Commit 193cded3 authored by Jussi Lindgren's avatar Jussi Lindgren
plugins/processing/matlab:
 * Fixed path processing bug of the Matlab scripting box preventing Matlab launch on Linux
 * Changed the Matlab boxes and scenarios to ask for the Matlab executable instead of the setting being platform-specific (although on Windows, giving just the path works too, hence this change should be compatible with older Matlab-box using scenarios).
 * Fixed some compilation warnings
 * Deprecated the Matlab filter box. Please use the scripting box instead.
modules/fs:
 + Added a function to get the parent path of a path
cmake-modules:
 * Fixed the alternative way to detect Matlab on Linux and added support for upper-case MATLAB folder (2013a default install does this, for example)
parent 4ba94200
...@@ -17,9 +17,18 @@ IF(UNIX OR WIN32) ...@@ -17,9 +17,18 @@ IF(UNIX OR WIN32)
# Alternative way to try to find matlab # Alternative way to try to find matlab
FILE(GLOB_RECURSE Executable_Candidates "/usr/local/matlab*/matlab") FILE(GLOB_RECURSE Executable_Candidates "/usr/local/matlab*/matlab")
IF(Executable_Candidates) IF(Executable_Candidates)
LIST(GET Executable_Candidates 1 Matlab_EXECUTABLE) LIST(GET Executable_Candidates 0 Matlab_EXECUTABLE)
ENDIF(Executable_Candidates) ENDIF(Executable_Candidates)
ENDIF(UNIX AND NOT Matlab_EXECUTABLE) ENDIF(UNIX AND NOT Matlab_EXECUTABLE)
# Alternative way 2 to try to find matlab
FILE(GLOB_RECURSE Executable_Candidates "/usr/local/MATLAB*/matlab")
IF(Matlab_EXECUTABLE) IF(Matlab_EXECUTABLE)
GET_FILENAME_COMPONENT(Matlab_ROOT ${Matlab_EXECUTABLE} PATH) GET_FILENAME_COMPONENT(Matlab_ROOT ${Matlab_EXECUTABLE} PATH)
SET(Matlab_ROOT ${Matlab_ROOT}/..) SET(Matlab_ROOT ${Matlab_ROOT}/..)
...@@ -71,4 +80,4 @@ IF(Matlab_FOUND) ...@@ -71,4 +80,4 @@ IF(Matlab_FOUND)
ENDIF(Matlab_LIB_FOUND) ENDIF(Matlab_LIB_FOUND)
ELSE(Matlab_FOUND) ELSE(Matlab_FOUND)
MESSAGE(STATUS " FAILED to find Matlab...") MESSAGE(STATUS " FAILED to find Matlab...")
ENDIF(Matlab_FOUND) ENDIF(Matlab_FOUND)
\ No newline at end of file
...@@ -16,6 +16,9 @@ namespace FS ...@@ -16,6 +16,9 @@ namespace FS
static FS::boolean createPath(const char* sPath); static FS::boolean createPath(const char* sPath);
// Creates all components of a path to the filesystem except the last part (i.e. for paths including a filename in the end) // Creates all components of a path to the filesystem except the last part (i.e. for paths including a filename in the end)
static FS::boolean createParentPath(const char* sPath); static FS::boolean createParentPath(const char* sPath);
// Returns a path omitting the last part of it (essentially boost::filesystem::parent_path). Output sParentPath needs to be pre-allocated.
