Attention une mise à jour du service Gitlab va être effectuée le mardi 18 janvier (et non lundi 17 comme annoncé précédemment) entre 18h00 et 18h30. Cette mise à jour va générer une interruption du service dont nous ne maîtrisons pas complètement la durée mais qui ne devrait pas excéder quelques minutes.
Commit 15588892 authored by VIGNET Pierre's avatar VIGNET Pierre
Handle Start nodes in exported graph for a bcx model
parent 3307da77
......@@ -154,14 +154,19 @@ def load_solutions(file):
def get_transitions(file, all_places=False):
"""Get all transitions in a file model (bcx format).
:param: Model in bcx format.
:type: <str>
:param arg1: Model in bcx format.
:param arg2: Ask to return all the places of the model.
(useful for get_frontier_places() that compute frontier places)
:type arg1: <str>
:type arg2: <bool>
:return: A dictionnary of events as keys, and transitions as values.
Since many transitions can define an event, values are lists.
Each transition is a tuple with: origin node, final node, attributes
like label and condition.
{u'h00': [('Ax', 'n1', {u'label': u'h00[]'}),]
:rtype: <dict <list <tuple <str>, <str>, <dict <str>: <str>>>>
If all_places is True, this func returns also a list of all places in
the model.
parser = MakeModelFromXmlFile(file)
......@@ -183,9 +188,15 @@ def get_transitions(file, all_places=False):
# ori/ext entities, so we have to extract them and their respective
# conditions
if trans.event == '':
# null event without clock...
# null event without clock => StartNodes
# These nodes are used to resolve the problem of
# Strongly Connected Components (inactivated cycles in the graph)
# The nodes
# Avoids having SigConstExpr as event type in parse_event()
continue
# I create a transition (SCC-__start__?),
# and a node (__start__?) for this case.
trans.event = 'SCC-' + trans.ori.name
events = {trans.event: trans.condition}
elif re.match('_h_[0-9_\.]+', trans.event):
# 1 event (with 1 clock)
......@@ -222,7 +233,14 @@ def get_transitions(file, all_places=False):
def get_frontier_places(transitions, all_places):
"""Return frontier places of a model (deducted from its transitions).
"""Return frontier places of a model (deducted from its transitions and
from all places of the model).
.. note:: why we use all_places from the model instead of
(input_places - output_places) to get frontier places ?
Because some nodes are only in conditions and not in transitions.
If we don't do that, these nodes are missing when we compute
valid paths from conditions.
:param arg1: Model's transitions.
