Commit af524052 authored by MARTINEZ Thierry 's avatar MARTINEZ Thierry
First class ODE systems
parent 5e4ba131
ADDITIONAL_MODULES=modules/sbml/sbml_utils.pl ADDITIONAL_MODULES=modules/sbml/sbml_utils.pl
MODULES=$(shell sed -n -E 's/^- (.*\.pl)$$/\1/p' toc.org) $(ADDITIONAL_MODULES) MODULES=$(shell sed -n -E 's/^[+-] (.*\.pl)$$/\1/p' toc.org) \
# load_test_files/1 should make this useless, but I cannot find how to use it # load_test_files/1 should make this useless, but I cannot find how to use it
TEST_MODULES=$(wildcard $(MODULES:.pl=.plt)) TEST_MODULES=$(wildcard $(MODULES:.pl=.plt))
...@@ -62,7 +62,7 @@ check_conservations :- ...@@ -62,7 +62,7 @@ check_conservations :-
'checks all conservation laws against reactions, and if necessary kinetics 'checks all conservation laws against reactions, and if necessary kinetics
(see also \\command{add_conservation/1}).' (see also \\command{add_conservation/1}).'
compute_ode, ode_system,
forall( forall(
% model: current_model? compute_ode already supposes a single model % model: current_model? compute_ode already supposes a single model
...@@ -245,6 +245,10 @@ read_toc(Stream, Type) :- ...@@ -245,6 +245,10 @@ read_toc(Stream, Type) :-
atom_codes(Atom, Line), atom_codes(Atom, Line),
atom_concat('%', _, Atom)
true
atom_concat('* ', Section, Atom) atom_concat('* ', Section, Atom)
add_section(1, Section) add_section(1, Section)
...@@ -257,7 +261,7 @@ read_toc(Stream, Type) :- ...@@ -257,7 +261,7 @@ read_toc(Stream, Type) :-
add_section(3, Section) add_section(3, Section)
Atom = '+ index' Atom = '- index'
assertz(toc(index)) assertz(toc(index))
...@@ -10,6 +10,7 @@ ...@@ -10,6 +10,7 @@
delete_vertex/1, delete_vertex/1,
edge/1, edge/1,
add_edge/1, add_edge/1,
edgeref/1,
delete_edge/1, delete_edge/1,
list_edges/0, list_edges/0,
list_isolated_vertices/0, list_isolated_vertices/0,
...@@ -116,15 +117,22 @@ add_edge(EdgeList) :- ...@@ -116,15 +117,22 @@ add_edge(EdgeList) :-
delete_edge(EdgeList) :- :- grammar(edgeref).
edgeref(Edge) :-
edge(Edge).
delete_edge(EdgeRefList) :-
biocham_command(*), biocham_command(*),
type(EdgeList, '*'(edge)), type(EdgeRefList, '*'(edgeref)),
doc('Deletes a set of edges from the current graph.'), doc('Deletes a set of edges from the current graph.'),
get_current_graph(GraphId), get_current_graph(GraphId),
member(Edge, EdgeList), member(EdgeRef, EdgeRefList),
delete_item([parent: GraphId, kind: edge, key: Edge]) delete_item([parent: GraphId, kind: edge, key: EdgeRef])
...@@ -258,11 +266,11 @@ list_attributes(GraphObject) :- ...@@ -258,11 +266,11 @@ list_attributes(GraphObject) :-
get_current_graph(Id) :- get_current_graph(Id) :-
get_selection(current_graph, [Id]). get_selection(current_model, current_graph, [Id]).
set_current_graph(Id) :- set_current_graph(Id) :-
set_selection(current_graph, [Id]). set_selection(current_model, current_graph, [Id]).
get_graph_name(Id, Name) :- get_graph_name(Id, Name) :-
...@@ -37,8 +37,8 @@ ...@@ -37,8 +37,8 @@
inherits/1, inherits/1,
inherits/2, inherits/2,
begin_command/0, begin_command/0,
get_selection/2, get_selection/3,
set_selection/2, set_selection/3,
at_delete/2, at_delete/2,
get_parent/2 get_parent/2
...@@ -338,7 +338,7 @@ load_biocham_stream(Stream) :- ...@@ -338,7 +338,7 @@ load_biocham_stream(Stream) :-
current_models(Models) :- current_models(Models) :-
get_selection(current_models, Models). get_selection(top, current_models, Models).
