Commit 66bb264a authored by VIGNET Pierre's avatar VIGNET Pierre
[lib] CLU: Fix typos
parent 9ddd9ce9
...@@ -1424,13 +1424,12 @@ class CLUnfolder(object): ...@@ -1424,13 +1424,12 @@ class CLUnfolder(object):
if self.__variant_property: if self.__variant_property:
self.__precomputed_variant_constraints = list() self.__precomputed_variant_constraints = list()
for prop in self.__variant_property:
# compile initial (X0) property into numeric form # compile initial (X0) property into numeric form
# For each property in step of __variant_property # For each property in step of __variant_property
self.__precomputed_variant_constraints.append( self.__precomputed_variant_constraints += [
[self.__code_clause(clause) [self.__code_clause(clause) for clause in self.__compile_event(prop)]
for clause in self.__compile_event(prop)] for prop in self.__variant_property
if self.__dimacs_variant: if self.__dimacs_variant:
# Add DIMACS clauses # Add DIMACS clauses
