GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
VIGNET Pierre
cadbiom
86fd252b
86fd252b
VIGNET Pierre
[lib] TestCLUnfolder: Adapt to CLUnfolder changes
88fbb30e
library/cadbiom/models/clause_constraints/mcl/TestCLUnfolder.py
86fd252b
@@ -224,9 +224,9 @@ class TestCLUnfolder(unittest.TestCase):
model
model1
unfolder
create_unfolder
model
# test frontier: should be n1
cfr
unfolder
get_
frontier
cfr
unfolder
frontier
_values
res
unfolder
get_var_name
cfr
'n1'
res
res
len
unfolder
get_
frontier
res
res
len
unfolder
frontier
_values
self
assert_
res
'Error in frontier: model1'
# model2 (one cycle without start)
@@ -234,9 +234,9 @@ class TestCLUnfolder(unittest.TestCase):
unfolder
create_unfolder
model
cfr
unfolder
get_
frontier
cfr
unfolder
frontier
_values
res
unfolder
get_var_name
cfr
'n1'
res
res
len
unfolder
get_
frontier
res
res
len
unfolder
frontier
_values
self
assert_
res
'Error in frontier: model2'
# model3: same as model2 but with a start on n3
@@ -244,7 +244,7 @@ class TestCLUnfolder(unittest.TestCase):
unfolder
create_unfolder
model
# test frontier - should be {n1, n3}
cfr
unfolder
get_
frontier
cfr
unfolder
frontier
_values
res
len
cfr
2
res
res
unfolder
get_var_name
cfr
'n1'
res
res
unfolder
get_var_name
cfr
'n3'
@@ -253,7 +253,7 @@ class TestCLUnfolder(unittest.TestCase):
# model4
model
model4
unfolder
create_unfolder
model
cfr
unfolder
get_
frontier
cfr
unfolder
frontier
_values
res
len
cfr
# res = res and unfolder.get_var_name(cfr[0]) == 'n3'
self
assert_
res
'Error in frontier: model4'
@@ -278,14 +278,16 @@ class TestCLUnfolder(unittest.TestCase):
unfolder
create_unfolder
model
lfc
unfolder
get_free_clocks
res
len
lfc
2
res
res
unfolder
get_var_name
lfc
'hh2'
res
res
unfolder
get_var_name
lfc
'hh1'
found_names
unfolder
get_var_name
clock
for
clock
in
lfc
res
found_names
'hh2'
'hh1'
self
assert_
res
'Error in free clocks: model4'
lin
unfolder
get_inputs
res
len
lin
res
res
unfolder
get_var_name
lin
'in1'
found_names
unfolder
get_var_name
inpt
for
inpt
in
lin
res
found_names
'in1'
self
assert_
res
'Error in inputs: model4'
unittest
skip
"Test is not implemented"
def
test_init_forward
self
test forward initialization for various models and property
