GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
VIGNET Pierre
cadbiom
93063634
VIGNET Pierre
[test] Fix command line test: changes in API of get_transitions_from_model_file
cca016e3
2
command_line/cadbiom_cmd/tools/solutions.py
93063634
@@ -277,9 +277,17 @@ def convert_solutions_to_json(sol_steps, transitions, conditions=True):
# Get transitions for the given event
# Structure of transitions:
# {u'h00': [('Ax', 'n1', {u'label': u'h00[]'}),]
LOGGER
debug
"convert_solutions_to_json:: %s"
transitions
step_event
transitions
get
event
None
step_event
transitions
event
if
not
step_event
if
not
step_event
LOGGER
error
"convert_solutions_to_json:: event not found in the "
"transitions of the model: %s"
event
LOGGER
error
"convert_solutions_to_json:: transitions: %s"
transitions
decomp_event
'event'
"ERROR, no transition"
decomp_event
'event'
else
else
# Get list of transitions
command_line/test/test_mac.py
93063634
@@ -191,7 +191,7 @@ def test_convert_solutions_to_json(raw_feed_output, simulate_mac_complete_file):
fd_model_name
raw_feed_output
fd_model_name
raw_feed_output
# Get transitions from the model
model_transitions
fd_model_name
model_transitions
_
fd_model_name
decomp_solutions
decomp_solutions
load_solutions
load_solutions
model_transitions
model_transitions
