GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
VIGNET Pierre
cadbiom
e3507745
e3507745
VIGNET Pierre
Upgrade install/uninstall methods for dev
f383d679
4
command_line/Makefile
e3507745
@@ -20,17 +20,15 @@ install:
echo
Install the package...
pip
install
uninstall
files.txt
uninstall
echo
Uninstalling the package...
pip uninstall
-y
cadbiom_cmd
dev_install
echo
Install the package
for
developers...
python2.7 setup.py develop
dev_uninstall
echo
for
developers...
--uninstall
# Replacement for python setup.py develop which doesn't support extra_require keyword.
# Install a project in editable mode.
pip
install
-e
.[dev]
unit_tests
echo
Launch unit tests
doc/source/installation.rst
e3507745
@@ -226,7 +226,7 @@ Just do:
.. code-block:: bash
$ make
dev_
uninstall
$ make uninstall
Testing
gui/Makefile
e3507745
echo
pip
install
uninstall
files.txt
uninstall
echo
pip uninstall
-y
cadbiom_gui
dev_install
echo
Install the package
for
developers...
dev_uninstall
echo
for
developers...
--uninstall
pip
install
-e
.[dev]
upload
clean sdist
python setup.py bdist_wheel
library/Makefile
e3507745
@@ -24,17 +24,15 @@ install:
echo
pip
install
uninstall
files.txt
uninstall
echo
pip uninstall
-y
cadbiom
dev_install
echo
Install the package
for
developers...
dev_uninstall
echo
for
developers...
--uninstall
pip
install
-e
.[dev]
unit_tests
echo
Launch unit tests
