Commit ee369392 authored by jeancoquet's avatar jeancoquet
Fix bug on filterSigExpressions
parent 4185c8dc
...@@ -426,7 +426,7 @@ def parse_event(event): ...@@ -426,7 +426,7 @@ def parse_event(event):
# _h_2018 _h_820 _h_4939 _h_5231 _h_3301 _h_4967 _h_2303 _h_3301 # _h_2018 _h_820 _h_4939 _h_5231 _h_3301 _h_4967 _h_2303 _h_3301
return [tree] return [tree]
def filterSigExpressions(expr): def filterSigExpression(expr):
.. note:: No SigConstExpr here => filtered in get_transitions() .. note:: No SigConstExpr here => filtered in get_transitions()
by checking null events (event="") in the model. by checking null events (event="") in the model.
...@@ -448,6 +448,9 @@ def parse_event(event): ...@@ -448,6 +448,9 @@ def parse_event(event):
raise AssertionError("You should never have been there ! " raise AssertionError("You should never have been there ! "
"Your expression type is not yer supported...") "Your expression type is not yer supported...")
def filterSigExpressions(listOfExpr):
return [filterSigExpression(expr) for expr in listOfExpr]
# Error Reporter # Error Reporter
err = Reporter() err = Reporter()
tvi = TableVisitor(err) tvi = TableVisitor(err)
