Commit c54a641a authored by Jussi Lindgren's avatar Jussi Lindgren
Tests: Added Shrinkage LDA tests to the build automation
parent 9bcc53ec
...@@ -12,6 +12,8 @@ ELSE(WIN32) ...@@ -12,6 +12,8 @@ ELSE(WIN32)
SET(OV_LOGFILE "$ENV{HOME}/.config/openvibe/log/openvibe-designer.log") SET(OV_LOGFILE "$ENV{HOME}/.config/openvibe/log/openvibe-designer.log")
ENDIF(WIN32) ENDIF(WIN32)
# Misc classifier tests
SET(TEST_SCENARIOS LDA-Native-Test LDA-OneVsOne-HT-Test LDA-OneVsOne-PKPD-Test LDA-OneVsOne-Voting-Test LDA-OneVsAll-Test sLDA-Native-Test sLDA-OneVsOne-HT-Test sLDA-OneVsOne-PKPD-Test sLDA-OneVsOne-Voting-Test sLDA-OneVsAll-Test SVM-Native-Test SVM-OneVsOne-Voting-Test SVM-OneVsOne-HT-Test SVM-OneVsOne-PKPD-Test SVM-OneVsAll-Test MLP-Native-Test MLP-OneVsOne-Voting-Test MLP-OneVsOne-HT-Test MLP-OneVsOne-PKPD-Test MLP-OneVsAll-Test) SET(TEST_SCENARIOS LDA-Native-Test LDA-OneVsOne-HT-Test LDA-OneVsOne-PKPD-Test LDA-OneVsOne-Voting-Test LDA-OneVsAll-Test sLDA-Native-Test sLDA-OneVsOne-HT-Test sLDA-OneVsOne-PKPD-Test sLDA-OneVsOne-Voting-Test sLDA-OneVsAll-Test SVM-Native-Test SVM-OneVsOne-Voting-Test SVM-OneVsOne-HT-Test SVM-OneVsOne-PKPD-Test SVM-OneVsAll-Test MLP-Native-Test MLP-OneVsOne-Voting-Test MLP-OneVsOne-HT-Test MLP-OneVsOne-PKPD-Test MLP-OneVsAll-Test)
FOREACH(TEST_NAME ${TEST_SCENARIOS}) FOREACH(TEST_NAME ${TEST_SCENARIOS})
...@@ -37,3 +39,30 @@ FOREACH(TEST_NAME ${TEST_SCENARIOS}) ...@@ -37,3 +39,30 @@ FOREACH(TEST_NAME ${TEST_SCENARIOS})
ENDFOREACH(TEST_NAME) ENDFOREACH(TEST_NAME)
# Shrinkage LDA tests. These are in a different block as they use different data (and miss ProcessorBox part)
SET(TEST_SCENARIOS shrinkage_lda shrinkage_lda_rot)
SET(TEST_THRESHOLD 80)
SET(SCENARIO_TO_TEST "shrinkageLDA/${TEST_NAME}.xml")
ADD_TEST(clean_Classification_${TEST_NAME} rm -f ${OV_LOGFILE})
ADD_TEST(run_Classification_${TEST_NAME} "$ENV{OV_BINARY_PATH}/openvibe-designer.${EXT}" ${OS_FLAGS} "--no-gui" "--no-session-management" "--config" "$ENV{OV_BINARY_PATH}/share/openvibe/kernel/openvibe_test.conf" "--play-fast" ${SCENARIO_TO_TEST})
ADD_TEST(compare_Classification_${TEST_NAME} "$ENV{OV_BINARY_PATH}/test_accuracy.${EXT}" "${OS_FLAGS}" "${OV_LOGFILE}" "${TEST_THRESHOLD}")
# It would be better to clean last, but we can't do this as it will delete the
# output we wish to include, and we can't prevent clean from running if a prev. test fails
# We need the clean to be sure that the comparator stage is not getting data from a previous run.
SET_TESTS_PROPERTIES(run_Classification_${TEST_NAME} PROPERTIES DEPENDS clean_Classification_${TEST_NAME})
SET_TESTS_PROPERTIES(run_Classification_${TEST_NAME} PROPERTIES ATTACHED_FILES_ON_FAIL ${OV_LOGFILE})
SET_TESTS_PROPERTIES(compare_Classification_${TEST_NAME} PROPERTIES DEPENDS run_Classification_${TEST_NAME})
SET_TESTS_PROPERTIES(compare_Classification_${TEST_NAME} PROPERTIES ATTACHED_FILES_ON_FAIL ${OV_LOGFILE})
SET_TESTS_PROPERTIES(run_Classification_${TEST_NAME}_ProcessorBox PROPERTIES DEPENDS run_Classification_${TEST_NAME})
SET_TESTS_PROPERTIES(run_Classification_${TEST_NAME}_ProcessorBox PROPERTIES ATTACHED_FILES_ON_FAIL ${OV_LOGFILE})
\ No newline at end of file
