Commit 0d6656d5 authored by MONSEIGNE Thibaut's avatar MONSEIGNE Thibaut
Fix: Clean CTest file without empty directory...
parent 21dcfd60
...@@ -20,43 +20,27 @@ set(ENV{OV_TEST_DEPLOY_PATH} "${CTEST_SOURCE_DIRECTORY}/local-tmp/test-deploy/") ...@@ -20,43 +20,27 @@ set(ENV{OV_TEST_DEPLOY_PATH} "${CTEST_SOURCE_DIRECTORY}/local-tmp/test-deploy/")
# subdirs command is deprecated and should be replaced by add_subdirectory calls as per the documentation recommendations, # subdirs command is deprecated and should be replaced by add_subdirectory calls as per the documentation recommendations,
# however the 2 command do not have the same behavior with ctest. Doing the change currently breaks tests. # however the 2 command do not have the same behavior with ctest. Doing the change currently breaks tests.
subdirs("${CTEST_SOURCE_DIRECTORY}/contrib/plugins/server-extensions/tcp-tagging/test") subdirs("${CTEST_SOURCE_DIRECTORY}/contrib/plugins/server-extensions/tcp-tagging/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/acquisition/test") #subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/acquisition/test") # No tests here
subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/turbofieldtrip/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/tools/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/vrpn/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/stimulation/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/feature-extraction/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/signal-processing/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/simple-visualization/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/file-io/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/data-generation/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/examples/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/classification/test") subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/classification/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/stream-codecs/test") subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/data-generation/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/python/test") #subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/dll-bridge/test") # No tests here
subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/streaming/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/matlab/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/evaluation/test") subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/evaluation/test")
#subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/examples/test") # No tests here
#subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/matlab/test") # No tests here
#subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/network-io/test") # No tests here
subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/riemannian/test") subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/riemannian/test")
#subdirs("${CTEST_SOURCE_DIRECTORY}/applications/external-stimulation-connection-example/test") subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/signal-processing/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/applications/platform/acquisition-server/test") subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/simple-visualization/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/applications/platform/designer/test") subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/stimulation/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/applications/demos/ssvep-demo/test") #subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/streaming/test") # No tests here
#subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/tests/test") # No tests here
#subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/tools/test") # No tests here
#subdirs("${CTEST_SOURCE_DIRECTORY}/plugins/processing/vrpn/test") # No tests here
#subdirs("${CTEST_SOURCE_DIRECTORY}/applications/platform/acquisition-server/test") # No tests here
#subdirs("${CTEST_SOURCE_DIRECTORY}/applications/demos/ssvep-demo/test") # No tests here
subdirs("${CTEST_SOURCE_DIRECTORY}/applications/demos/vr-demo/test") subdirs("${CTEST_SOURCE_DIRECTORY}/applications/demos/vr-demo/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/applications/developer-tools/id-generator/test") #subdirs("${CTEST_SOURCE_DIRECTORY}/applications/developer-tools/plugin-inspector/test") # No tests here
subdirs("${CTEST_SOURCE_DIRECTORY}/applications/developer-tools/skeleton-generator/test") #subdirs("${CTEST_SOURCE_DIRECTORY}/applications/developer-tools/skeleton-generator/test") # No tests here
subdirs("${CTEST_SOURCE_DIRECTORY}/applications/developer-tools/vrpn-simulator/test") #subdirs("${CTEST_SOURCE_DIRECTORY}/applications/developer-tools/vrpn-simulator/test") # No tests here
subdirs("${CTEST_SOURCE_DIRECTORY}/applications/developer-tools/plugin-inspector/test") #subdirs("${CTEST_SOURCE_DIRECTORY}/documentation/test") # No tests here
subdirs("${CTEST_SOURCE_DIRECTORY}/toolkit/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/scenarios/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/openvibe/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/kernel/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/modules/xml/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/modules/automaton/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/modules/stream/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/modules/ebml/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/modules/socket/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/modules/fs/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/modules/system/test")
subdirs("${CTEST_SOURCE_DIRECTORY}/scripts/software/tmp/vrpn/java_vrpn/test")
