GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
mpfr
mpfr
361c153b
361c153b
Vincent Lefevre
Update of INSTALL file about CompCert.
f75b0c38
INSTALL
361c153b
@@ -709,15 +709,15 @@ The relevant build projects are available here:
d. Using the CompCert compiler
this was t
ested with CompCert 3.
7
and MPFR
revision 13851
on x86_64-linux]
T
10
and MPFR
master-11992-f75b0c388
on x86_64-linux]
CompCert (http://compcert.
inria.fr
/) is a formally verified compiler.
CompCert (http
s
://compcert.
org
To compile MPFR with CompCert:
$ ./configure CC=ccomp CFLAGS="
-fbitfields
-flongdouble -fstruct-passing"
--disable-shared
$ ./configure
--disable-shared
CC=ccomp CFLAGS="-flongdouble -fstruct-passing"
You also need to unset LD_LIBRARY_PATH, and/or you might need to change
wl="" into wl="-Wl," in the libtool file.
(after running configure)
All tests (make check) should pass (tget_set_d64, tget_set_d128 and
tset_float128 are skipped, since CompCert does not support _Decimal64,
