Verified Commit 96269849 authored by Luke Bertot's avatar Luke Bertot Committed by SIMONIN Matthieu
Support for trusted client with Grid’5000
Internal certificate. In this mode users can pass the g5k_user argument
to most calls to specify which user the API call should be made as. In
cases where g5k_user is not specified API calls will be made as the
anonymous user whose access is limited to the Grid’5000 reference API.
In this mode python-grid5000 does not store any login information, so
g5k_user must be provided explicitly provided on every call that requires
one.
parent 24c5d9ea
Branches proposed-changes2
Pipeline #120023 passed
...@@ -21,6 +21,14 @@ python3.6: ...@@ -21,6 +21,14 @@ python3.6:
- tox -e py36 - tox -e py36
- tox -e pep8 - tox -e pep8
python2.7:
image: python:2.7
stage: test
tags: [qlf-ci.inria.fr]
script:
- pip install tox
- tox -e py27 pep8
#### Entering th release zone #### Entering th release zone
pages: pages:
stage: deploy stage: deploy
...@@ -688,6 +688,56 @@ In [2]: # gk is your entry point ...@@ -688,6 +688,56 @@ In [2]: # gk is your entry point
#+END_SRC #+END_SRC
*** Using Grid'5000 client certificates
~python-grid5000~ can also be used as a trusted client with Grid'5000
internal certificate. In this mode users can pass the ~g5k_user~ argument
cases where ~g5k_user~ is not specified API calls will be made as the
~anonymous~ user whose access is limited to the Grid'5000 reference API.
In this mode ~python-grid5000~ does not store any login information, so
~g5k_user~ most be provided explicitly provided on every call that requires
one.
#+BEGIN_SRC python :exports code :tangle examples/certificate.py
import logging
from grid5000 import Grid5000
logging.basicConfig(level=logging.DEBUG)
gk = Grid5000(
uri="https://api-ext.grid5000.fr/stable/",
sslcert="/path/to/ssl/certfile.cert",
sslkey="/path/to/ssl/keyfile.key"
gk.sites.list()
job = site.jobs.create({"name": "pyg5k",
"command": "sleep 3600"},
g5k_user = "auser1")
# Since the 'anonymous' user can not inspect jobs the following call will raise exception
# python-grid5000.exceptions.Grid5000AuthenticationError: 401 Unauthorized
job.refresh()
# Both following call work since any user can request info on any jobs.
job.refresh(g5k_user='auser1')
job.refresh(g5k_user='auser2')
# Some operations can only be performed by the jobs creator.
# The following call will raise exception
# pyg5k.exceptions.Grid5000DeleteError: 403 Unauthorized
job.delete(g5k_user='auser2')
# This call works as expected
job.delete(g5k_user='auser1')
#+END_SRC
* Appendix :noexport: * Appendix :noexport:
** How to export this file ** How to export this file
...@@ -700,4 +750,3 @@ In [2]: # gk is your entry point ...@@ -700,4 +750,3 @@ In [2]: # gk is your entry point
Do ~C-c C-v t~ or ~M-x Do ~C-c C-v t~ or ~M-x
org-babel-tangle~. The scripts are available under available under ~examples~. org-babel-tangle~. The scripts are available under available under ~examples~.
...@@ -253,7 +253,7 @@ Before starting, the file ``$HOME/.python-grid5000.yaml`` will be loaded. ...@@ -253,7 +253,7 @@ Before starting, the file ``$HOME/.python-grid5000.yaml`` will be loaded.
site = gk.sites["rennes"] site = gk.sites["rennes"]
job = site.jobs.create({"name": "pyg5k", job = site.jobs.create({"name": "pyg5k",
"command": "sleep 3600"}) "command": "sleep 3600"})
while job.state != "running": while job.state != "running":
job.refresh() job.refresh()
...@@ -287,8 +287,8 @@ Before starting, the file ``$HOME/.python-grid5000.yaml`` will be loaded. ...@@ -287,8 +287,8 @@ Before starting, the file ``$HOME/.python-grid5000.yaml`` will be loaded.
"command": "sleep 3600", "command": "sleep 3600",
"types": ["deploy"]}) "types": ["deploy"]})
...@@ -298,7 +298,7 @@ Before starting, the file ``$HOME/.python-grid5000.yaml`` will be loaded. ...@@ -298,7 +298,7 @@ Before starting, the file ``$HOME/.python-grid5000.yaml`` will be loaded.
print("Assigned nodes : %s" % job.assigned_nodes) print("Assigned nodes : %s" % job.assigned_nodes)
deployment = site.deployments.create({"nodes": job.assigned_nodes, deployment = site.deployments.create({"nodes": job.assigned_nodes,
"environment": "debian9-x64-min"}) "environment": "debian9-x64-min"})
# To get SSH access to your nodes you can pass your public key # To get SSH access to your nodes you can pass your public key
# from pathlib import Path # from pathlib import Path
...@@ -358,8 +358,8 @@ Before starting, the file ``$HOME/.python-grid5000.yaml`` will be loaded. ...@@ -358,8 +358,8 @@ Before starting, the file ``$HOME/.python-grid5000.yaml`` will be loaded.