static FS::boolean getParentPath(const char *sPath, char *sParentPath);
private: private:
Files(void); Files(void);
...@@ -158,3 +158,14 @@ bool Files::createParentPath(const char *sPath) ...@@ -158,3 +158,14 @@ bool Files::createParentPath(const char *sPath)
return boost::filesystem::create_directories(boost::filesystem::path(sPath).parent_path()); return boost::filesystem::create_directories(boost::filesystem::path(sPath).parent_path());
bool Files::getParentPath(const char *sPath, char *sParentPath)
if(!sPath || !sParentPath) {
return false;
strcpy(sParentPath, boost::filesystem::path(sPath).parent_path().string().c_str());
return true;
...@@ -100,9 +100,9 @@ ...@@ -100,9 +100,9 @@
</Setting> </Setting>
<Setting> <Setting>
<TypeIdentifier>(0x79a9edeb, 0x245d83fc)</TypeIdentifier> <TypeIdentifier>(0x79a9edeb, 0x245d83fc)</TypeIdentifier>
<Name>Path to Matlab Executables</Name> <Name>Matlab executable (path)</Name>
<DefaultValue>C:/Program Files (x86)/MATLAB/R2011b/bin/win32</DefaultValue> <DefaultValue>C:/Program Files (x86)/MATLAB/R2011b/bin/win32/matlab.exe</DefaultValue>
<Value>C:/Program Files (x86)/MATLAB/R2011b/bin/win32</Value> <Value>C:/Program Files (x86)/MATLAB/R2011b/bin/win32/matlab.exe</Value>
<Setting> <Setting>
...@@ -495,7 +495,7 @@ ...@@ -495,7 +495,7 @@
<Identifier>(0x000037be, 0x000071f3)</Identifier> <Identifier>(0x000037be, 0x000071f3)</Identifier>
<Text>&lt;b&gt;Configure the Matlab Scripting box:&lt;/b&gt; <Text>&lt;b&gt;Configure the Matlab Scripting box:&lt;/b&gt;
&lt;span color=&quot;red&quot;&gt; Set the matlab installation directory before use !&lt;/span&gt; &lt;span color=&quot;red&quot;&gt; Set the matlab executable path before use !&lt;/span&gt;
Enter the path to your local Matlab installation. Enter the path to your local Matlab installation.
...@@ -601,4 +601,4 @@ The documentation page for this tutorial is available at: ...@@ -601,4 +601,4 @@ The documentation page for this tutorial is available at:
<NumChildren>0</NumChildren> <NumChildren>0</NumChildren>
</VisualisationWidget> </VisualisationWidget>
</VisualisationTree> </VisualisationTree>
</OpenViBE-Scenario> </OpenViBE-Scenario>
...@@ -293,9 +293,9 @@ ...@@ -293,9 +293,9 @@
<Setting> <Setting>
<Setting> <Setting>
...@@ -672,8 +672,8 @@ every 2 seconds</Text> ...@@ -672,8 +672,8 @@ every 2 seconds</Text>
<Identifier>(0x000042fe, 0x00002140)</Identifier> <Identifier>(0x000042fe, 0x00002140)</Identifier>
&lt;span color=&quot;red&quot;&gt; Set the matlab installation directory &lt;span color=&quot;red&quot;&gt; Set the matlab executable path
and working directory before use !&lt;/span&gt; and the working directory before use !&lt;/span&gt;
If you want to add a sinusoid noise to the signal If you want to add a sinusoid noise to the signal
set the noise frequency and amplitude. set the noise frequency and amplitude.
...@@ -756,4 +756,4 @@ Set the frequency range for the plot scale.</Text> ...@@ -756,4 +756,4 @@ Set the frequency range for the plot scale.</Text>
...@@ -23,9 +23,9 @@ ...@@ -23,9 +23,9 @@
<Setting> <Setting>
<Setting> <Setting>
...@@ -268,8 +268,8 @@ ...@@ -268,8 +268,8 @@
<Identifier>(0x000035a5, 0x000068bb)</Identifier> <Identifier>(0x000035a5, 0x000068bb)</Identifier>
You can select the number of channels You can select the number of channels
and size of data chunk. and size of data chunk.
...@@ -354,4 +354,4 @@ The documentation page for this tutorial is available at: ...@@ -354,4 +354,4 @@ The documentation page for this tutorial is available at:
...@@ -15,6 +15,8 @@ ...@@ -15,6 +15,8 @@
#include <windows.h> #include <windows.h>
#endif #endif
#include <fs/Files.h>
#define MATLAB_BUFFER 2048 #define MATLAB_BUFFER 2048
#define m_pMatlabEngine ((Engine*)m_pMatlabEngineHandle) #define m_pMatlabEngine ((Engine*)m_pMatlabEngineHandle)
#define m_pMatlabStimulation ((mxArray*)m_pMatlabStimulationHandle) #define m_pMatlabStimulation ((mxArray*)m_pMatlabStimulationHandle)
...@@ -32,11 +34,44 @@ using namespace OpenViBEPlugins::Tools; ...@@ -32,11 +34,44 @@ using namespace OpenViBEPlugins::Tools;
#define boolean OpenViBE::boolean #define boolean OpenViBE::boolean
// Sanitizes a path so that it only has / or \ characters and has a / or \ in the end.
