GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
VIGNET Pierre
cadbiom
dc27928d
dc27928d
VIGNET Pierre
[lib][tests] Hardening tests by using the error attr of the reporter
fe28f3c0
library/cadbiom/models/guard_transitions/analyser/TestStaticAnalysis.py
dc27928d
@@ -51,7 +51,6 @@ Review: Pay attention: Lots of tests are made without any assertion.
from
__future__
import
print_function
import
pkg_resources
import
unittest
import
sys
import
os
import
networkx
as
nx
@@ -65,10 +64,10 @@ from cadbiom.models.guard_transitions.chart_model import ChartModel
from
cadbiom.models.guard_transitions.translators.chart_xml
import
MakeModelFromXmlFile
from
cadbiom.commons
import
DIR_LOGS
from
cadbiom.commons
import
DIR_LOGS
logger
TRACEFILE
sys
stdout
#TRACEFILE = open("/tmp/testMCLTranslator.txt",'w'
LOGGER
logger
class
Reporter
object
@@ -86,7 +85,8 @@ class Reporter(object):
self
error
True
mess
self
mess
"ERROR -> "
mes
TRACEFILE
write
\n\n
mess
LOGGER
error
mess
class
TestAnaVisitors
unittest
TestCase
@@ -118,6 +118,7 @@ class TestAnaVisitors(unittest.TestCase):
scc
append
elem
print
'SCC FRONTIER '
scc
# empty list ?
assert
scc
assert
reporter
error
False
class
TestStaticAnalysis
unittest
TestCase
@@ -152,6 +153,7 @@ class TestStaticAnalysis(unittest.TestCase):
lvi
LangVisitor
out
parser
model
accept
lvi
out
close
assert
reporter
error
False
def
test_frontier1_no_clock
self
@@ -182,7 +184,7 @@ class TestStaticAnalysis(unittest.TestCase):
lvi
LangVisitor
out
parser
model
accept
lvi
out
close
assert
reporter
error
False
def
test_frontier2
self
@@ -204,6 +206,7 @@ class TestStaticAnalysis(unittest.TestCase):
ftr
sta
get_frontier_scc
print
ftr
assert
set
'betaglycan__dimer___intToMb'
'TGFB_TGFBR2_betaglycan_active_intToMb'
ftr
assert
reporter
error
False
def
test_get_tr_node_variables
self
