Commit 79a0331b authored by Thinh Dong's avatar Thinh Dong
EDOAL to SPARQL renderer
parent 2e780627
......@@ -209,6 +209,7 @@ public class ParserPrinter {
File f = new File(dirName);
f.mkdir();
System.setProperty("user.dir", dirName);
System.setProperty("Split", "true");
writer = new PrintWriter (
new BufferedWriter(
......@@ -179,7 +179,7 @@ public abstract class GraphPatternRendererVisitor extends IndentedRendererVisito
public void createQueryFiles(String query) {
BufferedWriter out = null;
try {
FileWriter writer1 = new FileWriter(new File("").getAbsolutePath()+"query"+ number +".rq");
FileWriter writer1 = new FileWriter(new File("").getAbsolutePath()+"/query"+ number +".rq");
out = new BufferedWriter(writer1);
number++;
out.write(query);
......@@ -1023,13 +1023,15 @@ public abstract class GraphPatternRendererVisitor extends IndentedRendererVisito
public void visit( final Value e ) throws AlignmentException {
String str = e.getType().toString();
int index;
if (str.contains("#"))
index = str.lastIndexOf("#");
else
index = str.lastIndexOf("/");
uriType = str.substring(0, index+1);
if (e.getType() != null) {
int index;
else
value = e.getValue();
package fr.inrialpes.exmo.align.impl.renderer;
import fr.inrialpes.exmo.align.impl.edoal.Expression;
import java.io.PrintWriter;
import org.semanticweb.owl.align.Alignment;
import org.semanticweb.owl.align.AlignmentException;
import org.semanticweb.owl.align.AlignmentVisitor;
import org.semanticweb.owl.align.Cell;
import org.semanticweb.owl.align.Relation;
import fr.inrialpes.exmo.align.impl.Annotations;
import fr.inrialpes.exmo.align.impl.BasicAlignment;
import fr.inrialpes.exmo.align.impl.Namespace;
import fr.inrialpes.exmo.align.parser.SyntaxElement;
import fr.inrialpes.exmo.ontowrap.Ontology;
import java.net.URI;
import java.util.ArrayList;
import java.util.Enumeration;
import java.util.Hashtable;
import java.util.Iterator;
import java.util.List;
import java.util.Properties;
public class SPARQLConstructRendererVisitor extends GraphPatternRendererVisitor implements AlignmentVisitor{
......@@ -33,9 +21,7 @@ public class SPARQLConstructRendererVisitor extends GraphPatternRendererVisitor
Cell cell = null;
Hashtable<String,String> nslist = null;
boolean embedded = false;
private static Namespace DEF = Namespace.ALIGNMENT;
private List<String> listBGP1;
private List<String> listBGP2;
......@@ -105,8 +91,10 @@ public class SPARQLConstructRendererVisitor extends GraphPatternRendererVisitor
query += "WHERE {"+NL;
query += listBGP2.get(listBGP2.size()-1)+NL;
query += "}"+NL;
indentedOutputln(query);
createQueryFiles(query);
if(System.getProperty("Split")=="true")
else
query="";
......@@ -124,8 +112,10 @@ public class SPARQLConstructRendererVisitor extends GraphPatternRendererVisitor
query += listBGP1.get(listBGP1.size()-1)+NL;
query += "}"+NL;
else
