Commit ba79ea2f authored by Jérôme Euzenat's avatar Jérôme Euzenat
- preliminary bits for algebraic manipulation of BasicOntologyNetworks
parent 6b856ca0
...@@ -131,7 +131,7 @@ public class BasicOntologyNetwork implements OntologyNetwork { ...@@ -131,7 +131,7 @@ public class BasicOntologyNetwork implements OntologyNetwork {
public Set<Alignment> getAlignments(){ public Set<Alignment> getAlignments(){
return alignments; return alignments;
public Set<URI> getOntologies(){ public Set<URI> getOntologies() {
return ontologies.keySet(); // ?? return ontologies.keySet(); // ??
public Set<Alignment> getTargetingAlignments( URI onto ){ public Set<Alignment> getTargetingAlignments( URI onto ){
...@@ -148,6 +148,116 @@ public class BasicOntologyNetwork implements OntologyNetwork { ...@@ -148,6 +148,116 @@ public class BasicOntologyNetwork implements OntologyNetwork {
for ( Alignment al : newal ) addAlignment( al ); for ( Alignment al : newal ) addAlignment( al );
* Normalizes an ontology network for it to have exactly one alignment between each pair of ontologies.
* Modifies the network
public void normalize() throws AlignmentException {
for ( OntologyTriple ot1 : ontologies.values() ) {
for ( OntologyTriple ot2 : ontologies.values() ) {
Set<Alignment> als = intersect( ot1.sourceAlignments, ot2.targettingAlignments );
// Suppress them
if ( als.size() != 1 ) {
Alignment norm = normalizeAlignmentSet( als, ot1.onto, ot2.onto );
for ( Alignment al : als ) {
remAlignment( al );
// Add new
addAlignment( norm );
protected Alignment normalizeAlignmentSet( Set<Alignment> als, URI onto1, URI onto2 ) {
Alignment result = null;
if ( als.size() == 0 ) { // If no element, create new
result = new BasicAlignment();
result.init( onto1, onto2 );
} else if ( als.size() > 1 ) { // If more than one element, merge them
result = null;
if ( result == null ) {
result = al;
} else {
result.join( al );
} else {
result = als.iterator().next();
return result;
protected Set<Alignment> intersect( Set<Alignment> s1, Set<Alignment> s2 ) {
Set<Alignment> result = new HashSet<Alignment>();
for ( Alignment x : s1 ) {
if ( s2.contains( x ) ) result.add( x );
return result;
* Match ontologies in a network, using existing ontologies as input...
* TODO
public void match( String method, boolean reflexive, boolean symmetric) throws AlignmentException {
if ( ( ot1 == ot2 && reflexive )
|| symmetric ) {
Alignment init = normalizeAlignmentSet( als, ot1.onto, ot2.onto );
remAlignment( al );
// Create the alignment process
//AlignmentProcess ap = ...
// Match
//ap.init( ot1.onto, ot2.onto );
//ap.align( init, (Properties)null );
// replace
//addAlignment( ap );
* Intersection of two ontology networks...
* Creates a new network
* TODO
public static BasicOntologyNetwork meet( OntologyNetwork on1, OntologyNetwork on2 ) throws AlignmentException {
BasicOntologyNetwork result = new BasicOntologyNetwork();
Set<URI> ontologies2ndNetwork = on2.getOntologies();
// intersect these...
for ( URI onto1 : on1.getOntologies() ) {
if ( ontologies2ndNetwork.contains( onto1 ) ) {
result.addOntology( onto1 );
// go to the networks now
for ( URI onto1 : result.getOntologies() ) {
for ( URI onto2 : result.getOntologies() ) {
// Get the alignments from both networks
// Normalise them (yes because it is join)
// Meet them
return result;
* Union of two ontology networks...
* TODO
public static BasicOntologyNetwork join( OntologyNetwork on1, OntologyNetwork on2 ) throws AlignmentException {
return (BasicOntologyNetwork)null;
* Add alignments only if there is no existing alignments * Add alignments only if there is no existing alignments
public void match( Class<? extends AlignmentProcess> method, boolean reflexive ) throws AlignmentException { public void match( Class<? extends AlignmentProcess> method, boolean reflexive ) throws AlignmentException {
