quiet --wait --norestart --nocache --installPath
%BUILDTOOLSDIR%
--remove
Microsoft
.VisualStudio.Component.Windows10SDK.10240
--remove
Microsoft
.VisualStudio.Component.Windows10SDK.10586
--remove
Microsoft
.VisualStudio.Component.Windows10SDK.14393
--remove
Microsoft
.VisualStudio.Component.Windows81SDK
--add
Microsoft
.VisualStudio.Workload.VCTools
--add
Microsoft
.VisualStudio.Component.VC.Tools.x86.x64
--add
Microsoft
IF
%ERRORLEVEL%
"3010"
EXIT
%vs_buildtoolsexe%
%BUILDTOOLSDIR%
--remove
Microsoft
--remove
Microsoft
--remove
Microsoft
--remove
Microsoft
--add
Microsoft
--add
Microsoft
--add
Microsoft
.18362
IF
%ERRORLEVEL%
"3010"
EXIT
echo
"Load environment variables to use Build Tools from this script"
echo
@@ -33,22 +33,12 @@ for /F "tokens=1,2 delims=;" %%i in (reqs_win.txt) do (
%BUILDDIR%
%%i
.exe"
/S /D
%BUILDDIR%
%%i
%BUILDDIR%
%%i
.exe"
/S /D
%BUILDDIR%
%%i
::curl -L -O "https://gitlab.inria.fr/radili/fbxsdk_python/uploads/12002ae82d20e4d6b60107dacb5abe4b/sip-4.19.3.tar.gz"
curl
-L -o
%BUILDDIR%
\patch.py"
"https://raw.githubusercontent.com/techtonik/python-patch/master/patch.py"
python
%BUILDDIR%
\patch.py"
patch
tar
xvf
sip
4
.19.3.tar.gz
-C
%BUILDDIR%
sip
-wheel --verbose
cd
%BUILDDIR%
\sip
python
"configure.py"
-b
%SIPINSTALLDIR%
-d
%SIPINSTALLDIR%
-e
%SIPINSTALLDIR%
--pyidir
%SIPINSTALLDIR%
--sip-module
"fbxsip"
nmake
nmake
install
cd
%CURRENTDIR%
copy
"PythonBindings.py"
%FBXSDKPYTHONDIR%
\PythonBindings.py"
SET
"FBXSDK_ROOT=
%FBXSDKDIR%
SET
"SIP_ROOT=
%SIPDIR%
python
%FBXSDKPYTHONDIR%
\PythonBindings.py
Python3_x64
copy
%FBXSDKPYTHONDIR%
\build\Distrib\site-packages\fbx\*"
%FBXDIR%
copy
%SIPINSTALLDIR%
\fbxsip.pyd"
%FBXDIR%
%vs_buildtoolsexe%
uninstall
%BUILDTOOLSDIR%
--remove
Microsoft
--remove
Microsoft
--remove
Microsoft
--remove
Microsoft
--remove
Microsoft
--remove
Microsoft
--remove
Microsoft
IF
%ERRORLEVEL%
"3010"
EXIT
%vs_buildtoolsexe%
uninstall
%BUILDTOOLSDIR%
--remove
Microsoft
--remove
Microsoft
--remove
Microsoft
--remove
Microsoft
--remove
Microsoft
--remove
Microsoft
--remove
Microsoft
IF
%ERRORLEVEL%
"3010"
EXIT
popd
popd
pause
pause
This diff is collapsed.
pyproject.toml
6
4
0d2f8ae2
# Specify sip v5 as the build system for the package.
[build-system]
[build-system]
requires
"sip >=5, <6"
"auditwheel"
requires
"sip >=5, <6"
build-backend
"sipbuild.api"
build-backend
"sipbuild.api"
# Specify the PEP 566 metadata for the project.
@@ -12,10 +12,12 @@ version = "2020.1"
[tool.sip.bindings.fbx_module]
headers
"fbxsdk.h"
headers
"fbxsdk.h"
include-dirs
"build/fbxsdk/include"
include-dirs
libraries
"fbxsdk"
# python 3.7 3.8 3.9
library-dirs
"build/fbxsdk/lib/gcc/x64/release"
libraries
"libfbxsdk-md"
"zlib-md"
"libxml2-md"
"Advapi32"
"Wininet"
# python 3.6
# libraries = ["libfbxsdk-mt", "zlib-mt", "libxml2-mt", "Advapi32", "Wininet"]
library-dirs
"build/fbxsdk/lib/vs2017/x64/release"
[tool.sip.project]
[tool.sip.project]
sip-files-dir
"build/fbxpy/sip"
sip-files-dir
"build/fbxpy/sip"
wheel-includes
"build/fbxpy/common/FbxCommon.py"
wheel-includes
minimum-glibc-version
"2.17"
Loading
Save comment
