Commit e2d905d4 authored by Jussi Lindgren's avatar Jussi Lindgren
Plugins: Fixed issue with stimulation params of the Matlab box
parent cf973945
...@@ -263,6 +263,10 @@ boolean CBoxAlgorithmMatlabScripting::initialize(void) ...@@ -263,6 +263,10 @@ boolean CBoxAlgorithmMatlabScripting::initialize(void)
this->getLogManager() << LogLevel_Trace << "Matlab Path '" << m_sMatlabPath << "' added to Windows PATH environment variable.\n"; this->getLogManager() << LogLevel_Trace << "Matlab Path '" << m_sMatlabPath << "' added to Windows PATH environment variable.\n";
else
this->getLogManager() << LogLevel_Trace << "No need to add matlab to PATH\n";
#endif #endif
if(!OpenMatlabEngineSafely()) return false; if(!OpenMatlabEngineSafely()) return false;
...@@ -370,7 +374,7 @@ boolean CBoxAlgorithmMatlabScripting::initialize(void) ...@@ -370,7 +374,7 @@ boolean CBoxAlgorithmMatlabScripting::initialize(void)
uint64 l_oStimCode = FSettingValueAutoCast(*this->getBoxAlgorithmContext(),i); uint64 l_oStimCode = FSettingValueAutoCast(*this->getBoxAlgorithmContext(),i);
stringstream ss1; stringstream ss1;
ss1 << l_oStimCode; ss1 << l_oStimCode;
l_sSettingValues = l_sSettingValues + CString(ss1.str().c_str()); l_sSettingValues = l_sSettingValues + CString(ss1.str().c_str()) + CString(" ");
// we keep the stimulation codes as doubles, to be able to put them in arrays with other doubles (such as timings). // we keep the stimulation codes as doubles, to be able to put them in arrays with other doubles (such as timings).
// they are still comparable with uint64 matlab values. // they are still comparable with uint64 matlab values.
...@@ -785,14 +789,23 @@ boolean CBoxAlgorithmMatlabScripting::printOutputBufferWithFormat() ...@@ -785,14 +789,23 @@ boolean CBoxAlgorithmMatlabScripting::printOutputBufferWithFormat()
l_ssMatlabBuffer<<m_sMatlabBuffer; l_ssMatlabBuffer<<m_sMatlabBuffer;
if(l_ssMatlabBuffer.str().size()>0) if(l_ssMatlabBuffer.str().size()>0)
size_t l_oErrorIndex=l_ssMatlabBuffer.str().find("??? "); const size_t l_oErrorIndex1 = l_ssMatlabBuffer.str().find("??? ");
if(l_oErrorIndex==std::string::npos) const size_t l_oErrorIndex2 = l_ssMatlabBuffer.str().find("Error: ");
const size_t l_oErrorIndex3 = l_ssMatlabBuffer.str().find("Error ");
// Find the earliest error message
size_t l_oErrorIndex = std::string::npos;
if (l_oErrorIndex == std::string::npos || (l_oErrorIndex1 != std::string::npos && l_oErrorIndex1 < l_oErrorIndex))
l_oErrorIndex=l_ssMatlabBuffer.str().find("Error: "); l_oErrorIndex = l_oErrorIndex1;
if(l_oErrorIndex==std::string::npos) if (l_oErrorIndex == std::string::npos || (l_oErrorIndex2 != std::string::npos && l_oErrorIndex2 < l_oErrorIndex))
l_oErrorIndex = l_oErrorIndex2;
if (l_oErrorIndex == std::string::npos || (l_oErrorIndex3 != std::string::npos && l_oErrorIndex3 < l_oErrorIndex))
l_oErrorIndex=l_ssMatlabBuffer.str().find("Error in "); l_oErrorIndex = l_oErrorIndex3;
size_t l_oWarningIndex=l_ssMatlabBuffer.str().find("Warning: "); size_t l_oWarningIndex=l_ssMatlabBuffer.str().find("Warning: ");
