Commit 71bb4ddd authored by Jérôme Euzenat's avatar Jérôme Euzenat
Updates align.html with CVS instructions
Updated build with new repository
parent a97bb20e
...@@ -31,6 +31,7 @@ ...@@ -31,6 +31,7 @@
<property name="email" value="Jerome.Euzenat@inrialpes.fr"/> <property name="email" value="Jerome.Euzenat@inrialpes.fr"/>
<property name="libdir" value="lib" /> <property name="libdir" value="lib" />
<property name="debug" value="off"/> <property name="debug" value="off"/>
<property name="WebDir" value="/Volumes/Phata/Web/html/co4/align"/>
<filter token="DATE" value="${date}"/> <filter token="DATE" value="${date}"/>
<filter token="VERS" value="${version}"/> <filter token="VERS" value="${version}"/>
...@@ -116,19 +117,18 @@ ...@@ -116,19 +117,18 @@
</javadoc> </javadoc>
</target> </target>
<!-- tested -->
<target name="release" depends="init"> <target name="release" depends="init">
<antcall target="zip"/>
</target> </target>
<!-- tested -->
<target name="zip" depends="jar"> <target name="zip" depends="jar">
<echo message="Ziping..."/> <echo message="Ziping..."/>
<mkdir dir="html"/> <copy todir="${WebDir}">
<copy todir="html"> <fileset dir="html" includes="**/*.html"/>
<fileset dir="/Volumes/Phata/Web/html/co4/align"
includes="**/*.html" excludes="**/plan.html"/>
</copy> </copy>
<!-- zip everything from outside --> <!-- zip everything from outside -->
<zip zipfile="/Volumes/Phata/Web/html/co4/align/align.zip"> <zip zipfile="${WebDir}/align.zip">
<fileset dir="." includes="**/*"/> <fileset dir="." includes="**/*"/>
</zip> </zip>
</target> </target>
...@@ -11,9 +11,45 @@ ...@@ -11,9 +11,45 @@
<li>Implementing further alignment methods;</li> <li>Implementing further alignment methods;</li>
</ul></p> </ul></p>
<h1>Getting ontoalign</h1>
<h2>Fetching the ZIP'ed version</h2>
<p>The simplest way to use ontoalign is to get the following
<a href="align.zip">zipfile</a>. It contains all the soources, compiled
library, OWL API library.</p>
<h2>Anonymous CVS</h2>
<p>The very last version of ontoalign can be fetched from the CVS
source tree. Just do the following:
<pre>
$ cvs -d :pserver:cvs@cvs-sop.inria.fr:/CVS/exmosoft login
&lt;ENTER return when asked for the password&gt;
$ cvs -d :pserver:cvs@cvs-sop.inria.fr:/CVS/exmosoft checkout ontoalign
</pre>
... and you are done.
Note that you will have to fetch separately the <a href="owlapi.html">OWL-API</a>.</p>
<h2>CVS account</h2>
<p>If you have improved ontoalign and want this to be included in the
source tree and want to have a CVS account for that, please contact
Jerome . Euzenat (&Agrave;) inrialpes . fr.</p>
<p>Once provided with a password you will be able to check out from and
commit in our repository through:
<pre>
</pre>
</p>
<h1>Distribution</h1> <h1>Distribution</h1>
<p>It comes in a zip file: <a href="align.zip">align.zip</a>.</p> <p>It comes in a zip file: <a href="align.zip">align.zip</a>.</p>
<h2>Files</h2>
<p>Everything is built on top of the OWL-API binary distribution <p>Everything is built on top of the OWL-API binary distribution
(which does not need to be recompiled). (which does not need to be recompiled).
It is made of: It is made of:
...@@ -21,15 +57,33 @@ It is made of: ...@@ -21,15 +57,33 @@ It is made of:
<li>src: source classes;</li> <li>src: source classes;</li>
<li>rdf: some examples to be tested;</li> <li>rdf: some examples to be tested;</li>
<li>dtd: the align.dtd and align.owl alignment specification;</li> <li>dtd: the align.dtd and align.owl alignment specification;</li>
<li>lib: jar-files including a procalign.jar;</li> <li>lib: jar-files including a procalign.jar (in the zip-file the
owl-api libraries are included);</li>
<li>html: a few html presentation files</li> <li>html: a few html presentation files</li>
<li>build.xml: ant file to compile and generate jar-file.</li> <li>build.xml: ant file to compile and generate jar-file.</li>
<li>distrib: contains a few files for building the distribution</li> <li>distrib: contains a few files for building the distribution</li>
<li>classes: the compiled classes (useless)</li> <li>classes: the compiled classes (in the zip file, the classes are
<li>javadoc: generated javadoc;</li> included)</li>
<li>javadoc: generated javadoc (in the zip file the doc are
pregenerated);</li>
</ul> </ul>
</p> </p>
<h2>Requirements</h2>
<p><b>For using</b> you will need <a href="http://java.sun.com">Java
runtime environment</a> (tested in 1.4.1) and the <a href="owlapi.html">OWL-API binary distribution</a> (this is
included in the above zip file).</p>
<p><b>For extending</b> you will need Java compiler (tested in <a href="http://java.sun.com">Java
standard edition</a> 1.4.1) and the <a href="owlapi.html">OWL-API binary distribution</a> (this is included in the
above zip file).
<p><b>For developing</b> (compiling) you will need Java compiler
(tested in <a href="http://java.sun.com">Java standard edition</a> 1.4.1) and the <a href="owlapi.html">OWL-API binary distribution</a> (which is
not included in the CVS repositories). It is also very usefull to
have <a ref="http://ant.apache.org">Ant</a>.</p>
<h1>Compilation and use</h1> <h1>Compilation and use</h1>
<p>Generating the lib/procalign.jar file can be done by launching: <p>Generating the lib/procalign.jar file can be done by launching:
