Commit 52138701 authored by Vincent Lefevre's avatar Vincent Lefevre
mpfrlint: update for git.
This is used to check that the doc/mpfr.texi UPDATED-MONTH value is
up-to-date by comparing it with the date of the latest commit.
parent 0eb14935
......@@ -501,13 +501,15 @@ fi
# Note about the TZ value: GMT0 and UTC0 are both specified by POSIX,
# and UTC0 is the preferred value, but old systems only accept GMT0.
# The "0" is important ("GMT" alone does not work on Tru64 Unix).
texisvnd=`LC_ALL=C TZ=GMT0 svn info doc/mpfr.texi 2> /dev/null | sed -n 's/Last Changed Date:.*, [0-9]* \([A-Z][a-z][a-z] [0-9][0-9][0-9][0-9]\)).*/\1/p'`
if [[ $? -eq 0 ]] && [[ -n "$texisvnd" ]] then
texidate=`sed -n 's/@set UPDATED-MONTH \([A-Z][a-z][a-z]\).*\( [0-9][0-9][0-9][0-9]\)/\1\2/p' doc/mpfr.texi`
[[ $texidate == $texisvnd ]] || { cat <<EOF && err=1 }
#texisvnd=`LC_ALL=C TZ=GMT0 svn info doc/mpfr.texi 2> /dev/null | sed -n 's/Last Changed Date:.*, [0-9]* \([A-Z][a-z][a-z] [0-9][0-9][0-9][0-9]\)).*/\1/p'`
texigitd=`LC_ALL=C TZ=GMT0 git show -s --format=%cd --date=format:"%B %Y" doc/mpfr.texi`
if [[ $? -eq 0 ]] && [[ -n "$texigitd" ]] then
#texidate=`sed -n 's/@set UPDATED-MONTH \([A-Z][a-z][a-z]\).*\( [0-9][0-9][0-9][0-9]\)/\1\2/p' doc/mpfr.texi`
texidate=`sed -n 's/^@set UPDATED-MONTH *//p' doc/mpfr.texi`
[[ $texidate == $texigitd ]] || { cat <<EOF && err=1 }
mpfr.texi's UPDATED-MONTH seems to be incorrect:
mpfr.texi's UPDATED-MONTH: $texidate
Last Changed Date in WC: $texisvnd
Last Changed Date in WC: $texigitd
EOF
fi
Supports Markdown
