Commit b8c02436 authored by Jussi Lindgren's avatar Jussi Lindgren
Build: Various tweaks
- Especially made the Ogre finding on Linux less selective
parent 945693d3
...@@ -173,9 +173,6 @@ IF(UNIX) ...@@ -173,9 +173,6 @@ IF(UNIX)
SET(SKIP_PLUGINS_PROCESSING_MATLAB "1") SET(SKIP_PLUGINS_PROCESSING_MATLAB "1")
ENDIF(UNIX) ENDIF(UNIX)
# Currently empty module
SET(SKIP_CONTRIB_PLUGINS_PROCESSING_CLASSIFICATION "1")
#SET(SKIP_MODULES_AUTOMATON "1") #SET(SKIP_MODULES_AUTOMATON "1")
#SET(SKIP_MODULES_EBML "1") #SET(SKIP_MODULES_EBML "1")
#SET(SKIP_MODULES_FS "1") #SET(SKIP_MODULES_FS "1")
...@@ -43,5 +43,5 @@ ELSE(LIB_EmotivAPI) ...@@ -43,5 +43,5 @@ ELSE(LIB_EmotivAPI)
ENDIF(LIB_EmotivAPI) ENDIF(LIB_EmotivAPI)
ELSE(PATH_EmotivAPI) ELSE(PATH_EmotivAPI)
MESSAGE(STATUS " FAILED to find Emotiv API") MESSAGE(STATUS " FAILED to find Emotiv API (optional)")
ENDIF(PATH_EmotivAPI) ENDIF(PATH_EmotivAPI)
...@@ -59,7 +59,7 @@ IF(UNIX) ...@@ -59,7 +59,7 @@ IF(UNIX)
ADD_DEFINITIONS(-DTARGET_HAS_ThirdPartyGMobiLabPlusAPI) ADD_DEFINITIONS(-DTARGET_HAS_ThirdPartyGMobiLabPlusAPI)
TARGET_LINK_LIBRARIES(${PROJECT_NAME} ${gMOBIlabplus_LIBRARY} ) TARGET_LINK_LIBRARIES(${PROJECT_NAME} ${gMOBIlabplus_LIBRARY} )
ELSE(gMOBIlabplus_LIBRARY) ELSE(gMOBIlabplus_LIBRARY)
MESSAGE(STATUS " FAILED to find GMobiLabPlusAPI... ") MESSAGE(STATUS " FAILED to find GMobiLabPlusAPI... (optional)")
MESSAGE(STATUS " : If it should be found, see that 'gmobilabapi.so' link exists on the fs, with no numeric suffixes in the filename.") MESSAGE(STATUS " : If it should be found, see that 'gmobilabapi.so' link exists on the fs, with no numeric suffixes in the filename.")
MESSAGE(STATUS " : e.g. do 'cd /usr/lib/ ; ln -s libgmobilabplusapi.so.1.12 libgmobilabplusapi.so' ") MESSAGE(STATUS " : e.g. do 'cd /usr/lib/ ; ln -s libgmobilabplusapi.so.1.12 libgmobilabplusapi.so' ")
ENDIF(gMOBIlabplus_LIBRARY) ENDIF(gMOBIlabplus_LIBRARY)
...@@ -35,7 +35,7 @@ IF(WIN32) ...@@ -35,7 +35,7 @@ IF(WIN32)
SET(OV_ThirdPartyGUSBAmp "YES") SET(OV_ThirdPartyGUSBAmp "YES")
ELSE(PATH_GUSBampCAPI) ELSE(PATH_GUSBampCAPI)
MESSAGE(STATUS " FAILED to find gUSBampCAPI") MESSAGE(STATUS " FAILED to find gUSBampCAPI (optional)")
ENDIF(PATH_GUSBampCAPI) ENDIF(PATH_GUSBampCAPI)
ENDIF(WIN32) ENDIF(WIN32)
...@@ -49,10 +49,10 @@ IF(UNIX) ...@@ -49,10 +49,10 @@ IF(UNIX)
MESSAGE(STATUS " [ OK ] Third party lib ${gUSBAmpLinux_LIBRARY}") MESSAGE(STATUS " [ OK ] Third party lib ${gUSBAmpLinux_LIBRARY}")
ADD_DEFINITIONS(-DTARGET_HAS_ThirdPartyGUSBampCAPI_Linux) ADD_DEFINITIONS(-DTARGET_HAS_ThirdPartyGUSBampCAPI_Linux)
TARGET_LINK_LIBRARIES(${PROJECT_NAME} ${gUSBAmpLinux_LIBRARY} ) TARGET_LINK_LIBRARIES(${PROJECT_NAME} ${gUSBAmpLinux_LIBRARY} )
ELSE(gUSBAmpLinux_LIBRARY) ELSE(gUSBAmpLinux_LIBRARY)
MESSAGE(STATUS " FAILED to find GUSBAmpAPI Linux... ") MESSAGE(STATUS " FAILED to find GUSBAmpAPI Linux... (optional)")
MESSAGE(STATUS " : If it should be found, see that 'libgusbampapi.so.1.14' link exists on the fs, with no further nemeric suffixes in the filename.") MESSAGE(STATUS " : If it should be found, see that 'libgusbampapi.so.1.14' link exists on the fs, with no further nemeric suffixes in the filename.")
