GitLab
Explore
Primary navigation
Search or go to…
cadbiom
Manage
Plan
Issue boards
Code
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
VIGNET Pierre
cadbiom
cca016e3
cca016e3
5 years ago
VIGNET Pierre
Downloads
Patches
[lib] Add doc
3547375d
Branches containing commit
Tags containing commit
library/cadbiom/models/guard_transitions/chart_model.py
+1
1 addition, 0 deletions
1 addition
cca016e3
@@ -852,6 +852,7 @@ class CSimpleNode(CNode):
return
True
return
True
def
set_name
self
name
def
set_name
self
name
Rename the current node; update simple_node_dict attr of the model
try
try
del
self
model
simple_node_dict
self
name
del
self
model
simple_node_dict
self
name
except
except
This diff is collapsed.
Loading
Save comment
