Commit 02fa2fac authored by Jérôme Euzenat's avatar Jérôme Euzenat
Put version by default to 1.0.0
parent 5cc4fe97
<!-- $Id: build.xml,v 1.41 2002-10-30 16:41:35 triolet Exp $ --> <!-- $Id: build.xml,v 1.42 2002-11-04 08:54:28 jerome Exp $ -->
<project name="transmo" default="compile" basedir=".."> <project name="transmo" default="compile" basedir="..">
...@@ -36,7 +36,7 @@ ...@@ -36,7 +36,7 @@
<target name="init"> <target name="init">
<tstamp><format locale="fr,fr" pattern="dd/MM/yyyy" property="TODAY"/></tstamp> <tstamp><format locale="fr,fr" pattern="dd/MM/yyyy" property="TODAY"/></tstamp>
<property name="doing" value="running"/> <property name="doing" value="running"/>
<property name="version" value="0-9-10${doing}"/> <property name="version" value="1-0-0${doing}"/>
<property name="date" value="${TODAY}"/> <property name="date" value="${TODAY}"/>
<property name="login" value="triolet"/> <property name="login" value="triolet"/>
<property name="email" value="Fabien.Triolet@inrialpes.fr"/> <property name="email" value="Fabien.Triolet@inrialpes.fr"/>
