Commit 5467094e authored by Jérôme Euzenat's avatar Jérôme Euzenat
- added better modelling of ontologies
parent c9cdc249
* $Id: Ontology.java 643 2008-02-23 11:16:09Z euzenat $
* Copyright (C) INRIA Rhne-Alpes, 2007-2008
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU Lesser General Public License as published by
* the Free Software Foundation; either version 2.1 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU Lesser General Public License for more details.
* You should have received a copy of the GNU Lesser General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
package fr.inrialpes.exmo.align.onto;
import java.net.URI;
* Store the information regarding ontologies in a specific structure
public class BasicOntology<O> implements Ontology<O> {
protected URI uri = null;
protected URI file = null;
protected URI formalismURI = null;
protected String formalism = null;
protected O onto = null;
public BasicOntology() {};
public URI getURI() { return uri; }
public URI getFile() { return file; }
public URI getFormURI() { return formalismURI; }
public String getFormalism() { return formalism; }
public O getOntology() { return onto; }
public void setURI( URI uri ) { this.uri = uri; }
public void setFile( URI file ) { this.file = file; }
public void setFormURI( URI u ) { formalismURI = u; }
public void setFormalism( String name ) { formalism = name; }
public void setOntology( O o ) { this.onto = o; }
* $Id$
* Copyright (C) INRIA Rhne-Alpes, 2003-2008
import java.util.Iterator;
import org.xml.sax.SAXException;
import org.semanticweb.owl.align.AlignmentException;
public abstract class ConcreteOntology<O> extends BasicOntology<O> implements LoadedOntology<O> {
public abstract Iterator<Object> getObjectProperties() throws AlignmentException;
public abstract Iterator<URI> getClassNames() throws AlignmentException;
public abstract Iterator<URI> getObjectPropertyNames() throws AlignmentException;
public abstract Iterator<URI> getDataPropertyNames() throws AlignmentException;
public abstract Iterator<URI> getInstanceNames() throws AlignmentException;
public abstract int nbClasses() throws AlignmentException;
public abstract int nbDataProperties() throws AlignmentException;
public abstract int nbObjectProperties() throws AlignmentException;
public abstract int nbInstances() throws AlignmentException;
public abstract Object getEntity( URI uri ) throws AlignmentException;
//public abstract void loadOntology( URI ref, OntologyCache ontologies ) throws SAXException, AlignmentException;
* $Id$
* Copyright (C) INRIA Rhne-Alpes, 2008
import java.util.Set;
public interface LoadedOntology<O> extends Ontology<O> {
public Set<Entity> getEntities();
public Set<Entity> getClasses();
public Set<Entity> getProperties();
public boolean contains(Entity e);
public void unload();
* $Id$
public interface Ontology<O> {
public URI getURI();
public URI getFile();
public URI getFormURI(); // Can be null
public String getFormalism(); // Can be null
public O getOntology();
public void setURI( URI uri );
public void setFile( URI file );
public void setFormURI( URI u );
public void setFormalism( String name );
public void setOntology( O o );
* $Id$
import java.util.Collections;
import java.util.HashSet;
import java.util.IdentityHashMap;
import java.util.Map;
public abstract class OntologyAdapter<O> extends ConcreteOntology<O> {
protected O ontology;
protected URI uri;
protected Set<Entity> classes;
protected Set<Entity> properties;
protected Set<Entity> entities;
public Set<Entity> individuals;
protected OntologyAdapter() {}
public OntologyAdapter(O ont, Set<Entity> c, Set<Entity> p, URI uri) {
ontology=ont;
classes = c;
properties = p;
entities = new HashSet<Entity>(c);
entities.addAll(p);
this.uri = uri;
public boolean contains(Entity e) {
return classes.contains(e) || properties.contains(e);
public Set<Entity> getClasses() {
return Collections.unmodifiableSet(classes);
public Set<Entity> getEntities() {
return Collections.unmodifiableSet(entities);
return ontology;
ontology = o;
public Set<Entity> getProperties() {
return Collections.unmodifiableSet(properties);
return uri;
public String toString() {
return uri.toString();
* $Id: OntologyCache.java 670 2008-03-02 00:06:16Z euzenat $
* modify it under the terms of the GNU Lesser General Public License
* as published by the Free Software Foundation; either version 2.1 of
* the License, or (at your option) any later version.