"resources": "slash_22=1+nodes=1"}) "resources": "slash_22=1+nodes=1"})
...@@ -371,8 +371,8 @@ Before starting, the file ``$HOME/.python-grid5000.yaml`` will be loaded. ...@@ -371,8 +371,8 @@ Before starting, the file ``$HOME/.python-grid5000.yaml`` will be loaded.
# create acces for all ips in the subnet # create acces for all ips in the subnet
access = site.storage["msimonin"].access.create({"ipv4": ip_network, access = site.storage["msimonin"].access.create({"ipv4": ip_network,
"termination": {"job": job.uid, "termination": {"job": job.uid,
"site": site.uid}}) "site": site.uid}})
4.7 Vlan API 4.7 Vlan API
...@@ -434,9 +434,9 @@ Before starting, the file ``$HOME/.python-grid5000.yaml`` will be loaded. ...@@ -434,9 +434,9 @@ Before starting, the file ``$HOME/.python-grid5000.yaml`` will be loaded.
"resources": "{type='kavlan'}/vlan=1+nodes=1", "resources": "{type='kavlan'}/vlan=1+nodes=1",
...@@ -444,8 +444,8 @@ Before starting, the file ``$HOME/.python-grid5000.yaml`` will be loaded. ...@@ -444,8 +444,8 @@ Before starting, the file ``$HOME/.python-grid5000.yaml`` will be loaded.
time.sleep(5) time.sleep(5)
"environment": "debian9-x64-min", "environment": "debian9-x64-min",
"vlan": job.resources_by_type["vlans"][0]}) "vlan": job.resources_by_type["vlans"][0]})
while deployment.status != "terminated": while deployment.status != "terminated":
deployment.refresh() deployment.refresh()
...@@ -485,9 +485,9 @@ Before starting, the file ``$HOME/.python-grid5000.yaml`` will be loaded. ...@@ -485,9 +485,9 @@ Before starting, the file ``$HOME/.python-grid5000.yaml`` will be loaded.
"resources": "{type='kavlan'}/vlan=1+{cluster='paranoia'}nodes=1", "resources": "{type='kavlan'}/vlan=1+{cluster='paranoia'}nodes=1",
"types": ["deploy"] "types": ["deploy"]
...@@ -555,16 +555,16 @@ For this example you’ll need ``matplotlib``, ``seaborn`` and ``pandas``. ...@@ -555,16 +555,16 @@ For this example you’ll need ``matplotlib``, ``seaborn`` and ``pandas``.
value = timeserie.values value = timeserie.values
measurement = timeserie.uid measurement = timeserie.uid
df = pd.concat([df, pd.DataFrame({ df = pd.concat([df, pd.DataFrame({
"timestamp": timestamp, "timestamp": timestamp,
"value": value, "value": value,
"measurement": [measurement]*len(timestamp) "measurement": [measurement]*len(timestamp)
sns.relplot(data=df, sns.relplot(data=df,
x="timestamp", x="timestamp",
y="value", y="value",
hue="measurement", hue="measurement",
kind="line") kind="line")
plt.show() plt.show()
4.9 More snippets 4.9 More snippets
...@@ -594,8 +594,8 @@ For this example you’ll need ``matplotlib``, ``seaborn`` and ``pandas``. ...@@ -594,8 +594,8 @@ For this example you’ll need ``matplotlib``, ``seaborn`` and ``pandas``.
candidates = site.clusters.list() candidates = site.clusters.list()
matching = [c.uid for c in candidates if c.uid in clusters] matching = [c.uid for c in candidates if c.uid in clusters]
if len(matching) == 1: if len(matching) == 1:
matches.append((site, matching[0])) matches.append((site, matching[0]))
clusters.remove(matching[0]) clusters.remove(matching[0])
print("We found the following matches %s" % matches) print("We found the following matches %s" % matches)
4.9.2 Get all job with a given name on all the sites 4.9.2 Get all job with a given name on all the sites
...@@ -625,13 +625,13 @@ For this example you’ll need ``matplotlib``, ``seaborn`` and ``pandas``. ...@@ -625,13 +625,13 @@ For this example you’ll need ``matplotlib``, ``seaborn`` and ``pandas``.
