GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
VIGNET Pierre
cadbiom
4baa096e
4baa096e
VIGNET Pierre
Add method to merge cams to csv file
3118a54d
solution_merge.py
4baa096e
# -*- coding: utf-8 -*-
from
__future__
import
unicode_literals
from
__future__
import
print_function
import
glob
import
csv
def
merge_cams_to_csv
directory
csvfile
'merged_cams.csv'
"""Merge *cam.txt files from a directory to a csv."""
# Add dir separator to the end if not present
directory
directory
if
directory
else
directory
csv_data
list
# Read all files in the given directory
for
filename
in
glob
glob
directory
'*_cam.txt'
#print(filename)
# Extract the formula from the filename
# ex:
# # ['./result/Whole NCI-PID database translated into CADBIOM formalism(and)', 'TGFB1', 'cam.txt']
formula
join
filename
split
'_'
# Read the content of the cam file & memorize this content
open
filename
as
fd
# Add formula column, before each cam to futur csv file
csv_data
append
formula
line
rstrip
\n
for
line
in
fd
# Write the final csv
open
directory
csvfile
'w'
as
fd
writer
csv
writer
fd
delimiter
writer
writerows
csv_data
if
__name__
"__main__"
merge_cams_to_csv
'result'
Supports