* This program is distributed in the hope that it will be useful, but
* WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
* Lesser General Public License for more details.
* License along with this program; if not, write to the Free Software
* USA.
// import java classes
import java.util.Hashtable;
import java.util.Enumeration;
* This caches the loaded ontologies so that it is possible to share them between alignments
* as well as to unload them if necessary.
* NOTE[3.2]: This class may be obsoleted and its code go to OntolofyFactory
* @author Jrme Euzenat
* @version $Id: OntologyCache.java 670 2008-03-02 00:06:16Z euzenat $
public class OntologyCache {
/** The list of currently loaded ontologies as a function:
* URI --> Ontology
* This is the ontology URI, NOT its filename
Hashtable<URI,LoadedOntology> ontologies = null;
public OntologyCache() {
ontologies = new Hashtable<URI,LoadedOntology>();
public void recordOntology( URI uri, LoadedOntology ontology ){
ontologies.put(uri,ontology);
public Ontology getOntology( URI uri ){
return ontologies.get( uri );
public void unloadOntology( URI uri, LoadedOntology ontology ){
LoadedOntology o = ontologies.get(uri);
o.unload();
ontologies.remove( uri );
public void clear(){
// JE: Onto [Is this correct ??]
//for ( Enumeration e = ontologies.elements() ; e.hasMoreElements(); ){
// Ontology o = (Ontology)e.nextElement();
for ( LoadedOntology o : ontologies.values() ){
o.unload();
ontologies.clear();
* $Id$
import java.util.HashMap;
import java.lang.reflect.InvocationTargetException;
public abstract class OntologyFactory {
protected static OntologyFactory instance;
private static String API_NAME="fr.inrialpes.exmo.align.onto.owlapi10.OWLAPIOntologyFactory";
protected static Map<URI,Ontology> loadedOntos= new HashMap<URI,Ontology>();
protected static Map<URI,Ontology> loadedOntosLogical= new HashMap<URI,Ontology>();
public static OntologyFactory newInstance() {
return newInstance(API_NAME);
public static OntologyFactory newInstance(String apiName) {
try {
Class ofClass = Class.forName(apiName);
Class[] cparams = {};
java.lang.reflect.Constructor ofConstructor = ofClass.getConstructor(cparams);
Object[] mparams = {};
instance = (OntologyFactory)ofConstructor.newInstance(mparams);
} catch (ClassNotFoundException cnfex ) {
cnfex.printStackTrace(); // better raise errors
} catch (NoSuchMethodException nsmex) {
nsmex.printStackTrace();
} catch (InstantiationException ieex) {
ieex.printStackTrace();
} catch (IllegalAccessException iaex) {
iaex.printStackTrace();
} catch (InvocationTargetException itex) {
itex.printStackTrace();
return instance;
public abstract LoadedOntology loadOntology( URI physicalURI );
// JE: This is not really usefule since it doubles OntologyCache...
// This may be included as well...
