Commit 9fbfb80d authored by Fabien Triolet's avatar Fabien Triolet
a servlet can read a file from web now.
parent b2da72c5
* $Id: CallImpl.java,v 1.2 2002-11-25 16:09:11 triolet Exp $
* $Id: CallImpl.java,v 1.3 2002-12-04 12:04:34 triolet Exp $
* Transmorpher
......@@ -205,6 +205,9 @@ public abstract class CallImpl extends Observable implements Call {
String key = (String)e.nextElement();
String val = (String)getParameters().getParameter(key);
if (((getProcess().getTransmorpher().getMain())instanceof Servlet)&&(key.equals("file"))){
if (val.startsWith("http"))
file.writeln(4,"tmParameters.setParameter(\""+ key +"\",\""+ val +"\" );");
else
file.writeln(4,"tmParameters.setParameter(\""+ key +"\",root+\""+ val +"\" );");
else
* $Id: Servlet.java,v 1.6 2002-11-25 16:09:11 triolet Exp $
* $Id: Servlet.java,v 1.7 2002-12-04 12:04:34 triolet Exp $
* Transmorpher
......@@ -180,6 +180,7 @@ public class Servlet extends MainProcess {
iFile.writeln(12,"}");
iFile.writeln(12,"else{");
iFile.writeln(14,"test=false;");
iFile.writeln(14,"break;");
iFile.writeln(10,"}");
iFile.writeln(10,"else{");
