Commit 93a457c3 authored by Jussi Lindgren's avatar Jussi Lindgren
Drivers: Fixed gMobilab & gUSBAmp coexistence on Windows
- Todo: Linux
parent 9d7470ff
...@@ -10,16 +10,6 @@ ...@@ -10,16 +10,6 @@
# Adds include path # Adds include path
# We have the following block to make sure gUSBAmp is not on the system. It will always override
# mobilab by default until we can figure out how to have both gUSBAmp and gMobilab drivers built
# in at the same time.
INCLUDE("FindThirdPartyGUSBampCAPI")
IF(OV_ThirdPartyGUSBAmp)
MESSAGE(STATUS " NOTE gtec USBAmp has been found, cannot have gMobilab driver in the same executable")
MESSAGE(STATUS " [ SKIP ] GMobiLabCAPI ...")
RETURN()
ENDIF(OV_ThirdPartyGUSBAmp)
IF(WIN32) IF(WIN32)
# note that the API must be 32bit with OpenViBE # note that the API must be 32bit with OpenViBE
FIND_PATH(PATH_GMobiLabCAPI GMobiLabPlus.h PATHS FIND_PATH(PATH_GMobiLabCAPI GMobiLabPlus.h PATHS
...@@ -39,7 +29,8 @@ IF(WIN32) ...@@ -39,7 +29,8 @@ IF(WIN32)
INCLUDE_DIRECTORIES(${PATH_GMobiLabCAPI}) INCLUDE_DIRECTORIES(${PATH_GMobiLabCAPI})
TARGET_LINK_LIBRARIES(${PROJECT_NAME} ${LIB_GMobiLabCAPI} ) # Do not link to the dll! Its opened runtime with dlopen()
# TARGET_LINK_LIBRARIES(${PROJECT_NAME} ${LIB_GMobiLabCAPI} )
INSTALL(PROGRAMS ${PATH_GMobiLabDLL}/gMOBIlabplus.dll DESTINATION "bin") INSTALL(PROGRAMS ${PATH_GMobiLabDLL}/gMOBIlabplus.dll DESTINATION "bin")
...@@ -48,6 +39,7 @@ IF(WIN32) ...@@ -48,6 +39,7 @@ IF(WIN32)
ELSE(PATH_GMobiLabCAPI AND PATH_GMobiLabDLL AND LIB_GMobiLabCAPI) ELSE(PATH_GMobiLabCAPI AND PATH_GMobiLabDLL AND LIB_GMobiLabCAPI)
MESSAGE(STATUS " FAILED to find GMobiLabPlusAPI + lib + dll") MESSAGE(STATUS " FAILED to find GMobiLabPlusAPI + lib + dll")
MESSAGE(STATUS " Results were ${PATH_GMobiLabCAPI} AND ${PATH_GMobiLabDLL} AND ${LIB_GMobiLabCAPI}")
ENDIF(PATH_GMobiLabCAPI AND PATH_GMobiLabDLL AND LIB_GMobiLabCAPI) ENDIF(PATH_GMobiLabCAPI AND PATH_GMobiLabDLL AND LIB_GMobiLabCAPI)
ENDIF(WIN32) ENDIF(WIN32)
...@@ -57,7 +49,8 @@ IF(UNIX) ...@@ -57,7 +49,8 @@ IF(UNIX)
MESSAGE(STATUS " Found GMobiLabPlusAPI...") MESSAGE(STATUS " Found GMobiLabPlusAPI...")
MESSAGE(STATUS " [ OK ] Third party lib ${gMOBIlabplus_LIBRARY}") MESSAGE(STATUS " [ OK ] Third party lib ${gMOBIlabplus_LIBRARY}")
ADD_DEFINITIONS(-DTARGET_HAS_ThirdPartyGMobiLabPlusAPI) ADD_DEFINITIONS(-DTARGET_HAS_ThirdPartyGMobiLabPlusAPI)
TARGET_LINK_LIBRARIES(${PROJECT_NAME} ${gMOBIlabplus_LIBRARY} ) # Do not link to the dll! Its opened runtime with dlopen()
# TARGET_LINK_LIBRARIES(${PROJECT_NAME} ${gMOBIlabplus_LIBRARY} )
ELSE(gMOBIlabplus_LIBRARY) ELSE(gMOBIlabplus_LIBRARY)
MESSAGE(STATUS " FAILED to find GMobiLabPlusAPI... (optional)") MESSAGE(STATUS " FAILED to find GMobiLabPlusAPI... (optional)")
MESSAGE(STATUS " : If it should be found, see that 'gmobilabapi.so' link exists on the fs, with no numeric suffixes in the filename.") MESSAGE(STATUS " : If it should be found, see that 'gmobilabapi.so' link exists on the fs, with no numeric suffixes in the filename.")
