Attention une mise à jour du service Gitlab va être effectuée le mardi 14 décembre entre 13h30 et 14h00. Cette mise à jour va générer une interruption du service dont nous ne maîtrisons pas complètement la durée mais qui ne devrait pas excéder quelques minutes.
Commit af81310b authored by VIGNET Pierre's avatar VIGNET Pierre
[lib] Remove attrs hloc/wloc in CStartNode, CSimpleNode, CInputNode; Relative...
[lib] Remove attrs hloc/wloc in CStartNode, CSimpleNode, CInputNode; Relative to refactor of XmlVisitor
parent 6b476b81
...@@ -656,8 +656,6 @@ class CStartNode(CNode): ...@@ -656,8 +656,6 @@ class CStartNode(CNode):
def __init__(self, x_coord, y_coord, model, **kwargs): def __init__(self, x_coord, y_coord, model, **kwargs):
CNode.__init__(self, x_coord, y_coord, model, **kwargs) CNode.__init__(self, x_coord, y_coord, model, **kwargs)
self.name = "__start__" self.name = "__start__"
self.wloc = 1.0
self.hloc = 1.0 # for compatibility with find
def copy(self, model=None): def copy(self, model=None):
...@@ -824,7 +822,6 @@ class CSimpleNode(CNode): ...@@ -824,7 +822,6 @@ class CSimpleNode(CNode):
CNode.__init__(self, xcoord, ycoord, model, **kwargs) CNode.__init__(self, xcoord, ycoord, model, **kwargs)
self.name = name self.name = name
self.father = None # double linkage for coordinate computations self.father = None # double linkage for coordinate computations
self.hloc = 1.0
self.activated = False self.activated = False
self.was_activated = False self.was_activated = False
...@@ -993,7 +990,6 @@ class CInputNode(CSimpleNode): ...@@ -993,7 +990,6 @@ class CInputNode(CSimpleNode):
def __init__(self, xcoord, ycoord, name, model, **kwargs): def __init__(self, xcoord, ycoord, name, model, **kwargs):
CSimpleNode.__init__(self, xcoord, ycoord, name, model, **kwargs) CSimpleNode.__init__(self, xcoord, ycoord, name, model, **kwargs)
self.hloc = 1.0
def is_input(self): def is_input(self):
