Commit 7a109058 authored by Jérôme Euzenat's avatar Jérôme Euzenat
- added parameterised measure
parent 39c76f8b
......@@ -72,6 +72,7 @@ import fr.inrialpes.exmo.align.parser.AlignmentParser;
* -c --color
* -v --value
* -e --labels
* -m --measure
* -d debug --debug=level
* -l list of compared algorithms
* -t output --type=output: xml/tex/html/ascii
......@@ -85,6 +86,7 @@ import fr.inrialpes.exmo.align.parser.AlignmentParser;
* requested (<CODE>-o</CODE> flags), then output will be written to
* <CODE>output</CODE> if present, stdout by default. In case of the Latex output, there are numerous files generated (regardless the <CODE>-o</CODE> flag).
* <pre>
* $Id$
* </pre>
......@@ -92,6 +94,35 @@ import fr.inrialpes.exmo.align.parser.AlignmentParser;
* @author Jrme Euzenat
Generating Spider/Radar view in TikZ is very easy.
The code below works.
But it is less informative than the above presentation.
\begin{tikzpicture}
% JE: experiment to draw radar/spider plots in TikZ
% n= number of dimensions (here 5)
% w=radius if the graph (here 2)
% p=number of isovalue lines (here 2)
% grid
% (for i=1 to n do \draw[black!50] (0,0) -- (i*360/n:w);
\draw[black!50] (0,0) -- (0:2) node {instances};
\draw[black!50] (0,0) -- (72:2) node {properties};
\draw[black!50] (0,0) -- (144:2) node {label};
\draw[black!50] (0,0) -- (216:2) node {hierarchy};
\draw[black!50] (0,0) -- (288:2);
% (for i=1 to p do \draw[black!50] (0,0) -- (i*360/n:w/i);
\draw[black!50] (0:2) -- (72:2) -- (144:2) -- (216:2) -- (288:2) -- (360:2);
\draw[black!50] (0:1) -- (72:1) -- (144:1) -- (216:1) -- (288:1) -- (360:1);
% any curve can be displayed in the same way
\draw (0:1) -- (72:1.22) -- (144:1.56) -- (216:.78) -- (288:.6) -- (360:1);
\end{tikzpicture}
public class GroupOutput {
static int SIZE = 16;// Nb of cells = 2^ = 16
......@@ -120,6 +151,7 @@ public class GroupOutput {
boolean labels = false;
boolean value = false;
int debug = 0;
int measure = 0;
PrintWriter output = null;
public static void main(String[] args) {
......@@ -128,7 +160,7 @@ public class GroupOutput {
public void run(String[] args) throws Exception {
LongOpt[] longopts = new LongOpt[9];
LongOpt[] longopts = new LongOpt[10];
longopts[0] = new LongOpt("help", LongOpt.NO_ARGUMENT, null, 'h');
longopts[1] = new LongOpt("output", LongOpt.REQUIRED_ARGUMENT, null, 'o');
......@@ -138,8 +170,9 @@ public class GroupOutput {
longopts[6] = new LongOpt("list", LongOpt.REQUIRED_ARGUMENT, null, 'l');
longopts[7] = new LongOpt("value", LongOpt.NO_ARGUMENT, null, 'v');
longopts[8] = new LongOpt("labels", LongOpt.NO_ARGUMENT, null, 'e');
longopts[9] = new LongOpt("measure", LongOpt.REQUIRED_ARGUMENT, null, 'm');
Getopt g = new Getopt("", args, "hveo:c::d::l:t:", longopts);
Getopt g = new Getopt("", args, "hveo:c::d::l:t:m:", longopts);
int c;
String arg;
......@@ -173,6 +206,13 @@ public class GroupOutput {
/* List of filename */
fileNames = g.getOptarg();
break;
case 'm' :
/* measure to be used */
String s = g.getOptarg();
if ( s.equals("p") ) measure = 1;
else if ( s.equals("r") ) measure = 2;
else if ( s.equals("o") ) measure = 3;
break;
case 'd' :
/* Debug level */
arg = g.getOptarg();
......@@ -253,7 +293,7 @@ public class GroupOutput {
String prefix = dir.toURI().toString()+"/"+tests[i]+"/";
try {
PRecEvaluator evaluator = (PRecEvaluator)eval( prefix+"refalign.rdf", prefix+algo+".rdf");
result = result + evaluator.getFmeasure();
result += getMeasure( evaluator );
nbtests++; // Only the tests that succeed
} catch ( AlignmentException aex ) { // simple error message
if ( aex.getCause() != null )
......@@ -369,6 +409,13 @@ public class GroupOutput {
return result;
public double getMeasure( PRecEvaluator evaluator ) {
if ( measure == 1 ) return evaluator.getPrecision();
if ( measure == 2 ) return evaluator.getRecall();
if ( measure == 3 ) return evaluator.getOverall();
return evaluator.getFmeasure();
public String colorFormat(double f){
if ( color == null ) return "";
else return ",fill="+color+"!"+(int)(f*100);