set_current_models(Models) :- set_current_models(Models) :-
...@@ -347,7 +347,7 @@ set_current_models(Models) :- ...@@ -347,7 +347,7 @@ set_current_models(Models) :-
throw(error(cannot_select_no_models)) throw(error(cannot_select_no_models))
set_selection(current_models, Models) set_selection(top, current_models, Models)
...@@ -360,7 +360,7 @@ new_model(Id) :- ...@@ -360,7 +360,7 @@ new_model(Id) :-
add_item([parent: top, kind: model, key: new_model, id: Id]), add_item([parent: top, kind: model, key: new_model, id: Id]),
item([parent:top, kind: model, key: initial, id: InitialId]) item([parent: top, kind: model, key: initial, id: InitialId])
inherits(Id, InitialId) inherits(Id, InitialId)
...@@ -567,7 +567,7 @@ all_ids(Options, Ids) :- ...@@ -567,7 +567,7 @@ all_ids(Options, Ids) :-
optional(Item, List) :- optional(Item, List) :-
memberchk(Item, List) member(Item, List)
true true
...@@ -646,7 +646,7 @@ list_ids_aux(Options, Ids) :- ...@@ -646,7 +646,7 @@ list_ids_aux(Options, Ids) :-
item(Id, _, _, Item), item(Id, _, _, Item),
indent(Indent), indent(Indent),
selection(_, Id) selection(_, _, Id)
Selected = '*' Selected = '*'
...@@ -710,12 +710,12 @@ delete_item(Id) :- ...@@ -710,12 +710,12 @@ delete_item(Id) :-
retractall(selection(_, Id)), retractall(selection(_, _, Id)),
KindItem = model KindItem = model
selection(current_models, _) selection(top, current_models, _)
true true
...@@ -829,18 +829,21 @@ inherits_from(Id, AncestorId) :- ...@@ -829,18 +829,21 @@ inherits_from(Id, AncestorId) :-
inherits_from(IntermediateAncestorId, AncestorId). inherits_from(IntermediateAncestorId, AncestorId).
:- dynamic(selection/2). :- dynamic(selection/3).
get_selection(SelectionName, Ids) :- get_selection(ParentOrCurrentModel, SelectionName, Ids) :-
get_selection_parent(ParentOrCurrentModel, Parent),
findall( findall(
Id, Id,
selection(SelectionName, Id), selection(Parent, SelectionName, Id),
Ids). Ids
set_selection(SelectionName, IdsOrOptions) :- set_selection(ParentOrCurrentModel, SelectionName, IdsOrOptions) :-
retractall(selection(SelectionName, _)), get_selection_parent(ParentOrCurrentModel, Parent),
retractall(selection(Parent, SelectionName, _)),
IdsOrOptions = [_: _| _] IdsOrOptions = [_: _| _]
...@@ -850,13 +853,24 @@ set_selection(SelectionName, IdsOrOptions) :- ...@@ -850,13 +853,24 @@ set_selection(SelectionName, IdsOrOptions) :-
member(Id, IdsOrOptions) member(Id, IdsOrOptions)
assertz(selection(SelectionName, Id)) assertz(selection(Parent, SelectionName, Id))
get_selection_parent(ParentOrCurrentModel, Parent) :-
ParentOrCurrentModel = current_model
single_model(Parent)
Parent = ParentOrCurrentModel
:- dynamic(at_delete_goal/2). :- dynamic(at_delete_goal/2).
at_delete(Id, Goal) :- at_delete(Id, Goal) :-
assertz(at_delete_goal(Id, Goal)). assertz(at_delete_goal(Id, Goal)).
...@@ -28,7 +28,7 @@ numerical_simulation(Time) :- ...@@ -28,7 +28,7 @@ numerical_simulation(Time) :-
biocham_command, biocham_command,
type(Time, time), type(Time, time),
doc('performs a numerical simulation up to a given time.'), doc('performs a numerical simulation up to a given time.'),
make_ode_system, make_ode_system,
solve(Time). solve(Time).