jobs = [] jobs = []
for site in sites: for site in sites:
jobs.append(job) jobs.append(job)
_jobs = [] _jobs = []
_jobs.append((site.uid, site.jobs.list(name=NAME, _jobs.append((site.uid, site.jobs.list(name=NAME,
state="waiting,launching,running"))) state="waiting,launching,running")))
print("We found %s" % _jobs) print("We found %s" % _jobs)
...@@ -674,13 +674,13 @@ cross-processes cache) and give you control on the cached object. Enough talking ...@@ -674,13 +674,13 @@ cross-processes cache) and give you control on the cached object. Enough talking
def get_api_client(): def get_api_client():
"""Gets the reference to the API cient (singleton).""" """Gets the reference to the API cient (singleton)."""
with _api_lock: with _api_lock:
global _api_client global _api_client
if not _api_client: if not _api_client:
conf_file = os.path.join(os.environ.get("HOME"), conf_file = os.path.join(os.environ.get("HOME"),
".python-grid5000.yaml") ".python-grid5000.yaml")
_api_client = Grid5000.from_yaml(conf_file) _api_client = Grid5000.from_yaml(conf_file)
return _api_client return _api_client
@ring.disk(storage) @ring.disk(storage)
...@@ -696,8 +696,8 @@ cross-processes cache) and give you control on the cached object. Enough talking ...@@ -696,8 +696,8 @@ cross-processes cache) and give you control on the cached object. Enough talking
sites = get_sites_obj() sites = get_sites_obj()
clusters = [] clusters = []
# should we cache the list aswell ? # should we cache the list aswell ?
clusters.extend(site.clusters.list()) clusters.extend(site.clusters.list())
return clusters return clusters
...@@ -710,3 +710,52 @@ cross-processes cache) and give you control on the cached object. Enough talking ...@@ -710,3 +710,52 @@ cross-processes cache) and give you control on the cached object. Enough talking
print("Calling again the function is now faster") print("Calling again the function is now faster")
clusters = get_all_clusters_obj() clusters = get_all_clusters_obj()
print(clusters) print(clusters)
4.9.4 Using Grid’5000 client certificates
``python-grid5000`` can also be used as a trusted client with Grid’5000
internal certificate. In this mode users can pass the ``g5k_user`` argument
cases where ``g5k_user`` is not specified API calls will be made as the
``anonymous`` user whose access is limited to the Grid’5000 reference API.
In this mode ``python-grid5000`` does not store any login information, so
``g5k_user`` most be provided explicitly provided on every call that requires
one.
.. code:: python
import logging
gk = Grid5000(
gk.sites.list()
job.refresh()
import logging
gk = Grid5000(
gk.sites.list()
job.refresh()
...@@ -49,17 +49,20 @@ class Grid5000(object): ...@@ -49,17 +49,20 @@ class Grid5000(object):
verify_ssl (bool); Whether SSL certificates should be validated. verify_ssl (bool); Whether SSL certificates should be validated.
timeout (float): Timeout to use for requests to the Grid5000 API. timeout (float): Timeout to use for requests to the Grid5000 API.
session (requests.Session): session to use session (requests.Session): session to use
ssl_cert (str): path to the client certificate file for Grid5000 API
ssl_key (str): path to the client key file for Grid5000 API
def __init__( def __init__(
self, self,
uri=DEFAULT_BASE_URL, uri=DEFAULT_BASE_URL,
username=None, username=None,
password=None, password=None,
verify_ssl=True, verify_ssl=True,
timeout=None, timeout=None,
session=None, session=None,
sslcert=None,
sslkey=None,
**kwargs **kwargs
self._uri = uri self._uri = uri
...@@ -68,12 +71,21 @@ class Grid5000(object): ...@@ -68,12 +71,21 @@ class Grid5000(object):
self.password = password self.password = password
self.verify_ssl = verify_ssl self.verify_ssl = verify_ssl
self.client_ssl = False
self.client_cert = None
if sslcert is not None:
self.client_ssl = True
if sslkey is not None:
self.client_cert = (sslcert, sslkey)
else:
self.client_cert = sslcert
self.headers = {"user-agent": USER_AGENT} self.headers = {"user-agent": USER_AGENT}
self.session = _create_session() self.session = _create_session()
# manage auth # manage auth
self._http_auth = None self._http_auth = None
if self.username: if self.username and not self.client_ssl:
self._http_auth = requests.auth.HTTPBasicAuth(self.username, self.password) self._http_auth = requests.auth.HTTPBasicAuth(self.username, self.password)
self.root = RootManager(self) self.root = RootManager(self)
...@@ -97,16 +109,14 @@ class Grid5000(object): ...@@ -97,16 +109,14 @@ class Grid5000(object):
return cls(**conf) return cls(**conf)
except Exception as e: except Exception as e:
logging.warn(e) logging.warn(e)
logging.info( logging.info("...Falling back to anonymous connection")
return cls() return cls()
def __enter__(self): def __enter__(self):
return self return self
def __exit__(self, *args): def __exit__(self, *args):
return self.session.cloase() return self.session.close()
def _build_url(self, path): def _build_url(self, path):
"""Returns the full url from path. """Returns the full url from path.
