Commit 5dd4e64a authored by Jérôme Euzenat's avatar Jérôme Euzenat
- added comments about a possible reimplementation
parent 0f78e7d3
...@@ -98,6 +98,12 @@ public class BasicParameters extends Properties implements Parameters, Cloneable ...@@ -98,6 +98,12 @@ public class BasicParameters extends Properties implements Parameters, Cloneable
return values(); return values();
* This is legacy code.
* java.lang.Properties offers p.storeToXML( System.out, "" )
* and p.loadFromXML( new FileInputStream( filename ) )
* which are natural implementers for this.
@SuppressWarnings( "unchecked" ) @SuppressWarnings( "unchecked" )
public void write(){ public void write(){
System.out.println("<?xml version='1.0' ?>"); System.out.println("<?xml version='1.0' ?>");
