Attention une mise à jour du service Gitlab va être effectuée le mardi 18 janvier (et non lundi 17 comme annoncé précédemment) entre 18h00 et 18h30. Cette mise à jour va générer une interruption du service dont nous ne maîtrisons pas complètement la durée mais qui ne devrait pas excéder quelques minutes.
Commit b0a3e6fc authored by VIGNET Pierre's avatar VIGNET Pierre
[lib] Tests: MCLTranslator: Fix typos
parent 7f4db566
......@@ -65,16 +65,12 @@ from cadbiom.models.guard_transitions.analyser.ana_visitors import TableVisitor
from cadbiom.models.clause_constraints.mcl.MCLAnalyser import MCLAnalyser
# simple reporter
class ErrorRep(object):
Simple error reporter
"""Simple error reporter"""
def __init__(self):
self.mess = ""
self.error = False
pass
def display(self, mess):
......@@ -442,7 +438,6 @@ class TestTransitionClauses(unittest.TestCase):
print("place_clocks", cl_ds.place_clocks)
assert cl_ds.place_clocks == {"_lit2": ["n3"], "_lit0": ["n1"]}
# TODO: check this
print("reporter: ", reporter.mess)
assert reporter.mess == ">> type error -> h is not a state (clock)"
......@@ -494,7 +489,6 @@ class TestTransitionClauses(unittest.TestCase):
# TODO: check this
assert reporter.mess == ">> Default signal:(n2 when n1) is not a clock"
......@@ -890,18 +884,8 @@ class TestFull(unittest.TestCase):
print("inputs:", cl_ds.inputs)
expected = {
"n3",
"h2",
"h3",
"h1",
"_lit2",
"_lit3",
"n1",
"_lit1",
"_lit0",
"n4",
"n2",
"_lit4",
"n3", "h2", "h3", "h1", "_lit2", "_lit3", "n1", "_lit1", "_lit0",
"n4", "n2", "_lit4",
assert cl_ds.base_var_set == expected
assert cl_ds.free_clocks == ["h3", "h1", "h2"]
......@@ -983,21 +967,8 @@ class TestFull(unittest.TestCase):
expected = {
"n3",
"h2",
"h3",
"h1",
"_lit6",
"_lit7",
"_lit2",
"_lit3",
"n1",
"_lit1",
"_lit0",
"n4",
"n2",
"_lit5",
"_lit4",
"n3", "h2", "h3", "h1", "_lit6", "_lit7", "_lit2", "_lit3", "n1",
"_lit1", "_lit0", "n4", "n2", "_lit5", "_lit4",
