Commit a88b2bab authored by Nicolas Mellado's avatar Nicolas Mellado
Use extra warning with g++ only
parent 8ed390a6
...@@ -81,7 +81,9 @@ endif(DOXYGEN_FOUND) ...@@ -81,7 +81,9 @@ endif(DOXYGEN_FOUND)
# enable extra warnings # enable extra warnings
list( APPEND CMAKE_CXX_FLAGS "-Wall -Wpedantic -Wextra -Wdouble-promotion ${CMAKE_CXX_FLAGS}") if (CMAKE_COMPILER_IS_GNUCXX)
endif (CMAKE_COMPILER_IS_GNUCXX)
set(CMAKE_MODULE_PATH ${PROJECT_SOURCE_DIR}/cmake) set(CMAKE_MODULE_PATH ${PROJECT_SOURCE_DIR}/cmake)