// @fixme should move to plugins-FS possibly
void CBoxAlgorithmMatlabFilter::sanitizePath(OpenViBE::CString &sPathToModify) const {
std::string l_oTmpPath(sPathToModify);
// Append / to end of path if its not there already
if(l_oTmpPath.length()>0)
char l_cLastChar = l_oTmpPath.at(l_oTmpPath.length()-1);
if(l_cLastChar != '\\' && l_cLastChar != '/')
l_oTmpPath = l_oTmpPath + "/";
#if defined TARGET_OS_Windows
// Convert '/' to '\'
for (size_t i=0; i < l_oTmpPath.length(); i++) {
if(l_oTmpPath[i] == '/')
l_oTmpPath[i] = '\\';
#endif
sPathToModify = OpenViBE::CString(l_oTmpPath.c_str());
boolean CBoxAlgorithmMatlabFilter::OpenMatlabEngineSafely(void) boolean CBoxAlgorithmMatlabFilter::OpenMatlabEngineSafely(void)
this->getLogManager() << LogLevel_Trace << "Trying to open Matlab engine\n"; this->getLogManager() << LogLevel_Trace << "Trying to open the Matlab engine\n";
#if defined TARGET_OS_Linux #if defined TARGET_OS_Linux
m_pMatlabEngineHandle=::engOpen(m_sMatlabPath.toASCIIString()); m_pMatlabEngineHandle=::engOpen(m_sMatlabPath.toASCIIString());
if(!m_pMatlabEngine)
this->getLogManager() << LogLevel_Error << "Could not open the Matlab engine.\n" <<
"The configured path to the matlab executable was expanded as '" << m_sMatlabPath << "'.\n";
return false;
#elif defined TARGET_OS_Windows #elif defined TARGET_OS_Windows
__try __try
...@@ -44,18 +79,20 @@ boolean CBoxAlgorithmMatlabFilter::OpenMatlabEngineSafely(void) ...@@ -44,18 +79,20 @@ boolean CBoxAlgorithmMatlabFilter::OpenMatlabEngineSafely(void)
__except(EXCEPTION_EXECUTE_HANDLER) __except(EXCEPTION_EXECUTE_HANDLER)
this->getLogManager() << LogLevel_Error << "First call to MATLAB engine failed.\n" this->getLogManager() << LogLevel_Error << "First call to the MATLAB engine failed.\n"
<< "\tTo use this box you must have MATLAB (32 bits version) installed on your computer.\n"; << "\tTo use this box you must have MATLAB (32 bits version) installed on your computer.\n";
m_pMatlabEngineHandle = NULL;
return false;
#else
#endif
if(!m_pMatlabEngine) if(!m_pMatlabEngine)
this->getLogManager() << LogLevel_Error << "Could not open Matlab engine\n"; this->getLogManager() << LogLevel_Error << "Could not open the Matlab engine.\n" <<
"The configured path to the matlab bin directory was expanded as '" << m_sMatlabPath << "'.\n";
return false; return false;
#else
this->getLogManager() << LogLevel_Error << "Only Linux and Windows are supported\n";
return false;
#endif
return true; return true;
...@@ -78,30 +115,27 @@ boolean CBoxAlgorithmMatlabFilter::initialize(void) ...@@ -78,30 +115,27 @@ boolean CBoxAlgorithmMatlabFilter::initialize(void)
ip_pMatrix.initialize(m_pStreamedMatrixEncoder->getInputParameter(OVP_GD_Algorithm_StreamedMatrixStreamEncoder_InputParameterId_Matrix)); ip_pMatrix.initialize(m_pStreamedMatrixEncoder->getInputParameter(OVP_GD_Algorithm_StreamedMatrixStreamEncoder_InputParameterId_Matrix));
m_ui64LatestStimulationChunkEndTime=0; m_ui64LatestStimulationChunkEndTime=0;
uint32 l_ui32FirstCommonIndex = 0;
getStaticBoxContext().getSettingValue(0, m_sMatlabPath); getStaticBoxContext().getSettingValue(0, m_sMatlabPath);
#if defined TARGET_OS_Windows #if defined TARGET_OS_Windows
std::string l_oTmpPath(m_sMatlabPath); if(!FS::Files::directoryExists(m_sMatlabPath) && FS::Files::fileExists(m_sMatlabPath))