public Ontology getOntologyFromFile(URI physicalURI) {
Ontology onto;
if (loadedOntos.containsKey(physicalURI))
onto = loadedOntos.get(physicalURI);
else {
onto = loadOntology( physicalURI );
loadedOntos.put(physicalURI, onto);
loadedOntosLogical.put(onto.getURI(), onto);
return onto;
public static Ontology getOntologyFromURI(URI logicalURI) {
return loadedOntosLogical.get(logicalURI);
* $Id$
package fr.inrialpes.exmo.align.onto.owlapi10;
import java.util.NoSuchElementException;
import java.lang.UnsupportedOperationException;
import fr.inrialpes.exmo.align.onto.ConcreteOntology;
import fr.inrialpes.exmo.align.onto.LoadedOntology;
import fr.inrialpes.exmo.align.onto.Entity;
import org.semanticweb.owl.model.OWLOntology;
import org.semanticweb.owl.model.OWLProperty;
import org.semanticweb.owl.model.OWLClass;
import org.semanticweb.owl.model.OWLObjectProperty;
import org.semanticweb.owl.model.OWLDataProperty;
import org.semanticweb.owl.model.OWLIndividual;
import org.semanticweb.owl.model.OWLEntity;
import org.semanticweb.owl.model.OWLException;
* Acts as an interface with regard to an ontology APY
//private class OWLAPIOntology extends OntologyAdapter<OWLOntology> {
// private OWLAPIOntology() {super();}
public class OWLAPIOntology extends ConcreteOntology<OWLOntology> implements LoadedOntology<OWLOntology> {
public OWLAPIOntology() {
setFormalism( "OWL1.0" );
try {
setFormURI( new URI("http://www.w3.org/2002/07/owl#") );
} catch (Exception e) {}; // does not happen
public OWLOntology getOntology() { return onto; }
public void setOntology( OWLOntology o ) { this.onto = o; }
// Here it shoud be better to report exception
// JE: Onto this does not work at all, of course...
try {
return (Set<Entity>)((OWLOntology)onto).getClasses(); // [W:unchecked]
} catch (OWLException ex) {
return null;
try {
return null;
try {
return null;
public Set<Entity> getIndividuals() {
try {
return (Set<Entity>)((OWLOntology)onto).getIndividuals(); // [W:unchecked]
return null;
// The only point is if I should return OWLProperties or names...
// I guess that I will return names (ns+name) because otherwise I will need a full
// Abstract ontology interface and this is not the rule...
public Iterator<Object> getObjectProperties() throws AlignmentException {
try {
// [Warning:unchecked] due to OWL API not serving generic types
return ((OWLOntology)onto).getObjectProperties().iterator(); // [W:unchecked]
throw new AlignmentException( "Cannot get object properties", ex );
// JE: these are really specific methods I guess
public Iterator<URI> getObjectPropertyNames() throws AlignmentException {
try {
return new URIIterator(((OWLOntology)onto).getObjectProperties().iterator());
public Iterator<URI> getDataPropertyNames() throws AlignmentException {
try {
return new URIIterator(((OWLOntology)onto).getDataProperties().iterator());
public Iterator<URI> getClassNames() throws AlignmentException {
try {
return new URIIterator(((OWLOntology)onto).getClasses().iterator());
public Iterator<URI> getInstanceNames() throws AlignmentException {
try {
return new URIIterator(((OWLOntology)onto).getIndividuals().iterator());
public int nbClasses() throws AlignmentException {
try {
return ((OWLOntology)onto).getClasses().size();
throw new AlignmentException( "Cannot get class number" );
public int nbObjectProperties() throws AlignmentException {
try {
return ((OWLOntology)onto).getObjectProperties().size();
throw new AlignmentException( "Cannot get object property number" );
public int nbDataProperties() throws AlignmentException {
try {
return ((OWLOntology)onto).getDataProperties().size();
throw new AlignmentException( "Cannot get data property number" );
public int nbInstances() throws AlignmentException {
try {
return ((OWLOntology)onto).getIndividuals().size();
throw new AlignmentException( "Cannot get individual number" );
if ( e instanceof OWLEntity ){
if ( e instanceof OWLClass ) {
for ( Object o : getClasses() ){
if ( o == e ) return true;
} else if ( e instanceof OWLDataProperty ) {
for ( Object o : getProperties() ){
} else if ( e instanceof OWLIndividual ) {
for ( Object o : getIndividuals() ){
return false;
public void unload() {
try {
((OWLOntology)onto).getOWLConnection().notifyOntologyDeleted( ((OWLOntology)onto) );
} catch (OWLException ex) { System.err.println(ex); };
public Object getEntity( URI uri ) throws AlignmentException {
try {
OWLEntity result = ((OWLOntology)onto).getClass( uri );
if ( result == null ) result = ((OWLOntology)onto).getDataProperty( uri );
if ( result == null ) result = ((OWLOntology)onto).getObjectProperty( uri );
if ( result == null ) result = ((OWLOntology)onto).getIndividual( uri );
return result;
throw new AlignmentException( "Cannot dereference URI : "+uri );
final class URIIterator implements Iterator<URI> {
private Iterator it = null;
public URIIterator ( Iterator i ){
it = i;
public boolean hasNext() { return it.hasNext(); }
public URI next() throws NoSuchElementException {
try{
return ((OWLEntity)it.next()).getURI();
throw new NoSuchElementException(ex.toString()); // cannot encapsulate!
