Commit 37f186d3 authored by nfoy's avatar nfoy
fix compilation warning on Fedora21 due to deprecated Ogre function call
parent 6171d7ce
...@@ -1443,7 +1443,7 @@ Ogre::String DotSceneLoader::getProperty(const Ogre::String &ndNm, const Ogre::S ...@@ -1443,7 +1443,7 @@ Ogre::String DotSceneLoader::getProperty(const Ogre::String &ndNm, const Ogre::S
void DotSceneLoader::processUserDataReference(rapidxml::xml_node<>* XMLNode, Ogre::Entity *pEntity) void DotSceneLoader::processUserDataReference(rapidxml::xml_node<>* XMLNode, Ogre::Entity *pEntity)
Ogre::String str = XMLNode->first_attribute("id")->value(); Ogre::String str = XMLNode->first_attribute("id")->value();
pEntity->setUserAny(Ogre::Any(str)); pEntity->getUserObjectBindings().setUserAny(Ogre::Any(str));
#endif #endif