// Convert '/' to '\' {
for (size_t i=0; i < l_oTmpPath.length(); i++) { // The path might be pointing to the executable, try to extract the directory
if(l_oTmpPath[i] == '/') char l_sParentPath[MAX_PATH];
{ FS::Files::getParentPath(m_sMatlabPath, l_sParentPath);
l_oTmpPath[i] = '\\'; m_sMatlabPath = OpenViBE::CString(l_sParentPath);
// Append \ to end of path if its not there already
if(l_oTmpPath.length()>0) sanitizePath(m_sMatlabPath);
this->getLogManager() << LogLevel_Trace << "Interpreting Matlab path as '" << m_sMatlabPath << "'\n";
if(!FS::Files::directoryExists(m_sMatlabPath))
char l_cLastChar = l_oTmpPath.at(l_oTmpPath.length()-1); this->getLogManager() << LogLevel_Error << "Configured Matlab path'" << m_sMatlabPath << "' does not seem to be a directory\n";
if(l_cLastChar != '\\') return false;
l_oTmpPath = l_oTmpPath + "\\";
m_sMatlabPath = OpenViBE::CString(l_oTmpPath.c_str());
char * l_sPath = getenv("PATH"); char * l_sPath = getenv("PATH");
if(l_sPath == NULL) if(l_sPath == NULL)
...@@ -54,13 +54,15 @@ namespace OpenViBEPlugins ...@@ -54,13 +54,15 @@ namespace OpenViBEPlugins
void* m_pMatlabMatrixHandle; void* m_pMatlabMatrixHandle;
void* m_pMatlabBCIContextHandle; void* m_pMatlabBCIContextHandle;
OpenViBE::CString m_sMatlabPath; OpenViBE::CString m_sMatlabPath; // On Linux, path of the executable. On Windows, the executable directory.
OpenViBE::CString m_sProcessFunction; OpenViBE::CString m_sProcessFunction;
OpenViBE::CString m_sInitializeFunction; OpenViBE::CString m_sInitializeFunction;
private: private:
OpenViBE::boolean OpenMatlabEngineSafely(void); OpenViBE::boolean OpenMatlabEngineSafely(void);
OpenViBE::boolean CloseMatlabEngineSafely(void); OpenViBE::boolean CloseMatlabEngineSafely(void);
void sanitizePath(OpenViBE::CString &sPathToModify) const;
class CBoxAlgorithmMatlabFilterDesc : virtual public OpenViBE::Plugins::IBoxAlgorithmDesc class CBoxAlgorithmMatlabFilterDesc : virtual public OpenViBE::Plugins::IBoxAlgorithmDesc
...@@ -89,9 +91,9 @@ namespace OpenViBEPlugins ...@@ -89,9 +91,9 @@ namespace OpenViBEPlugins
rBoxAlgorithmPrototype.addOutput ("Filtered streamed matrix", OV_TypeId_StreamedMatrix); rBoxAlgorithmPrototype.addOutput ("Filtered streamed matrix", OV_TypeId_StreamedMatrix);
rBoxAlgorithmPrototype.addOutput ("Stimulations", OV_TypeId_Stimulations); rBoxAlgorithmPrototype.addOutput ("Stimulations", OV_TypeId_Stimulations);
rBoxAlgorithmPrototype.addSetting("Matlab launch command", OV_TypeId_String, "[ssh user@host] /path/to/matlab"); rBoxAlgorithmPrototype.addSetting("Matlab executable (path)", OV_TypeId_String, "[ssh user@host] /path/to/matlab");
rBoxAlgorithmPrototype.addSetting("Path to Matlab Executable", OV_TypeId_String, "C:/Program Files (x86)/MATLAB/R2011b/bin/win32"); rBoxAlgorithmPrototype.addSetting("Matlab executable (path)", OV_TypeId_String, "C:/Program Files (x86)/MATLAB/R2011b/bin/win32/matlab.exe");
#else #else
#endif #endif
rBoxAlgorithmPrototype.addSetting("Matlab working directory", OV_TypeId_String, "${__volatile_ScenarioDir}"); rBoxAlgorithmPrototype.addSetting("Matlab working directory", OV_TypeId_String, "${__volatile_ScenarioDir}");
...@@ -99,6 +101,7 @@ namespace OpenViBEPlugins ...@@ -99,6 +101,7 @@ namespace OpenViBEPlugins
