GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
VIGNET Pierre
cadbiom
6306fd99
6306fd99
VIGNET Pierre
[cmd] Fix typos in docstrings
81527c2d
2
command_line/cadbiom_cmd/cadbiom_cmd.py
6306fd99
@@ -38,6 +38,7 @@ LOGGER = cm.logger()
def
check_output_dir
function
def
check_output_dir
function
"""Decorator used process some arguments from argparse"""
# Expose the docstring of the wrapped function instead of that of the decorator
wraps
function
wraps
function
def
modified_func
args
kwargs
def
modified_func
args
kwargs
"""Fix paths in arguments (add trailing '/')"""
@@ -79,7 +80,7 @@ def solutions_sort(args):
check_output_dir
check_output_dir
def
solutions_2_graphs
args
def
solutions_2_graphs
args
"""Create GraphML formated files containing a representation of the
trajectories for e
very
solution in complete MAC files (*mac_complete files).
trajectories for e
ach
This is a function to visualize paths taken by the solver from the boundaries
to the entities of interest.
@@ -135,8 +136,9 @@ def json_2_interaction_graph(args):
check_output_dir
check_output_dir
def
solutions_2_common_graph
args
def
args
"""Create a GraphML formated file containing a representation of **all**
"""Create a GraphML formated file containing a unique representation of **all**
trajectories for **all** solutions in complete MAC files (*mac_complete files).
trajectories corresponding to all solutions in each complete MAC files
command_line/cadbiom_cmd/solution_sort.py
6306fd99
@@ -226,7 +226,7 @@ def solutions_2_graphs(output_dir, model_file, path):
"""Entry point for solutions_2_graphs
trajectories for e
very
solution in complete MAC files (\*mac_complete files).
trajectories for e
ach
@@ -321,8 +321,9 @@ def convert_solution_file_to_graphs(output_dir, sol_steps, transitions):
def
output_dir
model_file
path
def
output_dir
model_file
path
"""Entry point for solutions_2_common_graph
trajectories for **all** solutions in complete MAC files (\*mac_complete files).
