Commit 93a0bcc7 authored by Jérôme Euzenat's avatar Jérôme Euzenat
- Version 4.5
parent 6e430ab5
......@@ -312,7 +312,7 @@
</javac>
<!-- possible groups: raw=impl+serv+io+onto+omwg, full=raw+ling+sem -->
<!-- ling requires WordNet and takes ages initialising it -->
<testng groups="full"
<testng groups="raw"
outputDir="test/html" verbose="1"
haltOnFailure="false" failureProperty="failed">
<!-- if ones uses logback -->
......@@ -76,7 +76,7 @@ with a warning:
<!--h2>Version 4.7 (1xxx): ??/??/201x - Letraset</h2-->
<!--h2>Version 4.6 (1xxx): ??/??/201X - Da lec'h all</h2-->
<h2>Version 4.5 (18xx): ??/03/2013 - Building 16</h2>
<h2>Version 4.5 (1847): 25/03/2013 - Building 16</h2>
<p><ul compact="1">
<li>Added several EDOAL-SPARQL renderers (impl)</li>
<li>Added <tt>ontowrap</tt> support in database store (server)</li>
No preview for this file type
......@@ -16,8 +16,8 @@
<groupId>org.semanticweb.owl</groupId>
<artifactId>align</artifactId>
<version>4.4</version>
<!-- Rev 1835:1844M 25/03/2013 -->
<version>4.5</version>
<!-- Rev 1846M 25/03/2013 -->
<name>The Alignment API</name>
<description>The Alignment API is an API for manipulating ontology alignments.</description>
<url>http://alignapi.gforge.inria.fr</url>
<groupId>fr.inrialpes.exmo.align</groupId>
<artifactId>alignsvc</artifactId>
<name>Alignment server</name>
<description>A server for storing and sharing ontology alignments.</description>
......@@ -42,19 +42,19 @@
<dependency>
<scope>compile</scope>
</dependency>
<dependency>
<groupId>fr.inrialpes.exmo</groupId>
<artifactId>ontowrap</artifactId>
</dependency>
<dependency>
<artifactId>procalign</artifactId>
</dependency>
<dependency>
<name>Ontology wrapping API</name>
<description>An ontology wrapping API and library.</description>
<name>Reference implementation of the Alignment API</name>
<description>Implementation of the Alignment API for manipulating ontology alignments.</description>
......@@ -42,13 +42,13 @@
<dependency>
</dependency>
<dependency>
</dependency>
<dependency>
