Commit cff62b3c authored by VIGNET Pierre's avatar VIGNET Pierre
[lib] Tests: Export/Import of models with MacroNode; Check order of xml attributes
parent c03674b0
...@@ -4,21 +4,23 @@ ...@@ -4,21 +4,23 @@
from __future__ import unicode_literals from __future__ import unicode_literals
from __future__ import print_function from __future__ import print_function
# Standard imports # Standard imports
import pytest import os
import tempfile import tempfile
import pytest
@pytest.fixture()
def feed_model_with_SCC(): @pytest.yield_fixture()
def feed_SCC_model():
"""Fixture for a Cadbiom model with 4 Strongly Connected Components """Fixture for a Cadbiom model with 4 Strongly Connected Components
:return: A list of SCC, and the corrected model with start nodes inserted. :return: A list of SCC, the corrected model with start nodes inserted
:rtype: <tuple <list>, <str>> and the original model with SCC.
:rtype: <tuple <list>, <str>, <NamedTemporaryFile>>
scc = [['I', 'K', 'J', 'L'], ['Y', 'X', 'Z']] scc = [['I', 'K', 'J', 'L'], ['Y', 'X', 'Z']]
model = """<?xml version = "1.0" encoding="ASCII" standalone="yes" ?> model_without_scc = """<?xml version = "1.0" encoding="ASCII" standalone="yes" ?>
<model xmlns="http://cadbiom" name=""> <model xmlns="http://cadbiom" name="">
<CSimpleNode name="A"/> <CSimpleNode name="A"/>
<CSimpleNode name="B"/> <CSimpleNode name="B"/>
...@@ -34,6 +36,11 @@ def feed_model_with_SCC(): ...@@ -34,6 +36,11 @@ def feed_model_with_SCC():
<CSimpleNode name="L"/> <CSimpleNode name="L"/>
<CStartNode name="__start__0"/> <CStartNode name="__start__0"/>
<CStartNode name="__start__1"/> <CStartNode name="__start__1"/>
<CMacroNode name="default_name_1" xloc="0.548920863309" yloc="0.589680589681" wloc="0.3" hloc="0.3">
<CSimpleNode name="A_1" xloc="0.0458033573137" yloc="0.364864864865"/>
<CSimpleNode name="B_1" xloc="0.30071942446" yloc="0.623259623259"/>
<transition ori="A_1" ext="B_1" event="h_1" condition=""/>
</CMacroNode>
<transition ori="I" ext="J" event="" condition=""/> <transition ori="I" ext="J" event="" condition=""/>
<transition ori="L" ext="I" event="" condition=""/> <transition ori="L" ext="I" event="" condition=""/>
<transition ori="K" ext="L" event="" condition=""/> <transition ori="K" ext="L" event="" condition=""/>
...@@ -54,27 +61,7 @@ def feed_model_with_SCC(): ...@@ -54,27 +61,7 @@ def feed_model_with_SCC():
</model> </model>
return scc, model # Create the original file model in /tmp/
def test_SCC_search(feed_model_with_SCC):
"""Test the correction of a model by removing Strongly Connected Components
- We add a start node for every SCC
- We add a transition between the start node and the smallest node of every
SCC (sorted in lexicogrpahic order)
- Thus, we add xml preamble in the model
Keep in mind that by testing the result of the export of a model, we also
test its content...
import cadbiom.models.guard_transitions.analyser.model_corrections as mc
model = feed_model_with_SCC[1]
# Create the file model in /tmp/
# Note: prevent the deletion of the file after the close() call # Note: prevent the deletion of the file after the close() call
fd_model = tempfile.NamedTemporaryFile(suffix='.bcx', delete=False) fd_model = tempfile.NamedTemporaryFile(suffix='.bcx', delete=False)
fd_model.write( fd_model.write(
...@@ -91,6 +78,11 @@ def test_SCC_search(feed_model_with_SCC): ...@@ -91,6 +78,11 @@ def test_SCC_search(feed_model_with_SCC):
<CSimpleNode name="K"/> <CSimpleNode name="K"/>
<CSimpleNode name="J"/> <CSimpleNode name="J"/>
<CMacroNode yloc="0.589680589681" hloc="0.3" wloc="0.3" name="default_name_1" xloc="0.548920863309">
<CSimpleNode yloc="0.364864864865" name="A_1" xloc="0.0458033573137"/>
<CSimpleNode yloc="0.623259623259" name="B_1" xloc="0.30071942446"/>
<transition ext="B_1" ori="A_1" action="" event="h_1" condition=""/>
</CMacroNode>
<transition name="" ori="A" ext="B" event="" condition="C"/> <transition name="" ori="A" ext="B" event="" condition="C"/>
<transition name="" ori="B" ext="D" event="" condition=""/> <transition name="" ori="B" ext="D" event="" condition=""/>
<transition name="" ori="C" ext="B" event="" condition="A"/> <transition name="" ori="C" ext="B" event="" condition="A"/>
...@@ -110,12 +102,37 @@ def test_SCC_search(feed_model_with_SCC): ...@@ -110,12 +102,37 @@ def test_SCC_search(feed_model_with_SCC):
fd_model.close() fd_model.close()
yield scc, model_without_scc, fd_model
# Tear down
os.remove(fd_model.name)
def test_SCC_search(feed_SCC_model):
Moreover, we:
- Add xml preamble in the model,
- Check the order of attributes of xml elements,
- Check import/export of a model with a macro node.
test its content...
_, model_without_scc, model_with_scc = feed_SCC_model
# Make a new model file (with "_without_scc" suffix in filename) # Make a new model file (with "_without_scc" suffix in filename)
mc.add_start_nodes(fd_model.name) # Filename + path mc.add_start_nodes(model_with_scc.name) # Filename + path
expected_lines = set(model.split("\n")) expected_lines = set(model_without_scc.split("\n"))
with open(fd_model.name[:-4] + "_without_scc.bcx", 'r') as file: with open(model_with_scc.name[:-4] + "_without_scc.bcx", 'r') as file:
found_lines = set(file.read().split("\n")) found_lines = set(file.read().split("\n"))
assert found_lines == expected_lines assert found_lines == expected_lines
Supports Markdown