MESSAGE(STATUS " : e.g. do 'cd /usr/lib/ ; ln -s libgusbampapi.so.1.14'. See gtec-bcilab/README for details.") MESSAGE(STATUS " : e.g. do 'cd /usr/lib/ ; ln -s libgusbampapi.so.1.14'. See gtec-bcilab/README for details.")
ENDIF(gUSBAmpLinux_LIBRARY) ENDIF(gUSBAmpLinux_LIBRARY)
...@@ -46,7 +46,7 @@ ENDIF(WIN32) ...@@ -46,7 +46,7 @@ ENDIF(WIN32)
IF(UNIX) IF(UNIX)
INCLUDE("FindThirdPartyPkgConfig") INCLUDE("FindThirdPartyPkgConfig")
pkg_check_modules(Ogre3D OGRE<=1.8.1) pkg_check_modules(Ogre3D OGRE)
pkg_check_modules(OIS OIS) pkg_check_modules(OIS OIS)
...@@ -31,5 +31,5 @@ IF(WIN32) ...@@ -31,5 +31,5 @@ IF(WIN32)
IF(UNIX) IF(UNIX)
MESSAGE(STATUS "The ThinkGear API for Neurosky MindSet is only available on windows.") MESSAGE(STATUS " Skipped ThinkGear API for Neurosky MindSet, only available on windows.")
PROJECT(openvibe-plugins-contrib-classification)
SET(PROJECT_VERSION_MAJOR ${OV_GLOBAL_VERSION_MAJOR}) # fill this once there is a contribution to this category...
SET(PROJECT_VERSION_MINOR ${OV_GLOBAL_VERSION_MINOR})
SET(PROJECT_VERSION_PATCH ${OV_GLOBAL_VERSION_PATCH})
SET(PROJECT_VERSION ${PROJECT_VERSION_MAJOR}.${PROJECT_VERSION_MINOR}.${PROJECT_VERSION_PATCH})
FILE(GLOB_RECURSE source_files src/*.cpp src/*.h src/*.inl)
ADD_LIBRARY(${PROJECT_NAME} SHARED ${source_files})
SET_TARGET_PROPERTIES(${PROJECT_NAME} PROPERTIES
VERSION ${PROJECT_VERSION}
SOVERSION ${PROJECT_VERSION_MAJOR}
COMPILE_FLAGS "-DOV_Exports -DOV_Shared")
INCLUDE("FindOpenViBE")
INCLUDE("FindOpenViBECommon")
# INCLUDE("FindOpenViBEToolkit")
# INCLUDE("FindOpenViBEModuleEBML")
# INCLUDE("FindOpenViBEModuleSystem")
# INCLUDE("FindThirdPartyITPP")
# INCLUDE("FindOpenViBEModuleXML")#for gragient descent lda
# Target macros
# Defines target operating system
# Defines target architecture
# Defines target compiler
IF(WIN32)
ADD_DEFINITIONS(-D_CRT_SECURE_NO_DEPRECATE)
ADD_DEFINITIONS(-DTARGET_OS_Windows)
ADD_DEFINITIONS(-DTARGET_ARCHITECTURE_i386)
ADD_DEFINITIONS(-DTARGET_COMPILER_VisualStudio)
ENDIF(WIN32)
IF(UNIX)
# ADD_DEFINITIONS(-fvisibility=hidden) # This flag should be present... man gcc
ADD_DEFINITIONS(-g)
ADD_DEFINITIONS(-fnon-call-exceptions)
ADD_DEFINITIONS(-DTARGET_OS_Linux)
ADD_DEFINITIONS(-DTARGET_COMPILER_GCC)
ENDIF(UNIX)
# Install files
INSTALL(TARGETS ${PROJECT_NAME}
RUNTIME DESTINATION ${CMAKE_INSTALL_FULL_BINDIR}
LIBRARY DESTINATION ${CMAKE_INSTALL_FULL_LIBDIR}
ARCHIVE DESTINATION ${CMAKE_INSTALL_FULL_LIBDIR})
#INSTALL(DIRECTORY src/ DESTINATION ${CMAKE_INSTALL_FULL_INCLUDEDIR} FILES_MATCHING PATTERN "*.h" PATTERN ".svn" EXCLUDE PATTERN "doc" EXCLUDE)