:- module( :- module(
ode, ode,
list_ODE/0, new_ode_system/0,
compute_ode/0, delete_ode_system/1,
set_ode_system_name/1,
list_ode_systems/0,
select_ode_system/1,
ode/1,
add_ode/1,
oderef/1,
delete_ode/1,
list_ode/0,
ode_system/0,
import_ode/1,
import_reactions_from_ode_system/0,
get_current_ode_system/1,
all_odes/1,
ode/2, ode/2,
load_ode/1 op(1000, fx, init)
:- dynamic(ode/2).
list_ODE :- :- devdoc('\\section{Commands}').
new_ode_system :-
biocham_command,
doc('creates an ODE system.'),
add_item([kind: ode_system, key: new_ode_system, id: Id]),
set_current_ode_system(Id).
delete_ode_system(Name) :-
biocham_command,
type(Name, name),
doc('deletes an ODE system.'),
delete_items([kind: ode_system, key: Name]).
set_ode_system_name(Name) :-
biocham_command,
type(Name, name),
doc('sets the name of the current ODE system.'),
get_current_ode_system(Id),
replace_item(Id, ode_system, Name, Name).
list_ode_systems :-
biocham_command,
doc('lists the ODE systems of the current model.'),
list_items([kind: ode_system]).
select_ode_system(Name) :-
biocham_command,
type(Name, name),
doc('selects an ODE system'),
find_item([kind: ode_system, key: Name, id: Id]),
:- grammar(ode).
ode(d(X)/dt = E) :-
name(X),
arithmetic_expression(E).
ode(DX/dt = E) :-
name(DX),
add_ode(ODE) :-
ode(ODE),
ODE = (d(X)/dt = _)
Item = ODE
ODE = (DX/dt = E),
atom_concat(d, X, DX)
Item = (d(X)/dt = E)
throw(error(illformed_ode(ODE)))
add_item([parent: Id, kind: ode, key: X, item: Item]).
add_ode(ODEList) :-
biocham_command(*),
type(ODEList, '*'(ode)),
doc('adds the given set of ODEs to the current ODE system.'),
member(ODE, ODEList),
add_ode(ODE)
import_reactions_from_ode_system :-
biocham_command,
doc('adds the reactions that match the current ODE system.'),
ode(X, E),
monomial(Monomial, E),
Monomial = - OppositeMonomial,
coefficient_species(OppositeMonomial, Coefficient, Species)
add_reaction(Coefficient * Species for X => '_')
coefficient_species(Monomial, Coefficient, Species)
add_reaction(Coefficient * Species for '_' => X)
:- grammar(oderef).
oderef(X) :-
name(X).
delete_ode(ODERefList) :-
biocham_command(*),
type(ODERefList, '*'(oderef)),
doc('removes the given set of ODEs from the current ODE system.'),
member(Name, ODERefList),
delete_single_ode(Name)
list_ode :-
doc(' doc('
returns the set of ordinary differential equations lists the set of ODES of the current ODE system.
and initial concentrations (one line per molecule).
\\begin{example} \\begin{example}
biocham_silent(clear_model), biocham_silent(clear_model),
biocham(a => b), biocham(a => b),
biocham(present(a)), biocham(ode_system),
biocham(list_ODE), biocham(list_ode),
doc(' doc('
\\end{example} \\end{example}
list_items([parent: Id, kind: ode]).
ode_system :-
biocham_command,
doc('builds the set of ODES corresponding to the reactions of the current model.'),
delete_ode_system('ode_system'),
new_ode_system,
set_ode_system_name('ode_system'),
clean_draft_ode,
compute_ode, compute_ode,
print_ode. simplify_ode,
put_ode_into_system,
clean_draft_ode.
import_ode(InputFile) :-
biocham_command,
type(InputFile, input_file),
doc('imports a set of ODEs.'),
new_ode_system,
set_ode_system_name(InputFile),
setup_call_cleanup(
open(InputFile, read, Stream),
read_ode(Stream),
close(Stream)
:- devdoc('\\section{Public API}').
get_current_ode_system(Id) :-
get_selection(current_model, current_ode_system, [Id]).
all_odes(ODEs) :-
all_items([parent: Id, kind: ode], ODEs).
ode(X, E) :-
var(X)
item([parent: Id, kind: ode, item: (d(X)/dt = E)])
find_item([parent: Id, kind: ode, key: X, item: (d(X)/dt = E)])
:- devdoc('\\section{Private predicates}').
set_current_ode_system(Id) :-
set_selection(current_model, current_ode_system, [Id]).