...@@ -4,12 +4,6 @@ ...@@ -4,12 +4,6 @@
IF(OV_ThirdPartyGMobilab)
MESSAGE(STATUS " NOTE gtec Mobilab has already been found, cannot have gUSBAmp driver in the same executable")
MESSAGE(STATUS " [ SKIP ] gUSBBampCAPI...")
RETURN()
ENDIF(OV_ThirdPartyGMobilab)
IF(WIN32) IF(WIN32)
FIND_PATH(PATH_GUSBampCAPI gUSBamp.h PATHS FIND_PATH(PATH_GUSBampCAPI gUSBamp.h PATHS
"C:/Program Files/gtec/gUSBampCAPI/API" "C:/Program Files/gtec/gUSBampCAPI/API"
...@@ -42,6 +42,7 @@ CDriverGTecGMobiLabPlus::CDriverGTecGMobiLabPlus(IDriverContext& rDriverContext) ...@@ -42,6 +42,7 @@ CDriverGTecGMobiLabPlus::CDriverGTecGMobiLabPlus(IDriverContext& rDriverContext)
,m_ui32SampleCountPerSentBlock(0) ,m_ui32SampleCountPerSentBlock(0)
,m_pSample(NULL) ,m_pSample(NULL)
,m_bTestMode(false) ,m_bTestMode(false)
,m_pLibrary(NULL)
m_rDriverContext.getLogManager() << LogLevel_Trace << "CDriverGTecGMobiLabPlus::CDriverGTecGMobiLabPlus\n"; m_rDriverContext.getLogManager() << LogLevel_Trace << "CDriverGTecGMobiLabPlus::CDriverGTecGMobiLabPlus\n";
...@@ -82,6 +83,7 @@ CDriverGTecGMobiLabPlus::~CDriverGTecGMobiLabPlus(void) ...@@ -82,6 +83,7 @@ CDriverGTecGMobiLabPlus::~CDriverGTecGMobiLabPlus(void)
void CDriverGTecGMobiLabPlus::release(void) void CDriverGTecGMobiLabPlus::release(void)
m_rDriverContext.getLogManager() << LogLevel_Trace << "CDriverGTecGMobiLabPlus::release\n"; m_rDriverContext.getLogManager() << LogLevel_Trace << "CDriverGTecGMobiLabPlus::release\n";
delete this; delete this;
...@@ -133,6 +135,38 @@ boolean CDriverGTecGMobiLabPlus::configure(void) ...@@ -133,6 +135,38 @@ boolean CDriverGTecGMobiLabPlus::configure(void)
//___________________________________________________________________// //___________________________________________________________________//
boolean CDriverGTecGMobiLabPlus::registerLibraryFunctions(void)
// Lets open the DLL
m_pLibrary = LoadLibrary("gMOBIlabplus.dll");
if (!m_pLibrary)
m_rDriverContext.getLogManager() << LogLevel_Error << "CDriverGTecGMobiLabPlus:: Unable to open gMOBIlabplus.dll\n";
return false;
m_fOpenDevice = (OV_GT_OpenDevice)GetProcAddress(m_pLibrary, "GT_OpenDevice");
m_fCloseDevice = (OV_GT_CloseDevice)GetProcAddress(m_pLibrary, "GT_CloseDevice");
m_fSetTestmode = (OV_GT_SetTestmode)GetProcAddress(m_pLibrary, "GT_SetTestmode");
m_fStartAcquisition = (OV_GT_StartAcquisition)GetProcAddress(m_pLibrary, "GT_StartAcquisition");
m_fGetData = (OV_GT_GetData)GetProcAddress(m_pLibrary, "GT_GetData");
m_fInitChannels = (OV_GT_InitChannels)GetProcAddress(m_pLibrary, "GT_InitChannels");
m_fStopAcquisition = (OV_GT_StopAcquisition)GetProcAddress(m_pLibrary, "GT_StopAcquisition");
m_fGetLastError = (OV_GT_GetLastError)GetProcAddress(m_pLibrary, "GT_GetLastError");
m_fTranslateErrorCode = (OV_GT_TranslateErrorCode)GetProcAddress(m_pLibrary, "GT_TranslateErrorCode");
if (!m_fOpenDevice || !m_fCloseDevice || !m_fSetTestmode
|| !m_fStartAcquisition || !m_fGetData || !m_fInitChannels
|| !m_fStopAcquisition || !m_fGetLastError || !m_fTranslateErrorCode)
m_rDriverContext.getLogManager() << LogLevel_Error << "CDriverGTecGMobiLabPlus:: Unable to find all the required functions from the gMOBIlabplus.dll\n";
return false;
return true;
* initialisation * initialisation
...@@ -152,6 +186,11 @@ boolean CDriverGTecGMobiLabPlus::initialize(const uint32 ui32SampleCountPerSentB ...@@ -152,6 +186,11 @@ boolean CDriverGTecGMobiLabPlus::initialize(const uint32 ui32SampleCountPerSentB
return false; return false;
if (!registerLibraryFunctions())
return false;
