Commit 28b22a9b authored by NOEL Philippe's avatar NOEL Philippe
Solve conflict in tools.rs
parents 8f248f06 5cf4f49b
Pipeline #75844 passed with stages
in 2 minutes and 52 seconds
[package] [package]
name = "pdbparser" name = "pdbparser"
version = "1.0.0" version = "1.0.0"
authors = ["NOEL Philippe <philippe.noel@inria.fr>"] authors = ["NOEL Philippe <philippe.noel@inria.fr>", "BRESSO Emmanuel <emmanuel.bresso@loria.fr>"]
edition = "2018" edition = "2018"
include = ["Cargo.toml", "src/**/*.rs", "tests/**/*.rs", "README.md"] include = ["Cargo.toml", "src/**/*.rs", "tests/**/*.rs", "README.md"]
This diff is collapsed.
...@@ -352,4 +352,39 @@ impl Structure { ...@@ -352,4 +352,39 @@ impl Structure {
/// Used to remove Hydrogens in the proteins
/// # Examples
/// use pdbparser;
/// let my_struct = pdbparser::read_pdb("tests/tests_file/f2.pdb", "f2");
/// let ss_h = my_struct.remove_h().unwrap();
/// assert_eq!(541, ss_h.get_atom_number());
pub fn remove_h(&self) -> Option<Structure> {
let mut new_struct = Structure::new(self.name.clone());
for chain in &self.chains {
let c_chain = chain.name;
for residue in &chain.lst_res {
let c_res = residue.res_num;
for atom in &residue.lst_atom {
if !(atom.name().starts_with("H")) {
new_struct.update_structure(
c_chain,
residue.name.clone(),
c_res,
atom.name.clone(),
atom.number,
atom.coord,
new_struct.refine_atom_numbering();
Some(new_struct)
use std::collections::HashMap; use std::collections::HashMap;
use std::env;
use std::fs;
use std::fs::File;
use std::io::BufReader;
use std::io::prelude::BufRead;
use std::process;
use super::structure::Structure; use super::structure::Structure;
use super::atom::Atom;
/// Convert the all amino acid to a FASTA sequence (1 residue as 1 char) /// Convert the all amino acid to a FASTA sequence (1 residue as 1 char)
/// Consult the corresponding table to have the code 1 letter <-> 3 letters /// Consult the corresponding table to have the code 1 letter <-> 3 letters
...@@ -56,3 +63,98 @@ pub fn fasta_seq(my_struct: &Structure) -> String { ...@@ -56,3 +63,98 @@ pub fn fasta_seq(my_struct: &Structure) -> String {
fasta fasta
// extract atom mass from Charmm parameter files.
fn atom_mass() -> HashMap<String, f32> {
let mut ref_masses = HashMap::new();
// If CHARMM_FOLDER enviroment variable is defined, then look for .parm files in this folder. Else use the ./datasets folder*.
let key = "CHARMM_FOLDER";
let charmm_folder = match env::var(key) {
Ok(charmm_folder) => charmm_folder,
_ => "./datasets".to_string(),
let paths = match fs::read_dir(charmm_folder) {
Ok(paths) => paths,
Err(_e) => {
eprintln!("cannot find your charmm folder");
process::exit(1);
for path in paths {
let test = path.unwrap().path();
if test.is_file() && test.extension().unwrap().to_str() == Some("prm") {
let charmmf = match File::open(test) {
Ok(charmmf) => charmmf,
Err(e) => {
eprintln!("Error while reading {}", e);
process::exit(1);
let reader = BufReader::new(charmmf);
for line in reader.lines() {
// MASS -1 H 1.00800 ! polar H
let l = line.unwrap();
if l.starts_with("MASS") {
let split: Vec<&str> = l.split_ascii_whitespace().collect();
let val = match split[3].parse::<f32>() {
Ok(val) => val,
Err(e) => {
eprintln!("Cannot cast {} into f32", e);
process::exit(1);
ref_masses.insert(split[2].to_string(), val);
return ref_masses;
/// Calculate the center of mass of a selection of atoms
/// Atom masses are extracted from CHARMM Force Field .prm files.
/// If CHARMM_FOLDER environement variable is set, .prm files in this folder are used. Else it will be files in datasets folder.
/// # Example
/// use pdbparser;
/// let my_prot = pdbparser::read_pdb("tests/tests_file/5jpq.pdb", "5jqp");
/// let atom_number = my_prot.get_atom_number() as usize;
/// let mut atoms: Vec<pdbparser::Atom> = Vec::with_capacity(atom_number);
/// for chain in my_prot.chains {
/// for residue in chain.lst_res {
/// for atom in residue.lst_atom {
/// atoms.push(atom);
/// assert_eq!([237.98595, 241.93814, 231.15921], pdbparser::center_of_mass(atoms))
pub fn center_of_mass(atom_list: Vec<Atom>) -> [f32; 3] {
let mut coord: [f32;3] = [0.0, 0.0, 0.0];
let mut mass_tot: f32 = 0.0;
let ref_masses = atom_mass();
for atom in atom_list {
let mass = match ref_masses.get(&atom.name) {
Some(mass) => *mass,
None => 0.0
mass_tot += mass;
coord[0] += mass * atom.coord[0];
coord[1] += mass * atom.coord[1];
coord[2] += mass * atom.coord[2];
[coord[0] / mass_tot, coord[1] / mass_tot, coord[2] / mass_tot]
...@@ -49,3 +49,42 @@ fn f2_res() { ...@@ -49,3 +49,42 @@ fn f2_res() {
.unwrap(); .unwrap();
assert_eq!("HSD", res.name()); assert_eq!("HSD", res.name());
#[test]
fn mass_center_f2() {
let mut atoms: Vec<pdbparser::Atom> = Vec::new();
for chain in my_struct.chains {
atoms.push(atom);
assert_eq!([0.011766517, 20.1037, -0.007502083], pdbparser::center_of_mass(atoms))
#[test]
fn mass_center_5jpq() {
let my_struct = pdbparser::read_pdb("tests/tests_file/5jpq.pdb", "5jpq");
atoms.push(atom);
#[test]
fn remove_hydrogens_f2(){
\ No newline at end of file
