GitLab
Explore
Primary navigation
Search or go to…
A
Alignment API
Manage
Plan
Issue boards
Code
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package Registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
moex
Alignment API
c7bb7b12
c7bb7b12
8 years ago
Jérôme Euzenat
Downloads
Patches
- mentioned the need to use the -W switch in order to benefit from the rest interface
eef46b3c
html/rest.html
+1
-1
1 addition, 1 deletion
html/rest.html
1 addition
1 deletion
html/rest.html
c7bb7b12
@@ -12,7 +12,7 @@
<h2>
REST interface
</h2>
<p>
The Alignment server provides a REST interface for accessing the
functions available on the server. Each request is an URL starting
(when launched with the -W switch)
with a prefix, e.g., http://aserv.inrialpes.fr/rest/. The request type
is identified by a string followed by a question mark, e.g., match?,
and parameters are given in the classical URL syntax, e.g.,
This diff is collapsed.
Loading
Save comment
