Commit b1e4dce2 authored by Jussi Lindgren's avatar Jussi Lindgren
Plugins: Code cleanup of the xDAWN box
Addresses Mantis #154
+ Added some const specifiers
parent c0c03246
...@@ -3,6 +3,7 @@ ...@@ -3,6 +3,7 @@
#include "ovpCBoxAlgorithmXDAWNSpatialFilterTrainer.h" #include "ovpCBoxAlgorithmXDAWNSpatialFilterTrainer.h"
#include <system/ovCMemory.h> #include <system/ovCMemory.h>
#include <openvibe/ovITimeArithmetics.h>
#include <complex> #include <complex>
#include <sstream> #include <sstream>
...@@ -198,7 +199,10 @@ boolean CBoxAlgorithmXDAWNSpatialFilterTrainer::process(void) ...@@ -198,7 +199,10 @@ boolean CBoxAlgorithmXDAWNSpatialFilterTrainer::process(void)
m_pSignalDecoder.decode(i); m_pSignalDecoder.decode(i);
if(m_pSignalDecoder.isHeaderReceived()) if(m_pSignalDecoder.isHeaderReceived())
for(it=l_vSignalChunk.begin(); it!=l_vSignalChunk.end(); it++) delete it->m_pMatrix; for(it=l_vSignalChunk.begin(); it!=l_vSignalChunk.end(); it++)
l_vSignalChunk.clear(); l_vSignalChunk.clear();
l_bIsContinuous=true; l_bIsContinuous=true;
...@@ -208,7 +212,7 @@ boolean CBoxAlgorithmXDAWNSpatialFilterTrainer::process(void) ...@@ -208,7 +212,7 @@ boolean CBoxAlgorithmXDAWNSpatialFilterTrainer::process(void)
if(m_pSignalDecoder.isBufferReceived()) if(m_pSignalDecoder.isBufferReceived())
IMatrix* ip_pMatrix = m_pSignalDecoder.getOutputMatrix(); const IMatrix* ip_pMatrix = m_pSignalDecoder.getOutputMatrix();
SChunk l_oChunk; SChunk l_oChunk;
l_oChunk.m_ui64StartTime=l_rDynamicBoxContext.getInputChunkStartTime(1, i); l_oChunk.m_ui64StartTime=l_rDynamicBoxContext.getInputChunkStartTime(1, i);
l_oChunk.m_ui64EndTime=l_rDynamicBoxContext.getInputChunkEndTime(1, i); l_oChunk.m_ui64EndTime=l_rDynamicBoxContext.getInputChunkEndTime(1, i);
...@@ -240,12 +244,15 @@ boolean CBoxAlgorithmXDAWNSpatialFilterTrainer::process(void) ...@@ -240,12 +244,15 @@ boolean CBoxAlgorithmXDAWNSpatialFilterTrainer::process(void)
m_pEvokedPotentialDecoder.decode(i); m_pEvokedPotentialDecoder.decode(i);
for(it=l_vEvokedPotential.begin(); it!=l_vEvokedPotential.end(); it++) delete it->m_pMatrix; for(it=l_vEvokedPotential.begin(); it!=l_vEvokedPotential.end(); it++)
l_vEvokedPotential.clear(); l_vEvokedPotential.clear();
if(m_pEvokedPotentialDecoder.isBufferReceived()) if(m_pEvokedPotentialDecoder.isBufferReceived())
IMatrix* ip_pMatrix = m_pEvokedPotentialDecoder.getOutputMatrix(); const IMatrix* ip_pMatrix = m_pEvokedPotentialDecoder.getOutputMatrix();
l_oChunk.m_ui64StartTime=l_rDynamicBoxContext.getInputChunkStartTime(2, i); l_oChunk.m_ui64StartTime=l_rDynamicBoxContext.getInputChunkStartTime(2, i);
l_oChunk.m_ui64EndTime=l_rDynamicBoxContext.getInputChunkEndTime(2, i); l_oChunk.m_ui64EndTime=l_rDynamicBoxContext.getInputChunkEndTime(2, i);
