Commit 305b0142 authored by MARIJON Pierre's avatar MARIJON Pierre
Add AAG with just adjacency edges
parent 5c6f2630
...@@ -33,19 +33,22 @@ def main(args=None): ...@@ -33,19 +33,22 @@ def main(args=None):
param = dict() param = dict()
contig_info(param, open(args["input_prefix"] + "knot/contigs.fasta")) contig_info(param, open(args["input_prefix"] + "_knot/contigs.fasta"))
if args["classification"]: if args["classification"]:
run_classification(args["input_prefix"] + "AAG.csv", args["input_prefix"]) run_classification(args["input_prefix"] + "_AAG.csv", args["input_prefix"])
classification_info(param, open(args["input_prefix"]+"classification.csv")) classification_info(param, open(args["input_prefix"]+"_knot" + os.sep + "classification.csv"))
if args["hamilton_path"]: if args["hamilton_path"]:
run_hamilton(args["input_prefix"] + "AAG.csv", args["input_prefix"]) run_hamilton(args["input_prefix"] + "_AAG.csv", args["input_prefix"])
hamilton_info(param, open(args["input_prefix"]+"hamilton_path.csv")) hamilton_info(param, open(args["input_prefix"]+"_knot" + os.sep + "hamilton_path.csv"))
full_aag_info(param, open(args["input_prefix"]+"AAG.csv")) full_aag_info(param, open(args["input_prefix"]+"_AAG.csv"))
build_AAG_representation(param, open(args["input_prefix"]+"AAG.csv")) build_AAG_representation(param, open(args["input_prefix"]+"_AAG.csv"))
build_clean_AAG(param, open(args["input_prefix"]+"_AAG.csv"), open(args["input_prefix"] + "_knot" + os.sep + "classification.csv"))
args["output"].write(template.render(param).encode("utf-8")) args["output"].write(template.render(param).encode("utf-8"))
...@@ -58,18 +61,20 @@ def contig_info(param, contig_file): ...@@ -58,18 +61,20 @@ def contig_info(param, contig_file):
param["tig_info"] = tig2len param["tig_info"] = tig2len
def run_classification(aag_path, prefix_output): def run_classification(aag_path, prefix_output):
subprocess.run(["knot.analysis.classifications", "-i", aag_path, "-o", prefix_output+"_classification.csv"]) subprocess.run(["knot.analysis.classifications", "-i", aag_path, "-o", prefix_output + "_knot" + os.sep + "classification.csv"])
def classification_info(param, classification_file):
def __classification_info(classification_file):
ext2type = dict() ext2type = dict()
for row in csv.DictReader(classification_file): for row in csv.DictReader(classification_file):
ext2type[(row["ext1"], row["ext2"])] = row["type"] ext2type[(row["ext1"], row["ext2"])] = row["type"]
param["classification_info"] = ext2type return ext2type
param["classification_info"] = __classification_info(classification_file)
def run_hamilton(aag_path, prefix_output): def run_hamilton(aag_path, prefix_output):
subprocess.run(["knot.analysis.hamilton_path", "-i", aag_path, "-o", prefix_output+"_hamilton_path.csv"]) subprocess.run(["knot.analysis.hamilton_path", "-i", aag_path, "-o", prefix_output + "_knot" + os.sep + "hamilton_path.csv"])
def hamilton_info(param, hamilton_file): def hamilton_info(param, hamilton_file):
...@@ -87,9 +92,7 @@ def full_aag_info(param, aag_file): ...@@ -87,9 +92,7 @@ def full_aag_info(param, aag_file):
param["full_aag_info"] = aag_record param["full_aag_info"] = aag_record
def build_AAG_representation(param, aag_file): def get_aag_graph(aag_file):
nodes = ""
edges = ""
edges_dict = dict() edges_dict = dict()
tig_set = set() tig_set = set()
...@@ -107,12 +110,12 @@ def build_AAG_representation(param, aag_file): ...@@ -107,12 +110,12 @@ def build_AAG_representation(param, aag_file):
edges_dict[frozenset((row["tig1"], row["tig2"]))] = int(row["nb_base"]) edges_dict[frozenset((row["tig1"], row["tig2"]))] = int(row["nb_base"])
for (tig1, tig2), length in edges_dict.items(): return edges_dict, tig_set
if length <= 0:
length = "overlap" def __construct_tig(tig_set):
edges += "{{ from: '{}', to: '{}', label: '{}', id: '{}' }},\n".format(tig1, tig2, length, tig1+"-"+tig2) nodes = ""
edges = ""
for tig in tig_set: for tig in tig_set:
nodes += "{{ id: '{}_begin', label: 'begin' }},\n".format(tig, tig) nodes += "{{ id: '{}_begin', label: 'begin' }},\n".format(tig, tig)
nodes += "{{ id: '{}_end', label: 'end' }},\n".format(tig, tig) nodes += "{{ id: '{}_end', label: 'end' }},\n".format(tig, tig)
...@@ -121,9 +124,40 @@ def build_AAG_representation(param, aag_file): ...@@ -121,9 +124,40 @@ def build_AAG_representation(param, aag_file):
e1 = tig + "_begin" e1 = tig + "_begin"
e2 = tig + "_end" e2 = tig + "_end"
edges += "{{from: '{}', to: '{}', label: '{}', width: 10, length: 1}},\n".format(e1, e2, tig) edges += "{{from: '{}', to: '{}', label: '{}', width: 10, length: 1}},\n".format(e1, e2, tig)
return nodes, edges
edges_dict, tig_set = get_aag_graph(aag_file)
nodes, edges = __construct_tig(tig_set)
if length <= 0:
length = "overlap"
param["aag_nodes"] = nodes param["aag_nodes"] = nodes
param["aag_edges"] = edges param["aag_edges"] = edges
def build_clean_AAG(param, aag, classification):
edges_dict, tig_set = get_aag_graph(aag)
classification = __classification_info(classification)
for (tig1, tig2), value in classification.items():
if not value.endswith("adjacency"):
continue
key = frozenset((tig1, tig2))
length = edges_dict[key]
if length <= 0:
length = "overlap"
param["aag_clean_nodes"] = nodes
param["aag_clean_edges"] = edges
if __name__ == "__main__": if __name__ == "__main__":
main() main()
<h1>Augmented Assembly Graph</h1> <h1>Augmented Assembly Graph</h1>
<h2>ALL link</h2>
<div id="aag"></div> <div id="aag"></div>
<script type="text/javascript"> <script type="text/javascript">
...@@ -33,3 +34,40 @@ ...@@ -33,3 +34,40 @@
var network = new vis.Network(container, data, options); var network = new vis.Network(container, data, options);
</script> </script>
<h2>Only adjacents link</h2>
<div id="aag_clean"></div>
// create an array with nodes
var nodes = new vis.DataSet([
{{aag_clean_nodes}}
// create an array with edges
var edges = new vis.DataSet([
{{aag_clean_edges}}
// create a network
var container = document.getElementById('aag_clean');
var data = {
nodes: nodes,
edges: edges
var options = {
height: '600px',
width: '600px',
nodes: {
shape: 'dot',
physics: {
forceAtlas2Based: {
avoidOverlap: 400
solver: 'forceAtlas2Based',
</script>