uint32 l_ui32ChannelCount = m_pHeader->getChannelCount(); uint32 l_ui32ChannelCount = m_pHeader->getChannelCount();
// analog exchanges allowed on the first "l_ui32CHannelCount" channels: // analog exchanges allowed on the first "l_ui32CHannelCount" channels:
...@@ -189,13 +228,18 @@ boolean CDriverGTecGMobiLabPlus::initialize(const uint32 ui32SampleCountPerSentB ...@@ -189,13 +228,18 @@ boolean CDriverGTecGMobiLabPlus::initialize(const uint32 ui32SampleCountPerSentB
// available header information // available header information
// from it // from it
#if defined(TARGET_OS_Windows) #if defined(TARGET_OS_Windows)
m_oDevice=::GT_OpenDevice((LPSTR)m_oPortName.c_str()); m_oDevice = m_fOpenDevice((LPSTR)m_oPortName.c_str());
#else #else
m_oDevice=::GT_OpenDevice(m_oPortName.c_str()); m_oDevice=::GT_OpenDevice(m_oPortName.c_str());
#endif #endif
if(m_oDevice==0) if(m_oDevice==0)
m_rDriverContext.getLogManager() << LogLevel_Error << "Unable to connect to [" << m_oPortName.c_str() << "]\n"; UINT l_uErrorCode = 0;
_ERRSTR l_sErrorString;
m_fGetLastError(&l_uErrorCode);
m_fTranslateErrorCode(&l_sErrorString, l_uErrorCode);
m_rDriverContext.getLogManager() << LogLevel_Error << "Unable to connect to [" << m_oPortName.c_str() << "], error code " << l_uErrorCode << ", " << l_sErrorString.Error << "\n";
delete [] m_oBuffer.pBuffer; delete [] m_oBuffer.pBuffer;
delete [] m_pSample; delete [] m_pSample;
...@@ -209,15 +253,18 @@ boolean CDriverGTecGMobiLabPlus::initialize(const uint32 ui32SampleCountPerSentB ...@@ -209,15 +253,18 @@ boolean CDriverGTecGMobiLabPlus::initialize(const uint32 ui32SampleCountPerSentB
boolean CDriverGTecGMobiLabPlus::uninitialize(void) boolean CDriverGTecGMobiLabPlus::uninitialize(void)
boolean l_bOk = true;
m_rDriverContext.getLogManager() << LogLevel_Trace << "CDriverGTecGMobiLabPlus::uninitialize\n"; m_rDriverContext.getLogManager() << LogLevel_Trace << "CDriverGTecGMobiLabPlus::uninitialize\n";
if(!m_rDriverContext.isConnected()) { return false; } if(!m_rDriverContext.isConnected()) { return false; }
if(m_rDriverContext.isStarted()) { return false; } if(m_rDriverContext.isStarted()) { return false; }
// uninitializes hardware here // uninitializes hardware here
if (!::GT_CloseDevice(m_oDevice)) if (!m_fCloseDevice(m_oDevice))
return false; m_rDriverContext.getLogManager() << LogLevel_Error << "GT_CloseDevice() failed\n";
l_bOk = false;
// frees memory // frees memory
...@@ -238,7 +285,13 @@ boolean CDriverGTecGMobiLabPlus::uninitialize(void) ...@@ -238,7 +285,13 @@ boolean CDriverGTecGMobiLabPlus::uninitialize(void)
m_oAnalogIn.ain7 = false; m_oAnalogIn.ain7 = false;
m_oAnalogIn.ain8 = false; m_oAnalogIn.ain8 = false;
return true; if (m_pLibrary)
FreeLibrary(m_pLibrary);
m_pLibrary = NULL;
return l_bOk;
const IHeader* CDriverGTecGMobiLabPlus::getHeader(void) const IHeader* CDriverGTecGMobiLabPlus::getHeader(void)
...@@ -272,17 +325,17 @@ boolean CDriverGTecGMobiLabPlus::start(void) ...@@ -272,17 +325,17 @@ boolean CDriverGTecGMobiLabPlus::start(void)
l_oDigitalInOut.dio8_enable = false; l_oDigitalInOut.dio8_enable = false;
// channel initialisation // channel initialisation
if(!::GT_InitChannels(m_oDevice, m_oAnalogIn, l_oDigitalInOut)) if(!m_fInitChannels(m_oDevice, m_oAnalogIn, l_oDigitalInOut))
m_rDriverContext.getLogManager() << LogLevel_Trace << "GT_InitChannels failed\n"; m_rDriverContext.getLogManager() << LogLevel_Trace << "GT_InitChannels failed\n";
// are we interested in test signal? // are we interested in test signal?
