Commit c11c70aa authored by Simon Boyé's avatar Simon Boyé
Vitelotte: Better OpenGL / shader handling + move srgb to gl_utils.
parent 0e3601ac
// Generated by shader2cpp. // Generated by shader2cpp.
// 2015-01-02T22:31:38.866645 // 2015-01-09T13:54:33.104329
#ifndef PATATE_VITELOTTE_UTILS_SHADER_H
#define PATATE_VITELOTTE_UTILS_SHADER_H
namespace Vitelotte namespace Vitelotte
...@@ -478,3 +482,4 @@ static const char* vert_common_glsl = ...@@ -478,3 +482,4 @@ static const char* vert_common_glsl =
#endif PATATE_VITELOTTE_UTILS_SHADER_H
...@@ -6,16 +6,13 @@ ...@@ -6,16 +6,13 @@
#include "../../common/gl_utils/shader.h" #include "../../common/gl_utils/shader.h"
//#include "shaders.hpp" #include "../Core/femUtils.h"
namespace Vitelotte { namespace Vitelotte {
inline Eigen::Vector4f linearToSrgb(const Eigen::Vector4f& linear);
inline Eigen::Vector4f srgbToLinear(const Eigen::Vector4f& srgb);
class VGMeshGL2RendererShader class VGMeshGL2RendererShader
public: public:
...@@ -5,28 +5,6 @@ namespace Vitelotte ...@@ -5,28 +5,6 @@ namespace Vitelotte
//Eigen::Vector4f linearToSrgb(const Eigen::Vector4f& linear)
// Eigen::Vector4f srgb = linear;
// for(int i=0; i<3; ++i)
// srgb(i) = linear(i) > 0.0031308?
// 1.055 * std::pow(linear(i), 1/2.4):
// 12.92 * linear(i);
// return srgb;
//Eigen::Vector4f srgbToLinear(const Eigen::Vector4f& srgb)
// Eigen::Vector4f linear = srgb;
// linear(i) = linear(i) > 0.04045?
// std::pow((linear(i)+0.055) / 1.055, 2.4):
// linear(i) / 12.92;
// return linear;
VGMeshRendererGL2DefaultShader::VGMeshRendererGL2DefaultShader() VGMeshRendererGL2DefaultShader::VGMeshRendererGL2DefaultShader()
: m_viewMatrix(Eigen::Matrix4f::Identity()), : m_viewMatrix(Eigen::Matrix4f::Identity()),
m_singularTriangles(false), m_singularTriangles(false),
...@@ -436,7 +414,7 @@ VGMeshGL2Renderer<_Mesh>::nodeValue(Node node) const ...@@ -436,7 +414,7 @@ VGMeshGL2Renderer<_Mesh>::nodeValue(Node node) const
if(m_pMesh->isValid(node) && m_pMesh->isConstraint(node)) if(m_pMesh->isValid(node) && m_pMesh->isConstraint(node))
if(m_renderSrgb) if(m_renderSrgb)
return srgbToLinear(m_pMesh->nodeValue(node)); return PatateCommon::srgbToLinear(m_pMesh->nodeValue(node));
else else
return m_pMesh->nodeValue(node); return m_pMesh->nodeValue(node);
...@@ -5,17 +5,15 @@ ...@@ -5,17 +5,15 @@
#include <Eigen/Dense> #include <Eigen/Dense>
#include "../../common/gl_utils/color.h"
#include "shaders.hpp" #include "shaders.hpp"
class VGMeshRendererShader class VGMeshRendererShader
public: public:
12.92 * linear(i);
return srgb;
linear(i) / 12.92;
return linear;
VGMeshRendererDefaultShader::VGMeshRendererDefaultShader() VGMeshRendererDefaultShader::VGMeshRendererDefaultShader()
...@@ -409,7 +387,7 @@ inline typename VGMeshRenderer<_Mesh>::NodeValue ...@@ -409,7 +387,7 @@ inline typename VGMeshRenderer<_Mesh>::NodeValue
VGMeshRenderer<_Mesh>::nodeValue(Node node) const VGMeshRenderer<_Mesh>::nodeValue(Node node) const
