Commit 71c61d56 authored by Jussi Lindgren's avatar Jussi Lindgren
Plugins: Made TCP Tagging a bit more quiet by default
parent 588bfc63
......@@ -242,11 +242,11 @@ void CPluginTCPTagging::loopHook(std::vector < std::vector < OpenViBE::float32 >
// Collect tags from the stream until exhaustion.
while(tagStream.pop(tag)) {
m_rKernelContext.getLogManager() << Kernel::LogLevel_Info << "New Tag received (" << tag.padding << ", " << tag.identifier << ", " << tag.timestamp << ") at " << posixTime << " (posix time in ms)\n";
m_rKernelContext.getLogManager() << Kernel::LogLevel_Trace << "New Tag received (" << tag.padding << ", " << tag.identifier << ", " << tag.timestamp << ") at " << posixTime << " (posix time in ms)\n";
// Check that the timestamp fits the current chunk.
if (tag.timestamp < m_previousPosixTime) {
m_rKernelContext.getLogManager() << Kernel::LogLevel_Warning << "The Tag has arrived before the beginning of the current chunk and will be inserted at the beginning of this chunk\n";
m_rKernelContext.getLogManager() << Kernel::LogLevel_Trace << "The Tag has arrived before the beginning of the current chunk and will be inserted at the beginning of this chunk\n";
tag.timestamp = m_previousPosixTime;
Supports Markdown