...@@ -122,26 +132,52 @@ class Grid5000(object): ...@@ -122,26 +132,52 @@ class Grid5000(object):
else: else:
return "%s%s" % (self._uri, path) return "%s%s" % (self._uri, path)
def _get_session_opts(self, content_type=None, accept=None): def _get_session_opts(
self, content_type=None, accept=None, user_id=None, other_headers=None
"""Returns list of option and headers to use of an http transaction
Args:
content_type (str): value of the Content-type http headers
accept (str) : value of the Accept http header
user_id (str) : Grid5000 user id to use in certificate mode
other_headers (dict) : other http headers to include
request_headers = self.headers.copy() request_headers = self.headers.copy()
if content_type is not None: if content_type is not None:
request_headers["Content-type"] = content_type request_headers["Content-type"] = content_type
if accept is not None: if accept is not None:
request_headers["Accept"] = accept request_headers["Accept"] = accept
return { res = {
"headers": request_headers, "headers": request_headers,
"auth": self._http_auth,
"timeout": self.timeout, "timeout": self.timeout,
"verify": self.verify_ssl, "verify": self.verify_ssl,
"cert": self.client_cert,
if self.client_ssl:
if user_id is not None:
request_headers["X-Api-User-CN"] = user_id
request_headers["X-Remote-Ident"] = user_id
else:
request_headers["X-Api-User-CN"] = "anonymous"
request_headers["X-Remote-Ident"] = "anonymous"
else:
res["auth"] = self._http_auth
if other_headers is not None:
request_headers.update(other_headers)
return res
def http_request( def http_request(
self, self,
verb, verb,
path, path,
query_data=None, query_data=None,
post_data=None, post_data=None,
header_data=None,
streamed=False, streamed=False,
content_type="application/json", content_type="application/json",
accept="application/json", accept="application/json",
...@@ -157,6 +193,7 @@ class Grid5000(object): ...@@ -157,6 +193,7 @@ class Grid5000(object):
query_data (dict): Data to send as query parameters query_data (dict): Data to send as query parameters
post_data (dict): Data to send in the body (will be converted to post_data (dict): Data to send in the body (will be converted to
json) json)
header_data (dict): Data to send as http headers
streamed (bool): Whether the data should be streamed streamed (bool): Whether the data should be streamed
**kwargs: Extra options to send to the server (e.g. sudo) **kwargs: Extra options to send to the server (e.g. sudo)
...@@ -169,10 +206,20 @@ class Grid5000(object): ...@@ -169,10 +206,20 @@ class Grid5000(object):
query_data = {} if query_data is None else query_data query_data = {} if query_data is None else query_data
url = self._build_url(path) url = self._build_url(path)
opts = self._get_session_opts(content_type=content_type, accept=accept) g5k_user = None
if self.client_ssl:
g5k_user = kwargs.pop("g5k_user", None)
accept=accept,
user_id=g5k_user,
other_headers=header_data,
verify = opts.pop("verify") verify = opts.pop("verify")
timeout = opts.pop("timeout") timeout = opts.pop("timeout")
cert = opts.pop("cert")
json = post_data json = post_data
data = None data = None
...@@ -186,12 +233,11 @@ class Grid5000(object): ...@@ -186,12 +233,11 @@ class Grid5000(object):
prepped = req.prepare() prepped = req.prepare()
settings = self.session.merge_environment_settings( settings = self.session.merge_environment_settings(
prepped.url, {}, streamed, verify, None prepped.url, {}, streamed, verify, cert
while True: while True:
result = self.session.send(prepped, timeout=timeout, **settings) result = self.session.send(prepped, timeout=timeout, **settings)
# TODO: # TODO:
# https://www.grid5000.fr/mediawiki/index.php/API#Status_Codes # https://www.grid5000.fr/mediawiki/index.php/API#Status_Codes
if 200 <= result.status_code < 300: if 200 <= result.status_code < 300:
...@@ -198,7 +198,7 @@ class ObjectDeleteMixin(object): ...@@ -198,7 +198,7 @@ class ObjectDeleteMixin(object):
Grid5000AuthenticationError: If authentication is not correct Grid5000AuthenticationError: If authentication is not correct
Grid5000DeleteError: If the server cannot perform the request Grid5000DeleteError: If the server cannot perform the request
self.manager.delete(self.get_id()) self.manager.delete(self.get_id(), **kwargs)
# Composite Mixins # Composite Mixins
...@@ -24,7 +24,7 @@ setup_requires = ...@@ -24,7 +24,7 @@ setup_requires =
install_requires = install_requires =
requests>=2.21 requests>=2.21
pyyaml>=5.1 pyyaml>=5.1
ipython>=7.3.0 ipython
[options.packages.find] [options.packages.find]
exclude = exclude =