return NodeValue(0, 0, 0, 1); // FIXME: Make this class work for Chan != 4 return NodeValue(0, 0, 0, 1); // FIXME: Make this class work for Chan != 4
#ifndef _PATATE_COMMON_GL_UTILS_COLOR_
#define _PATATE_COMMON_GL_UTILS_COLOR_
#include "Eigen/Dense"
namespace PatateCommon
12.92 * linear(i);
return srgb;
linear(i) / 12.92;
return linear;
#endif
...@@ -7,7 +7,8 @@ ...@@ -7,7 +7,8 @@
#include <string.h> #include <string.h>
#define PATATE_ASSERT_NO_GL_ERROR() \ #ifndef PATATE_ASSERT_NO_GL_ERROR
GLenum Error = glGetError(); \ GLenum Error = glGetError(); \
...@@ -16,6 +17,7 @@ ...@@ -16,6 +17,7 @@
exit(0); \ exit(0); \
#endif
#define PATATE_FIELD_OFFSET(_struct, _field) &(static_cast<_struct*>(0)->_field) #define PATATE_FIELD_OFFSET(_struct, _field) &(static_cast<_struct*>(0)->_field)
#!/bin/sh #!/bin/sh
./bin/shader2cpp -n Vitelotte::shader -o Patate/Vitelotte/Utils/shaders.hpp Patate/Vitelotte/Shaders/* ./bin/shader2cpp \
-n Vitelotte::shader \
-g PATATE_VITELOTTE_UTILS_SHADER_H \
-o Patate/Vitelotte/Utils/shaders.hpp \
...@@ -10,6 +10,8 @@ from datetime import datetime ...@@ -10,6 +10,8 @@ from datetime import datetime
argparser = ArgumentParser(description='Convert a set of shaders into cpp source code') argparser = ArgumentParser(description='Convert a set of shaders into cpp source code')
argparser.add_argument('-e', '--extern', default=False, action='store_true', argparser.add_argument('-e', '--extern', default=False, action='store_true',
help="Declare variables with external linkage.") help="Declare variables with external linkage.")
argparser.add_argument('-g', '--include-guard', default='',
help="Protect the file against multiple inclusion.")
argparser.add_argument('-o', '--output', default='-', argparser.add_argument('-o', '--output', default='-',
help="Write the output to the file output, or stdout if omitted or output is '-'.") help="Write the output to the file output, or stdout if omitted or output is '-'.")
argparser.add_argument('-n', '--namespace', default='', argparser.add_argument('-n', '--namespace', default='',
...@@ -26,6 +28,12 @@ print("// {}".format(datetime.utcnow().isoformat()), file=out) ...@@ -26,6 +28,12 @@ print("// {}".format(datetime.utcnow().isoformat()), file=out)
print(file=out) print(file=out)
if options.include_guard:
print("#ifndef", options.include_guard, file=out)
print("#define", options.include_guard, file=out)
print(file=out)
print(file=out)
if namespaces: if namespaces:
for ns in namespaces: for ns in namespaces:
if ns != '': if ns != '':
...@@ -52,5 +60,7 @@ if namespaces: ...@@ -52,5 +60,7 @@ if namespaces:
print("}", file=out) print("}", file=out)
print("#endif", options.include_guard, file=out)
out.close() out.close()
...@@ -361,7 +361,7 @@ Eigen::Vector4f VGNodeRenderer::convColor(const Eigen::Vector4f& color) const ...@@ -361,7 +361,7 @@ Eigen::Vector4f VGNodeRenderer::convColor(const Eigen::Vector4f& color) const
if(m_linearizeSrgb) if(m_linearizeSrgb)
return Vitelotte::srgbToLinear(color); return PatateCommon::srgbToLinear(color);
return color; return color;
