Commit 8a0e632c authored by nfoy's avatar nfoy
prevent compilation from failing because of test_tagstream
parent cebe2718
...@@ -7,7 +7,7 @@ SET(source_files "${source_files};${additional_source_files}") ...@@ -7,7 +7,7 @@ SET(source_files "${source_files};${additional_source_files}")
SET(ADDITIONAL_PATH "${CMAKE_SOURCE_DIR}/contrib/plugins/server-extensions/tcp-tagging/") SET(ADDITIONAL_PATH "${CMAKE_SOURCE_DIR}/contrib/plugins/server-extensions/tcp-tagging/")
INCLUDE_DIRECTORIES(${ADDITIONAL_PATH}) INCLUDE_DIRECTORIES(${ADDITIONAL_PATH})
FILE(GLOB_RECURSE additional_source_files ${ADDITIONAL_PATH}/*.cpp ${ADDITIONAL_PATH}/*.h) FILE(GLOB additional_source_files ${ADDITIONAL_PATH}/*.cpp ${ADDITIONAL_PATH}/*.h)
SET(source_files "${source_files};${additional_source_files}") SET(source_files "${source_files};${additional_source_files}")
FUNCTION(OV_ADD_CONTRIB_DRIVER DRIVER_PATH) FUNCTION(OV_ADD_CONTRIB_DRIVER DRIVER_PATH)
ADD_TEST(run_test_tagstream "$ENV{OV_BINARY_PATH}/test_tagstream")
