Commit e7de8a20 authored by JONGLEZ Baptiste's avatar JONGLEZ Baptiste
Regenerate ReST README
parent 82bed9ed
1 merge request!7Improve SSL user experience on Grid'5000
...@@ -88,9 +88,10 @@ conform with the Grid5000 API models (with an ’s’!) ...@@ -88,9 +88,10 @@ conform with the Grid5000 API models (with an ’s’!)
password: MYPASSWORD password: MYPASSWORD
' > ~/.python-grid5000.yaml ' > ~/.python-grid5000.yaml
- When accessing the API from a Grid’5000 frontend, providing the username and - When accessing the API from a Grid’5000 frontend, providing the username
password is optionnal. Nevertheless you’ll need to deal with SSL verification and password is optionnal. Authentication should work out-of-the-box; if
by specifying the path to the certificate to use: it fails, try updating python-grid5000, or specify the path to the
certificate to use:
...@@ -614,51 +615,7 @@ connected to other testbeds for experiments involving wide area layer2 networks. ...@@ -614,51 +615,7 @@ connected to other testbeds for experiments involving wide area layer2 networks.
5.8 Metrics API 5.8 Metrics API
5.8.1 Get the timeseries corresponding to a job 5.8.1 Get some timeseries (and plot them)
Credits to ``lturpin``.
.. code:: python
import logging
import os
from grid5000 import Grid5000
logging.basicConfig(level=logging.DEBUG)
def get_job_consumption(job_id, gk, site):
metrics = gk.sites[site].metrics
job = gk.sites[site].jobs[job_id]
# nodes as list : "cluster-number.site.grid5000.fr"
nodes_dom = job.assigned_nodes
# nodes as list : "cluster-number"
nodes = map(lambda node_dom: node_dom.split('.')[0], nodes_dom)
# nodes as string : "cluster-number,cluster-number,..."
nodes_str = ','.join(nodes)
start = job.started_at
end = job.stopped_at
kwargs = {
"only": nodes_str,
"resolution": 1,
"from": start,
"to": end
timeseries = metrics["power"].timeseries.list(**kwargs)
return timeseries
conf_file = os.path.join(os.environ.get("HOME"), ".python-grid5000.yaml")
gk = Grid5000.from_yaml(conf_file)
timeseries = get_job_consumption("1092446", gk, "lyon")
print(timeseries)
5.8.2 Get some timeseries (and plot them)
For this example you’ll need ``matplotlib``, ``seaborn`` and ``pandas``. For this example you’ll need ``matplotlib``, ``seaborn`` and ``pandas``.
...@@ -675,45 +632,40 @@ For this example you’ll need ``matplotlib``, ``seaborn`` and ``pandas``. ...@@ -675,45 +632,40 @@ For this example you’ll need ``matplotlib``, ``seaborn`` and ``pandas``.
import seaborn as sns import seaborn as sns
import time import time
logging.basicConfig(level=logging.DEBUG) logging.basicConfig(level=logging.INFO)
conf_file = os.path.join(os.environ.get("HOME"), ".python-grid5000.yaml") conf_file = os.path.join(os.environ.get("HOME"), ".python-grid5000.yaml")
gk = Grid5000.from_yaml(conf_file) gk = Grid5000.from_yaml(conf_file)
metrics = gk.sites["lyon"].metrics metrics = gk.sites["lyon"].clusters["nova"].metrics
print("--- available metrics") print("--- available metrics")
print(metrics.list()) print(metrics)
print("---- power metric")
print(metrics["power"])
print("----- a timeserie") print("----- a timeserie")
now = time.time() now = time.time()
# NOTE that you can pass a job_id here
kwargs = { kwargs = {
"only": "nova-1,nova-2,nova-3", "nodes": "nova-1,nova-2,nova-3",
"resolution": 1, "metrics": "wattmetre_power_watt",
"from": int(now - 600), "start_time": int(now - 600),
"to": int(now)
timeseries = metrics["power"].timeseries.list(**kwargs) metrics = gk.sites["lyon"].metrics.list(**kwargs)
# let's visualize this # let's visualize this
df = pd.DataFrame() df = pd.DataFrame()
for timeserie in timeseries: for metric in metrics:
print(timeserie) timestamp = metric.timestamp
timestamp = timeserie.timestamps value = metric.value
value = timeserie.values device_id = metric.device_id
measurement = timeserie.uid
df = pd.concat([df, pd.DataFrame({ df = pd.concat([df, pd.DataFrame({
"timestamp": timestamp, "timestamp": [timestamp],
"value": value, "value": [value],
"measurement": [measurement]*len(timestamp) "device_id": [device_id]
sns.relplot(data=df, sns.relplot(data=df,
x="timestamp", x="timestamp",
y="value", y="value",
hue="measurement", hue="device_id",
kind="line") kind="line")
plt.show() plt.show()
