Commit fc3b64a9 authored by Jérôme Euzenat's avatar Jérôme Euzenat
- adjusted test results to new format
- introduced new test result comparison
- dealt with EDOAL (new renderer)
parent 68b6d929
* $Id$ * $Id$
* Copyright (C) INRIA, 2010 * Copyright (C) INRIA, 2009-2010
* This program is free software; you can redistribute it and/or modify * This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU Lesser General Public License as published by * it under the terms of the GNU Lesser General Public License as published by
...@@ -46,8 +46,6 @@ import fr.inrialpes.exmo.align.impl.renderer.XMLMetadataRendererVisitor; ...@@ -46,8 +46,6 @@ import fr.inrialpes.exmo.align.impl.renderer.XMLMetadataRendererVisitor;
import fr.inrialpes.exmo.align.impl.renderer.XSLTRendererVisitor; import fr.inrialpes.exmo.align.impl.renderer.XSLTRendererVisitor;
import fr.inrialpes.exmo.align.impl.method.StringDistAlignment; import fr.inrialpes.exmo.align.impl.method.StringDistAlignment;
//import fr.inrialpes.exmo.align.impl.eval.PRecEvaluator;
//import fr.inrialpes.exmo.align.impl.URIAlignment;
import java.io.ByteArrayOutputStream; import java.io.ByteArrayOutputStream;
import java.io.PrintWriter; import java.io.PrintWriter;
...@@ -67,6 +65,11 @@ public class RendererTest { ...@@ -67,6 +65,11 @@ public class RendererTest {
private AlignmentProcess alignment = null; private AlignmentProcess alignment = null;
private boolean valueSimilarTo( int obtained, int expected ) {
if ( (expected-1 <= obtained) && (obtained <= expected+1) ) return true;
else return false;
// Create the Alignement that will be rendered by everyone // Create the Alignement that will be rendered by everyone
@BeforeClass(groups = { "full", "impl", "raw" }) @BeforeClass(groups = { "full", "impl", "raw" })
private void init() throws Exception { private void init() throws Exception {
...@@ -78,6 +81,7 @@ public class RendererTest { ...@@ -78,6 +81,7 @@ public class RendererTest {
alignment.init( new URI("file:examples/rdf/edu.umbc.ebiquity.publication.owl"), new URI("file:examples/rdf/edu.mit.visus.bibtex.owl")); alignment.init( new URI("file:examples/rdf/edu.umbc.ebiquity.publication.owl"), new URI("file:examples/rdf/edu.mit.visus.bibtex.owl"));
alignment.align( (Alignment)null, params ); alignment.align( (Alignment)null, params );
assertEquals( alignment.nbCells(), 44 ); assertEquals( alignment.nbCells(), 44 );
// Suppress the time label
@Test(groups = { "full", "impl", "raw" }) @Test(groups = { "full", "impl", "raw" })
...@@ -90,7 +94,8 @@ public class RendererTest { ...@@ -90,7 +94,8 @@ public class RendererTest {
alignment.render( renderer ); alignment.render( renderer );
writer.flush(); writer.flush();
writer.close(); writer.close();
assertEquals( stream.toString().length(), 14297, "Rendered differently" ); //System.err.println( stream.toString() );
assertTrue( valueSimilarTo( stream.toString().length(), 14285 ), "Rendered differently: expected "+14285+" but was "+stream.toString().length() );
Properties params = new Properties(); Properties params = new Properties();
params.setProperty( "embedded", "1"); params.setProperty( "embedded", "1");
...@@ -105,7 +110,7 @@ public class RendererTest { ...@@ -105,7 +110,7 @@ public class RendererTest {
assertEquals( stream.toString().length(), 7478, "Rendered differently" ); assertTrue( valueSimilarTo( stream.toString().length(), 7479 ), "Rendered differently: expected "+7479+" but was "+stream.toString().length() );
stream = new ByteArrayOutputStream(); stream = new ByteArrayOutputStream();
...@@ -117,7 +122,7 @@ public class RendererTest { ...@@ -117,7 +122,7 @@ public class RendererTest {
assertEquals( stream.toString().length(), 7423, "Rendered differently" ); assertTrue( valueSimilarTo( stream.toString().length(), 7424 ), "Rendered differently: expected "+7424+" but was "+stream.toString().length() );
params.setProperty( "pre2008", "1"); params.setProperty( "pre2008", "1");
writer = new PrintWriter ( writer = new PrintWriter (
...@@ -128,7 +133,7 @@ public class RendererTest { ...@@ -128,7 +133,7 @@ public class RendererTest {
assertEquals( stream.toString().length(), 7296, "Rendered differently" ); assertTrue( valueSimilarTo( stream.toString().length(), 7297 ), "Rendered differently: expected "+7297+" but was "+stream.toString().length() );
...@@ -141,7 +146,7 @@ public class RendererTest { ...@@ -141,7 +146,7 @@ public class RendererTest {
assertEquals( stream.toString().length(), 7666, "Rendered differently" ); assertTrue( valueSimilarTo( stream.toString().length(), 7667 ), "Rendered differently: expected "+7667+" but was "+stream.toString().length() );
...@@ -155,7 +160,7 @@ public class RendererTest { ...@@ -155,7 +160,7 @@ public class RendererTest {
assertEquals( stream.toString().length(), 6551, "Rendered differently" ); assertTrue( valueSimilarTo( stream.toString().length(), 6552 ), "Rendered differently: expected "+6552+" but was "+stream.toString().length() );
...@@ -168,7 +173,7 @@ public class RendererTest { ...@@ -168,7 +173,7 @@ public class RendererTest {
assertEquals( stream.toString().length(), 21699, "Rendered differently" ); assertTrue( valueSimilarTo( stream.toString().length(), 21700 ), "Rendered differently: expected "+21700+" but was "+stream.toString().length() );
...@@ -181,7 +186,7 @@ public class RendererTest { ...@@ -181,7 +186,7 @@ public class RendererTest {
assertEquals( stream.toString().length(), 8203, "Rendered differently" ); assertTrue( valueSimilarTo( stream.toString().length(), 8204 ), "Rendered differently: expected "+8204+" but was "+stream.toString().length() );
...@@ -194,7 +199,7 @@ public class RendererTest { ...@@ -194,7 +199,7 @@ public class RendererTest {
assertEquals( stream.toString().length(), 15394, "Rendered differently" ); assertTrue( valueSimilarTo( stream.toString().length(), 15395 ), "Rendered differently: expected "+15395+" but was "+stream.toString().length() );
...@@ -207,7 +212,8 @@ public class RendererTest { ...@@ -207,7 +212,8 @@ public class RendererTest {
assertEquals( stream.toString().length(), 18393, "Rendered differently" ); //System.err.println( stream.toString() );
assertTrue( valueSimilarTo( stream.toString().length(), 18394 ), "Rendered differently: expected "+18394+" but was "+stream.toString().length() );
...@@ -220,7 +226,7 @@ public class RendererTest { ...@@ -220,7 +226,7 @@ public class RendererTest {
assertEquals( stream.toString().length(), 772, "Rendered differently" ); assertTrue( valueSimilarTo( stream.toString().length(), 770 ), "Rendered differently: expected "+770+" but was "+stream.toString().length() );
