Commit 477ef5c0 authored by VIGNET Pierre's avatar VIGNET Pierre
[lib] Cleaning stats management; Sync with new solver (nb_clauses)
parent c7b8fae5
...@@ -154,9 +154,11 @@ shift(): ...@@ -154,9 +154,11 @@ shift():
from __future__ import print_function from __future__ import print_function
from packaging import version
#from pyCryptoMS import CryptoMS #from pyCryptoMS import CryptoMS
from pycryptosat import Solver as CryptoMS from pycryptosat import Solver as CryptoMS
from pycryptosat import __version__ as solver_version
from cadbiom.models.biosignal.translators.gt_visitors import compile_cond, compile_event from cadbiom.models.biosignal.translators.gt_visitors import compile_cond, compile_event
from cadbiom.models.clause_constraints.CLDynSys import Clause, Literal from cadbiom.models.clause_constraints.CLDynSys import Clause, Literal
from cadbiom.models.clause_constraints.mcl.MCLSolutions import RawSolution, MCLException from cadbiom.models.clause_constraints.mcl.MCLSolutions import RawSolution, MCLException
...@@ -439,10 +441,10 @@ class CLUnfolder(object): ...@@ -439,10 +441,10 @@ class CLUnfolder(object):
"""Disable solver statistics (never used)""" """Disable solver statistics (never used)"""
self.__stats = False self.__stats = False
def _stats(self): def stats(self):
"""Display solver statistics""" """Display solver statistics"""
print("\n NB Variables in solver:", self.__nb_vars) LOGGER.info("NB Variables in solver:", self.__nb_vars)
print("NB Clauses in solver:", self.__nb_clauses) LOGGER.info("NB Clauses in solver:", self.__nb_clauses)
def set_include_aux_clauses(self, val): def set_include_aux_clauses(self, val):
"""Flag to include auxiliary clause to eliminate undesirable solutions. """Flag to include auxiliary clause to eliminate undesirable solutions.
...@@ -1375,6 +1377,24 @@ class CLUnfolder(object): ...@@ -1375,6 +1377,24 @@ class CLUnfolder(object):
LOGGER.debug(str(self.__initial_constraints)) LOGGER.debug(str(self.__initial_constraints))
def __sync_stats(self, solver):
"""Sync local data (nb vars, nb clauses) with solver state
if stats are activated (never besides in test environment).
.. note:: Its the only way to set __nb_vars and __nb_clauses attributes.
if version.parse(solver_version) < version.parse("5.6.9"):
if solver.nb_vars() > self.__nb_vars:
self.__nb_vars = solver.nb_vars()
else:
if solver.nb_vars > self.__nb_vars:
# Starting from pycryptosat 5.2, nb_clauses is private
# Starting from 5.6.9 the attribute is exposed
if solver.nb_clauses > self.__nb_clauses:
self.__nb_clauses = solver.nb_clauses
def __constraints_satisfied(self): def __constraints_satisfied(self):
"""Ask the SAT solver if the query/system is satisfiable in the given """Ask the SAT solver if the query/system is satisfiable in the given
number of steps. number of steps.
...@@ -1391,13 +1411,9 @@ class CLUnfolder(object): ...@@ -1391,13 +1411,9 @@ class CLUnfolder(object):
if self.__stats: if self.__stats:
# If stats are activated (never besides in test environment): # If stats are activated (never besides in test environment):
# sync local data (nb vars, nb clauses with solver state) # sync local data (nb vars, nb clauses) with solver state
if solver.nb_vars() > self.__nb_vars: self.__sync_stats(solver)
# Starting from pycryptosat 5.2, nb_clauses() is a private attribute
#if solver.nb_clauses() > self.__nb_clauses:
# self.__nb_clauses = solver.nb_clauses()
# Is the problem satisfiable ? # Is the problem satisfiable ?
return solver.is_satisfiable() return solver.is_satisfiable()
...@@ -1422,12 +1438,8 @@ class CLUnfolder(object): ...@@ -1422,12 +1438,8 @@ class CLUnfolder(object):
if LOGGER.getEffectiveLevel() == DEBUG: if LOGGER.getEffectiveLevel() == DEBUG:
LOGGER.debug("__msolve_constraints :: vvars : %s", vvars) LOGGER.debug("__msolve_constraints :: vvars : %s", vvars)