rBoxAlgorithmPrototype.addSetting("Process function", OV_TypeId_String, "bci_Process"); rBoxAlgorithmPrototype.addSetting("Process function", OV_TypeId_String, "bci_Process");
rBoxAlgorithmPrototype.addFlag(OpenViBE::Kernel::BoxFlag_IsUnstable); rBoxAlgorithmPrototype.addFlag(OpenViBE::Kernel::BoxFlag_IsUnstable);
rBoxAlgorithmPrototype.addFlag(OpenViBE::Kernel::BoxFlag_IsDeprecated);
...@@ -92,9 +92,15 @@ boolean CBoxAlgorithmMatlabScripting::checkFailureRoutine(boolean bResult, const ...@@ -92,9 +92,15 @@ boolean CBoxAlgorithmMatlabScripting::checkFailureRoutine(boolean bResult, const
boolean CBoxAlgorithmMatlabScripting::OpenMatlabEngineSafely(void) boolean CBoxAlgorithmMatlabScripting::OpenMatlabEngineSafely(void)
return false;
__try __try
...@@ -106,13 +112,18 @@ boolean CBoxAlgorithmMatlabScripting::OpenMatlabEngineSafely(void) ...@@ -106,13 +112,18 @@ boolean CBoxAlgorithmMatlabScripting::OpenMatlabEngineSafely(void)
m_pMatlabEngineHandle = NULL; m_pMatlabEngineHandle = NULL;
#endif
char l_sMatlabDirectory[MAX_PATH];
FS::Files::getParentPath(m_sMatlabPath, l_sMatlabDirectory);
this->getLogManager() << LogLevel_Error << "Could not open the Matlab engine.\n" << this->getLogManager() << LogLevel_Error << "Could not open the Matlab engine.\n" <<
"The path in the box configuration was interpreted as '" << m_sMatlabPath << "'.\n"; "The matlab binary path was reasoned to be '" << l_sMatlabDirectory << "'.\n";
#else
return false;
#endif
...@@ -226,24 +237,30 @@ boolean CBoxAlgorithmMatlabScripting::initialize(void) ...@@ -226,24 +237,30 @@ boolean CBoxAlgorithmMatlabScripting::initialize(void)
getStaticBoxContext().getSettingValue(1, m_sMatlabPath); getStaticBoxContext().getSettingValue(1, m_sMatlabPath);
this->getLogManager() << LogLevel_Trace << "Interpreting Matlab path as '" << m_sMatlabPath << "'\n"; #if defined TARGET_OS_Windows
if(!FS::Files::directoryExists(m_sMatlabPath)) if(!FS::Files::directoryExists(m_sMatlabPath))
this->getLogManager() << LogLevel_Error << "Problem with Matlab path '" << m_sMatlabPath << "'\n"; this->getLogManager() << LogLevel_Error << "Configured Matlab path '" << m_sMatlabPath << "' does not seem to be a directory\n";
this->getLogManager() << LogLevel_Error << "Could not access the environment variable PATH to add Matlab.\n"; this->getLogManager() << LogLevel_Error << "Could not access the environment variable PATH to add Matlab path to it.\n";
string l_sStrPath = string(l_sPath); string l_sStrPath = string(l_sPath);
...@@ -49,7 +49,7 @@ namespace OpenViBEPlugins ...@@ -49,7 +49,7 @@ namespace OpenViBEPlugins
CMatlabHelper m_oMatlabHelper; CMatlabHelper m_oMatlabHelper;
OpenViBE::CString m_sUninitializeFunction; OpenViBE::CString m_sUninitializeFunction;
...@@ -123,9 +123,13 @@ namespace OpenViBEPlugins ...@@ -123,9 +123,13 @@ namespace OpenViBEPlugins
rBoxAlgorithmPrototype.addSetting("Box clock frequency in Hz", OV_TypeId_Integer, "64"); rBoxAlgorithmPrototype.addSetting("Box clock frequency in Hz", OV_TypeId_Integer, "64");
rBoxAlgorithmPrototype.addSetting("Path to Matlab Executables", OV_TypeId_String, "C:/Program Files (x86)/MATLAB/R2011b/bin/win32"); // On Windows, the executable is not actually used, but its path is parsed from it and added to PATH.