public void remove() throws UnsupportedOperationException {
throw new UnsupportedOperationException();
* $Id$
import java.net.URISyntaxException;
import org.apache.log4j.Logger;
import org.apache.log4j.Level;
import fr.inrialpes.exmo.align.onto.OntologyCache;
import fr.inrialpes.exmo.align.onto.OntologyFactory;
import fr.inrialpes.exmo.align.onto.EntityAdapter;
import fr.inrialpes.exmo.align.onto.EntityAdapter.TYPE;
import fr.inrialpes.exmo.align.onto.Ontology;
import org.semanticweb.owl.io.vocabulary.RDFSVocabularyAdapter;
import org.semanticweb.owl.model.OWLAnnotationInstance;
import org.semanticweb.owl.model.OWLDataValue;
import org.semanticweb.owl.model.helper.OWLEntityCollector;
import org.semanticweb.owl.util.OWLConnection;
import org.semanticweb.owl.util.OWLManager;
import org.semanticweb.owl.io.owl_rdf.OWLRDFParser;
import org.semanticweb.owl.io.owl_rdf.OWLRDFErrorHandler;
public class OWLAPIOntologyFactory extends OntologyFactory {
private URI formalismUri = null;
private String formalismId = "OWL1.0";
public OWLAPIOntologyFactory() {
try {
formalismUri = new URI("http://www.w3.org/2002/07/owl#");
} catch (URISyntaxException ex) { ex.printStackTrace(); } // should not happen
public static OntologyFactory getInstance() {
if (instance == null || !(instance instanceof OWLAPIOntologyFactory))
instance = new OWLAPIOntologyFactory();
return instance;
public LoadedOntology loadOntology( URI physicalURI ) {
OWLConnection connection = null;
Map parameters = new HashMap();
parameters.put(OWLManager.OWL_CONNECTION,
"org.semanticweb.owl.impl.model.OWLConnectionImpl");
try {
connection = OWLManager.getOWLConnection(parameters);
Level lev = Logger.getLogger("org.semanticweb.owl").getLevel();
Logger.getLogger("org.semanticweb.owl").setLevel(Level.ERROR);
OWLOntology ontology = connection.loadOntologyPhysical(physicalURI);
Logger.getLogger("org.semanticweb.owl").setLevel(lev);
OWLAPIOntology onto = new OWLAPIOntology();
// It may be possible to fill this as final in OWLAPIOntology...
onto.setFormalism( formalismId );
onto.setFormURI( formalismUri );
onto.setOntology( ontology );
onto.setFile( physicalURI );
try {
onto.setURI( ontology.getLogicalURI() );//getURI();
} catch (OWLException e) {
// Better put in the AlignmentException of loaded
e.printStackTrace();
return onto;
return null;
/** Can be used for loading the ontology if it is not available **/
// JE: Onto: check that the structure is properly filled (see build...)