...@@ -299,18 +306,18 @@ boolean CBoxAlgorithmXDAWNSpatialFilterTrainer::process(void) ...@@ -299,18 +306,18 @@ boolean CBoxAlgorithmXDAWNSpatialFilterTrainer::process(void)
this->getLogManager() << LogLevel_Trace << "Converting OpenViBE matrices to IT++ matrices...\n"; this->getLogManager() << LogLevel_Trace << "Converting OpenViBE matrices to IT++ matrices...\n";
uint32 l_ui32ChunkCount=l_vSignalChunk.size(); const uint32 l_ui32ChunkCount=l_vSignalChunk.size();
uint32 l_ui32ChannelCount=l_vSignalChunk.begin()->m_pMatrix->getDimensionSize(0); const uint32 l_ui32ChannelCount=l_vSignalChunk.begin()->m_pMatrix->getDimensionSize(0);
uint32 l_ui32SampleCountPerChunk=l_vSignalChunk.begin()->m_pMatrix->getDimensionSize(1); const uint32 l_ui32SampleCountPerChunk=l_vSignalChunk.begin()->m_pMatrix->getDimensionSize(1);
uint32 l_ui32SampleCountPerERP=l_oAveragedERPMatrixOV.getDimensionSize(1); const uint32 l_ui32SampleCountPerERP=l_oAveragedERPMatrixOV.getDimensionSize(1);
uint64 l_ui64SignalStartTime=l_vSignalChunk.begin()->m_ui64StartTime; const uint64 l_ui64SignalStartTime=l_vSignalChunk.begin()->m_ui64StartTime;
uint64 l_ui64SignalEndTime=l_vSignalChunk.rbegin()->m_ui64EndTime; const uint64 l_ui64SignalEndTime=l_vSignalChunk.rbegin()->m_ui64EndTime;
itpp::mat l_oSignalMatrix(l_ui32ChannelCount, l_ui32ChunkCount*l_ui32SampleCountPerChunk); itpp::mat l_oSignalMatrix(l_ui32ChannelCount, l_ui32ChunkCount*l_ui32SampleCountPerChunk);
it=l_vSignalChunk.begin(); it=l_vSignalChunk.begin();
for(uint32 i=0; it!=l_vSignalChunk.end(); it++, i++) for(uint32 i=0; it!=l_vSignalChunk.end(); it++, i++)
itpp::mat l_oMatrix=itppext::convert(*it->m_pMatrix); const itpp::mat l_oMatrix=itppext::convert(*it->m_pMatrix);
l_oSignalMatrix.set_submatrix(0, i*l_ui32SampleCountPerChunk, l_oMatrix); l_oSignalMatrix.set_submatrix(0, i*l_ui32SampleCountPerChunk, l_oMatrix);
...@@ -321,8 +328,10 @@ boolean CBoxAlgorithmXDAWNSpatialFilterTrainer::process(void) ...@@ -321,8 +328,10 @@ boolean CBoxAlgorithmXDAWNSpatialFilterTrainer::process(void)
l_oDMatrix.clear(); l_oDMatrix.clear();
for(it=l_vEvokedPotential.begin(); it!=l_vEvokedPotential.end(); it++) for(it=l_vEvokedPotential.begin(); it!=l_vEvokedPotential.end(); it++)
uint64 l_ui64ERPStartTime=it->m_ui64StartTime; // Compute index of the sample corresponding to the start of the ERP
uint32 l_ui32ERPStartIndex=(uint32)(((l_ui64ERPStartTime-l_ui64SignalStartTime)*(l_ui32SampleCountPerChunk*l_ui32ChunkCount))/(l_ui64SignalEndTime-l_ui64SignalStartTime)); const uint64 l_ui64ERPStartTime = it->m_ui64StartTime;
