GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
VIGNET Pierre
cadbiom
b272b829
b272b829
VIGNET Pierre
Fix bug in solutions_2_json: unable to take only one file; add test for valid file/path
0d47bbf3
2
command_line/cadbiom_cmd/cadbiom_cmd.py
b272b829
@@ -82,8 +82,6 @@ def solutions_2_json(args):
# Module import
# Module import
import
solution_sort
import
solution_sort
params
args_to_param
args
params
args_to_param
args
params
'output'
params
'output'
if
params
'output'
else
params
'output'
solution_sort
solutions_2_json
solution_sort
solutions_2_json
params
'output'
params
'output'
params
'chart_file'
params
'chart_file'
command_line/cadbiom_cmd/solution_sort.py
b272b829
@@ -128,9 +128,12 @@ def solutions_2_json(output_dir, model_file, solution_path, conditions=True):
def
write_json_file
decompiled_filename
decomp_solutions
def
write_json_file
decompiled_filename
decomp_solutions
# Write file
# Write file
open
decompiled_filename
'w'
as
f_d
open
decompiled_filename
'w'
as
f_d
json
dump
decomp_solutions
f_d
sort_keys
True
indent
4
json
dump
decomp_solutions
f_d
sort_keys
True
indent
2
# Check valid input file/directory
assert
os
path
isfile
solution_path
os
path
isdir
solution_path
# Get transitions from the model
model_transitions
get_transitions_from_model_file
model_file
model_transitions
model_file
Supports