:- dynamic(draft_ode/2).
clean_draft_ode :-
retractall(draft_ode(_, _)).
compute_ode :- compute_ode :-
retractall(ode(_, _)),
item([kind: reaction, item: Item]), item([kind: reaction, item: Item]),
reaction(Item, Kinetics, Reactants, Products), reaction(Item, Kinetics, Reactants, Products),
...@@ -37,16 +232,15 @@ compute_ode :- ...@@ -37,16 +232,15 @@ compute_ode :-
add_molecules(Reactants, -KineticsExpression), add_molecules(Reactants, -KineticsExpression),
add_molecules(Products, KineticsExpression) add_molecules(Products, KineticsExpression)
simplify_ode.
simplify_ode :- simplify_ode :-
retract(ode(Variable, Expression)), retract(draft_ode(Variable, Expression)),
simplify(Expression, SimplifiedExpression), simplify(Expression, SimplifiedExpression),
assertz(ode(Variable, SimplifiedExpression)) assertz(draft_ode(Variable, SimplifiedExpression))
...@@ -62,58 +256,153 @@ add_molecules(Molecules, Kinetics) :- ...@@ -62,58 +256,153 @@ add_molecules(Molecules, Kinetics) :-
add_molecule(Coefficient * Molecule, Kinetics) :- add_molecule(Coefficient * Molecule, Kinetics) :-
retract(ode(Molecule, Expression)) retract(draft_ode(Molecule, Expression))
true true
Expression = 0 Expression = 0
asserta(ode(Molecule, Expression + Coefficient * Kinetics )). asserta(draft_ode(Molecule, Expression + Coefficient * Kinetics)).
print_ode :- put_ode_into_system :-
write('Init \tODE\n'),
ode(Molecule, Equation), draft_ode(X, Expression),
get_initial_concentration(Molecule, InitialConcentration),
format('~f \td[~w]/dt=~w\n', [InitialConcentration, Molecule, Equation]) add_ode(d(X)/dt = Expression)
load_ode(InputFile) :- delete_single_ode(Name) :-
biocham_command, get_current_ode_system(Id),
type(InputFile, input_file), delete_item([parent: Id, kind: ode, key: Name]).
doc('
creates a new Biocham model (reaction rules, initial state, parameters and
macros) inferred from an xppaut .ode file (preferably written with
parameters).
external_convert_ode(InputFile, 'external_ode.bc'),
load_biocham('external_ode.bc').
add_ode(InputFile) :- read_ode(Stream) :-
type(InputFile, input_file), repeat,
doc(' read_line_to_codes(Stream, Codes),
adds reaction rules, initial state, parameters and (
macros inferred from an xppaut .ode file (preferably written with Codes = end_of_file
parameters). ->
external_convert_ode(InputFile, 'external_ode.bc'), ;
add_biocham('external_ode.bc'). read_term_from_codes(Codes, Expression, []),
Expression = end_of_file
fail
Expression = done
Expression = (init X = _E)
add_item([parent: Id, kind: initial_concentration, key: X, item: Expression])
Expression = (_DX/dt = _E)
add_ode(Expression)
fail
throw(error(syntax_error_in_ode_system(Codes, Expression)))
external_convert_ode(InputFile, OutputFile) :- monomial(Monomial, A + B) :-
setup_call_cleanup( !,
open('external_load_ode.bc', write, Ode_bc),
portray_clause(Ode_bc, load_ode(InputFile)), monomial(Monomial, A)
portray_clause(Ode_bc, export_biocham(OutputFile)), ;
portray_clause(Ode_bc, 'quit') monomial(Monomial, B)
close(Ode_bc)
), monomial(Monomial, A - B) :-
call_subprocess(path(biocham), ['external_load_ode.bc'], [stdout(pipe(_))]). !,
monomial_opposite(Monomial, B)
monomial(A, A).
monomial_opposite(Monomial, A + B) :-
monomial_opposite(Monomial, A)
monomial_opposite(Monomial, A - B) :-
monomial_opposite(A, - A).
coefficient_species(Coefficient * Species, Coefficient, Species) :-
coefficient_species(Species, 1, Species).
%print_ode :-
% write('Init \tODE\n'),
% ode(Molecule, Equation),
% get_initial_concentration(Molecule, InitialConcentration),
% format('~f \td[~w]/dt=~w\n', [InitialConcentration, Molecule, Equation])
%load_ode(InputFile) :-
% biocham_command,
% type(InputFile, input_file),
% doc('
% creates a new Biocham model (reaction rules, initial state, parameters and
% macros) inferred from an xppaut .ode file (preferably written with
% parameters).
% external_convert_ode(InputFile, 'external_ode.bc'),