GT_SetTestmode(m_oDevice, m_bTestMode); m_fSetTestmode(m_oDevice, m_bTestMode);
// requests hardware to start sending data // requests hardware to start sending data
if(!::GT_StartAcquisition(m_oDevice)) if(!m_fStartAcquisition(m_oDevice))
m_rDriverContext.getLogManager() << LogLevel_Trace << "GT_StartAcquisition failed\n"; m_rDriverContext.getLogManager() << LogLevel_Trace << "GT_StartAcquisition failed\n";
...@@ -306,7 +359,7 @@ boolean CDriverGTecGMobiLabPlus::loop(void) ...@@ -306,7 +359,7 @@ boolean CDriverGTecGMobiLabPlus::loop(void)
for(i=0 ; i<m_ui32SampleCountPerSentBlock ; i++) for(i=0 ; i<m_ui32SampleCountPerSentBlock ; i++)
if (!::GT_GetData(m_oDevice, &m_oBuffer, &m_oOverlap))// receive samples from hardware (one per channel) if (!m_fGetData(m_oDevice, &m_oBuffer, &m_oOverlap))// receive samples from hardware (one per channel)
m_rDriverContext.getLogManager() << LogLevel_Error << "GT_GetData failed\n"; m_rDriverContext.getLogManager() << LogLevel_Error << "GT_GetData failed\n";
...@@ -350,7 +403,7 @@ boolean CDriverGTecGMobiLabPlus::stop(void) ...@@ -350,7 +403,7 @@ boolean CDriverGTecGMobiLabPlus::stop(void)
if(!m_rDriverContext.isStarted()) { return false; } if(!m_rDriverContext.isStarted()) { return false; }
// requests the hardware to stop sending data // requests the hardware to stop sending data
if(!::GT_StopAcquisition(m_oDevice)) if(!m_fStopAcquisition(m_oDevice))
m_rDriverContext.getLogManager() << LogLevel_Trace << "GT_StopAcquisition failed\n"; m_rDriverContext.getLogManager() << LogLevel_Trace << "GT_StopAcquisition failed\n";
...@@ -81,6 +81,37 @@ namespace OpenViBEAcquisitionServer ...@@ -81,6 +81,37 @@ namespace OpenViBEAcquisitionServer
private: private:
void allowAnalogInputs(OpenViBE::uint32 ui32ChannelIndex); void allowAnalogInputs(OpenViBE::uint32 ui32ChannelIndex);
// Register the function pointers from the dll. (The dll approach
// is used with gMobilab to avoid conflicts with the gUSBAmp lib)
OpenViBE::boolean registerLibraryFunctions(void);
// These gtec function calls are found from the dll library
typedef HANDLE(__stdcall *OV_GT_OpenDevice)(LPSTR lpPort);
typedef BOOL(__stdcall *OV_GT_CloseDevice)(HANDLE hDevice);
typedef BOOL(__stdcall *OV_GT_SetTestmode)(HANDLE hDevice, BOOL Testmode);
typedef BOOL(__stdcall *OV_GT_StartAcquisition)(HANDLE hDevice);
typedef BOOL(__stdcall *OV_GT_GetData)(HANDLE hDevice, _BUFFER_ST *buffer, LPOVERLAPPED lpOvl);
typedef BOOL(__stdcall *OV_GT_InitChannels)(HANDLE hDevice, _AIN analogCh, _DIO digitalCh);
typedef BOOL(__stdcall *OV_GT_StopAcquisition)(HANDLE hDevice);
typedef BOOL(__stdcall *OV_GT_GetLastError)(UINT * LastError);
typedef BOOL(__stdcall *OV_GT_TranslateErrorCode)(_ERRSTR *ErrorString, UINT ErrorCode);
OV_GT_OpenDevice m_fOpenDevice;
OV_GT_CloseDevice m_fCloseDevice;
OV_GT_SetTestmode m_fSetTestmode;
OV_GT_StartAcquisition m_fStartAcquisition;
OV_GT_GetData m_fGetData;
OV_GT_InitChannels m_fInitChannels;
OV_GT_StopAcquisition m_fStopAcquisition;
OV_GT_GetLastError m_fGetLastError;
OV_GT_TranslateErrorCode m_fTranslateErrorCode;
HINSTANCE m_pLibrary;
#elif defined(TARGET_OS_Linux)
void* m_pLibrary;
#endif