const uint32 l_ui32ERPStartIndex = static_cast<uint32>(ITimeArithmetics::timeToSampleCount(m_pSignalDecoder.getOutputSamplingRate(), l_ui64ERPStartTime));
for(uint32 k=0; k<l_ui32SampleCountPerERP; k++) for(uint32 k=0; k<l_ui32SampleCountPerERP; k++)
l_oDMatrix(l_ui32ERPStartIndex+k,k)=1; l_oDMatrix(l_ui32ERPStartIndex+k,k)=1;
...@@ -347,14 +356,14 @@ boolean CBoxAlgorithmXDAWNSpatialFilterTrainer::process(void) ...@@ -347,14 +356,14 @@ boolean CBoxAlgorithmXDAWNSpatialFilterTrainer::process(void)
this->getLogManager() << LogLevel_Info << l_oSignalMatrix.rows() << "x" << l_oSignalMatrix.cols() << "\n"; this->getLogManager() << LogLevel_Info << l_oSignalMatrix.rows() << "x" << l_oSignalMatrix.cols() << "\n";
#endif #endif
itpp::mat A=(l_oAveragedERPMatrix*itpp::inv(l_oDMatrix.transpose()*l_oDMatrix)*l_oAveragedERPMatrix.transpose()) * double(l_vEvokedPotential.size()) / double(l_ui32SampleCountPerChunk*l_ui32ChunkCount); const itpp::mat A=(l_oAveragedERPMatrix*itpp::inv(l_oDMatrix.transpose()*l_oDMatrix)*l_oAveragedERPMatrix.transpose()) * double(l_vEvokedPotential.size()) / double(l_ui32SampleCountPerChunk*l_ui32ChunkCount);
#if 1 #if 1
std::stringstream s4; std::stringstream s4;
s4 << "A :\n" << A << "\n"; s4 << "A :\n" << A << "\n";
this->getLogManager() << LogLevel_Debug << s4.str().c_str() << "\n"; this->getLogManager() << LogLevel_Debug << s4.str().c_str() << "\n";
#endif #endif
itpp::mat B=(l_oSignalMatrix*l_oSignalMatrix.transpose()) / double(l_ui32SampleCountPerChunk*l_ui32ChunkCount); const itpp::mat B=(l_oSignalMatrix*l_oSignalMatrix.transpose()) / double(l_ui32SampleCountPerChunk*l_ui32ChunkCount);
#if 1 #if 1
std::stringstream s5; std::stringstream s5;
s5 << "B :\n" << B << "\n"; s5 << "B :\n" << B << "\n";
...@@ -389,7 +398,7 @@ boolean CBoxAlgorithmXDAWNSpatialFilterTrainer::process(void) ...@@ -389,7 +398,7 @@ boolean CBoxAlgorithmXDAWNSpatialFilterTrainer::process(void)
std::map < double, itpp::vec >::const_reverse_iterator it = l_vEigenVector.rbegin(); std::map < double, itpp::vec >::const_reverse_iterator it = l_vEigenVector.rbegin();
uint32 l_ui32Cnt=0; uint32 l_ui32Cnt=0;
//We need to compute the size of the first dimension before setting the matrix //We need to compute the size of the first dimension before setting the matrix
uint32 l_ui32Dimension1Size = l_vEigenVector.size() < static_cast<uint32>(m_ui64FilterDimension)?l_vEigenVector.size():static_cast<uint32>(m_ui64FilterDimension); const uint32 l_ui32Dimension1Size = l_vEigenVector.size() < static_cast<uint32>(m_ui64FilterDimension)?l_vEigenVector.size():static_cast<uint32>(m_ui64FilterDimension);
CMatrix l_oOutputVectors; CMatrix l_oOutputVectors;
l_oOutputVectors.setDimensionCount(2); l_oOutputVectors.setDimensionCount(2);