public Ontology loadOntology( URI ref, OntologyCache ontologies ) throws SAXException, AlignmentException {
Ontology onto = null;
if ( (ontologies != null) && ( ontologies.getOntology( ref ) != null ) ) {
} else if ( onto != null ) {
} else {
OWLOntology parsedOnt = null;
try {
OWLRDFParser parser = new OWLRDFParser();
OWLRDFErrorHandler handler = new OWLRDFErrorHandler(){
public void owlFullConstruct( int code, String message )
throws SAXException {
public void owlFullConstruct(int code, String message, Object o)
public void error( String message ) throws SAXException {
throw new SAXException( message.toString() );
public void warning( String message ) throws SAXException {
System.err.println("WARNING: " + message);
parser.setOWLRDFErrorHandler( handler );
parser.setConnection( OWLManager.getOWLConnection() );
parsedOnt = parser.parseOntology( ref );
throw new AlignmentException( "Cannot load ontology "+ref, ex );
// THIS SHOULD NOW BE DONE WHEN CREATING THE ONTOLOGY
//setOntology( parsedOnt );
//if ( ontologies != null ) ontologies.recordOntology( ref, this );
//onto = parsedOnt;
return onto;
// JE: Onto: I am not sure of the meaning of this "get"
private Ontology getOntology(OWLOntology ont) {
// JE: Onto
//OntologyAdapter<OWLOntology> oModel = new OWLAPIOntology();
Ontology oModel = new OWLAPIOntology();
oModel.ontology=ont;
try {
oModel.uri=ont.getLogicalURI();//getURI();
// TODO Auto-generated catch block
oModel.classes = getEntities(oModel,OWLClass.class);
oModel.properties = getEntities(oModel,OWLProperty.class);
//oModel.individuals = getEntities(oModel,OWLIndividual.class);
oModel.entities = new HashSet<Entity>(oModel.properties);
oModel.entities.addAll(oModel.classes);
//oModel.entities.addAll(oModel.individuals);
//oModel.classes = getEntities(oModel,OWLEntity.class);
return oModel;
private Set<Entity> getEntities(LoadedOntology<OWLOntology> ont, Class<? extends OWLEntity> c){
OWLEntityCollector ec = new OWLEntityCollector();
try {
ont.getOntology().accept(ec);
Set<Entity> entities = new HashSet<Entity>();
for (Object obj : ec.entities()) {
if (c.isInstance(obj) && (((OWLEntity) obj).getURI() != null) &&
((OWLEntity) obj).getURI().getSchemeSpecificPart().equals(ont.getURI().getSchemeSpecificPart())){
//System.out.println(((OWLEntity) obj).getURI().getSchemeSpecificPart()+" - "+ont.getURI().getSchemeSpecificPart());
//System.out.println(((OWLEntity) obj).getURI()+" : "+ont.getOntology().contains(obj));
entities.add(new OWLAPIEntity((OWLEntity)obj, ont, ((OWLEntity)obj).getURI() ));
return entities;
return null;
private void addAnnotations(OWLAPIEntity ent) {
for (String[] a : getAnnotations(ent.getObject(),(OWLOntology)ent.getOntology().getOntology())) {
ent.getAnnotations().add(a[0]);
if (a[1]!=null) {
ent.getLangToAnnot(EntityAdapter.LANGUAGES.valueOf(a[1])).add(a[0]);
if (a[2].equals(RDFSVocabularyAdapter.INSTANCE.getComment())) {
ent.getTypeToAnnot(EntityAdapter.TYPE.comment).add(a[0]);
else if (a[2].equals(RDFSVocabularyAdapter.INSTANCE.getLabel())) {
private Set<String[]> getAnnotations(OWLEntity e, OWLOntology o) {
Set<String[]> res = new HashSet<String[]>();
Set annots;
try {
annots = e.getAnnotations(o);
for (Object annot : annots) {
OWLAnnotationInstance annInst = ((OWLAnnotationInstance) annot);
String val;
String lang=null;
String annotUri = annInst.getProperty().getURI().toString();
if ( annInst.getContent() instanceof OWLDataValue ) {
OWLDataValue odv = (OWLDataValue) annInst.getContent();
val = odv.toString();
lang = odv.getLang();
else
val= (String) annInst.getContent();
res.add(new String[]{val,lang,annotUri});
catch (OWLException oe) {
oe.printStackTrace();
return Collections.unmodifiableSet(res);
private class OWLAPIEntity extends EntityAdapter<OWLEntity> {
//private boolean toLoad=true;
private OWLAPIEntity() { super(false); }
private OWLAPIEntity(OWLEntity e, Ontology o, URI u ) {
super( e, o, u, false);
public Set<String> getAnnotations(String lang, TYPE type) {
if (this.annotations==null) {
init();
addAnnotations(this);
//toLoad=false;
return super.getAnnotations(lang, type);
