GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
VIGNET Pierre
cadbiom
b9781777
b9781777
VIGNET Pierre
[cmd] Add doc for start, invariant, final properties
e46e727f
2
command_line/cadbiom_cmd/cadbiom_cmd.py
b9781777
@@ -292,7 +292,8 @@ def main():
parser_input_file
add_argument
'chart_file'
parser_input_file
add_argument
'chart_file'
# Get final_property alone OR an input_file containing multiple properties
group
parser_input_file
add_mutually_exclusive_group
required
True
group
parser_input_file
required
True
group
add_argument
'final_prop'
nargs
group
add_argument
'final_prop'
nargs
help
"Final property that will occur at the end of the simulation."
group
add_argument
'--input_file'
action
ReadableFile
nargs
group
add_argument
'--input_file'
action
ReadableFile
nargs
help
"Without input file, there will be only one process. "
help
"While there will be 1 process per line (per logical formula "
@@ -317,8 +318,14 @@ def main():
parser_input_file
add_argument
'--continue'
action
'store_true'
parser_input_file
add_argument
'--continue'
action
'store_true'
help
"Resume previous computations; if there is a mac file from a "
help
"previous work, last frontier places/boundaries will be reloaded."
parser_input_file
add_argument
'--start_prop'
nargs
default
None
parser_input_file
add_argument
'--start_prop'
nargs
default
None
parser_input_file
add_argument
'--inv_prop'
nargs
default
None
help
"Property that will be part of the initial state of the model. "
"In concrete terms, some entities can be activated by this "
"mechanism without modifying the model."
parser_input_file
add_argument
'--inv_prop'
nargs
default
None
help
"Invariant property that will never occur during the simulation. "
"The given logical formula will be enclose by a logical not() and "
"will be checked at each step of the simulation."
parser_input_file
set_defaults
func
solutions_search
parser_input_file
set_defaults
func
solutions_search
command_line/cadbiom_cmd/solution_search.py
b9781777
@@ -23,6 +23,9 @@
@@ -23,6 +23,9 @@
# 35042 RENNES Cedex, FRANCE
Search Minimal Accessibility Conditions
Simulation of the system until some halting condition (given with the final
property) is satisfied.
from
__future__
import
unicode_literals
from
__future__
import
unicode_literals
from
__future__
import
print_function
from
__future__
import
print_function
@@ -138,8 +141,14 @@ def main2(chart_file, mac_file, mac_step_file, mac_complete_file, mac_strong_fil
:param mac_strong_file: ???
:param steps: Maximal steps to reach the solutions.
:param final_prop: Formula: Property that the solver looks for.
:param start_prop: Formula: Original property (constraint) for the solver. ## TODO
:param start_prop: Formula: Property that will be part of the initial state
:param inv_prop: Formula: ???## TODO
of the model.
In concrete terms, some entities can be activated by this mechanism
:param inv_prop: Formula: Invariant property that will never occur during
the simulation.
:param all_macs: If set to True (not default), search all macs with
less or equal the maxium of steps defined with the argument `steps`.
If set to False: The solver will search all solutions with the minimum