// Background: Matlab's engOpen() takes a different argument on Windows and on Linux. On Windows, we need to have Matlab
// on PATH, in Linux we need to provide a full path of the executable. However, we'd like our example scenarios to give
// correct instructions to the user on both platforms, hence we use a setting that contains the information for both use-cases.
#else #else
#endif #endif
...@@ -103,7 +103,7 @@ boolean CMatlabHelper::setSignalInputHeader(uint32 ui32InputIndex, IMatrix * pMa ...@@ -103,7 +103,7 @@ boolean CMatlabHelper::setSignalInputHeader(uint32 ui32InputIndex, IMatrix * pMa
sprintf(l_sBuffer, "%i",pMatrix->getDimensionSize(1)); sprintf(l_sBuffer, "%i",pMatrix->getDimensionSize(1));
l_sCommand = l_sCommand + CString(l_sBuffer) + CString(","); l_sCommand = l_sCommand + CString(l_sBuffer) + CString(",");
l_sCommand = l_sCommand + CString("{")+ l_sLabelList + CString("},"); l_sCommand = l_sCommand + CString("{")+ l_sLabelList + CString("},");
sprintf(l_sBuffer, "%i",ui64SamplingRate); sprintf(l_sBuffer, "%i",(int)ui64SamplingRate);
l_sCommand = l_sCommand + CString(l_sBuffer)+ CString(");"); l_sCommand = l_sCommand + CString(l_sBuffer)+ CString(");");
return engEvalString(m_pMatlabEngine, (const char *) l_sCommand) == 0; return engEvalString(m_pMatlabEngine, (const char *) l_sCommand) == 0;
...@@ -474,7 +474,7 @@ boolean CMatlabHelper::getChannelLocalisationOutputHeader(uint32 ui32OutputIndex ...@@ -474,7 +474,7 @@ boolean CMatlabHelper::getChannelLocalisationOutputHeader(uint32 ui32OutputIndex
mxArray * l_pDynamic = ::engGetVariable(m_pMatlabEngine,"OV_DYNAMIC"); mxArray * l_pDynamic = ::engGetVariable(m_pMatlabEngine,"OV_DYNAMIC");
uint32 l_ui32NbChannels = (uint32) *mxGetPr(l_pNbChannels); uint32 l_ui32NbChannels = (uint32) *mxGetPr(l_pNbChannels);
boolean l_ui32Dynamic = ((uint32) *mxGetPr(l_pDynamic) == 1); // boolean l_ui32Dynamic = ((uint32) *mxGetPr(l_pDynamic) == 1);
mwSize l_oNbCells = mxGetNumberOfElements(l_pNames); mwSize l_oNbCells = mxGetNumberOfElements(l_pNames);
char ** l_pNameList = new char*[l_oNbCells]; char ** l_pNameList = new char*[l_oNbCells];
for(uint32 cell = 0; cell < l_oNbCells; cell++) for(uint32 cell = 0; cell < l_oNbCells; cell++)
